11-15-2022, 08:20 PM | #265 | |
Rep 103
2007 Imola Red Z4M
2005 Phoenix Yellow M3 6MT 2013 Interlagos Blue M3 6MT ZCP CF roof |
11-17-2022, 03:42 PM | #266 |
Rep 363
Has anyone else installed the airbox yet?
I'll be doing mine tomorrow and it would be great to hear more tips, particularly regarding getting the plastic elbow to attach properly to the airbox. |
11-17-2022, 07:19 PM | #267 |
Rep 977
The installation is not as easy as one may think, but not terrible. If you use the stock air filter box, it is fiddly to get all in place. With the Eventuri it will be easier as there is more space.
Get anti-slip tape to prevent the elbow boot to slip off, or some epdm window sealers, the thinest one. All plugs fit the Karbonius just as per factory. I am running the stock air filter box with the sound generator, and it sounds good, but the growl is to deep, and not the wale sound as the CSL or when match with the eventuri. Unfortunately my Eventuri filter is not with me and that is why I have to do with the OE air filter for now. Last tip, use either teflon tape, or thread sealer to prevent any leak. Last edited by maupineda; 11-17-2022 at 10:09 PM.. |
11-17-2022, 10:41 PM | #268 | |
Rep 363
Where did you use the teflon tape? |
11-17-2022, 10:45 PM | #269 |
Rep 977
11-18-2022, 04:06 PM | #270 |
Rep 363
11-18-2022, 05:10 PM | #271 |
Rep 977
Mine is complete, as stated before, I had to use the OE air filter as my Eventuri is no on hand, but I did install the sound generator, the installation is pretty clean, the one thing I do not like is that there is very little clearance from the OE air filter to the Karb airbox
All buttoned up Here you can see the sound generator Sound-wise, the generator floods the cabin, and the growl is deep in tone and cannot hear the induction noise from the airbox. that shall change once I have the Eventuri on. I will try to do a sound clip. I like the look, it is not as flashy as the CSL, but still looks pretty cool. Last edited by maupineda; 11-18-2022 at 05:19 PM.. |
GuggagZ4M22.00 grannyknot953.00 |
11-18-2022, 07:03 PM | #272 |
Rep 363
Awesome!
I think the Z4 install with the stock air filter housing looks better than in the E46. Somehow the spacing between the elbow, airbox and plenum looks better... noting that you said the airbox is a bit too close to the plenum! |
11-19-2022, 08:19 AM | #273 |
///M Enthusiast
43
Rep 110
The CSL crankcase vent hoses (11157833649) seem to be back ordered until February. Anybody know of where they may be in stock? Or anybody happen to have an extra they’re willing to sell to me?
11-19-2022, 04:15 PM | #274 | |
Rep 363
https://www.schmiedmann.com/en/cata-ol?q=11157833649# |
11-19-2022, 05:57 PM | #275 | |
///M Enthusiast
43
Rep 110
11-20-2022, 03:03 AM | #276 |
Rep 363
I got my Karbonius plenum installed yesterday but didn't get a chance to have a proper drive until today.
Notes on the installation: - pretty straightforward, even for someone like me that isn't very experienced. - I used silicone tape around the plenum opening. This gives a grippy surface without leaving a residue. - I had some trouble with the location of the dipstick - it was too close to the plenum and rubbed when I was putting the plenum. In the end I used rubber washers on the mount to space the dipstick away from the plenum, which worked fine (see one of the images below). - The hose that comes from the elbow (only Z4s have this) joins up with the electrical conduit that is mounted to the side of the dipstick. There is a mount on the standard plenum for these but not the Karbonius plenum. I zip-tied them up but it's not ideal (see photo below). - I tried to install the stock air filter housing but it was contacting the electrical conduit on the side of the dipstick and the dipstick itself. Even if I hadn't of used the spacers, it would have been close. So, I just installed my Eventuri straight away. Bit of a bummer as I wanted to do some tests with the stock air filter housing. Notes on Karbonius plenum performance - After GuggagZ4M said with an Eventuri it was equivalent sound-wise to the full CSL intake, I had some pretty high expectations, and it didn't quite live up to them. - Having said that, I had a long drive today and there is a definite change in tone and increase in volume. Particularly, the CSL 'warble' is much clearer now. Low revs (~3,000rpm) in 3rd and 4th really accentuate the sound and overall, the intake is just more present everywhere all the time. - I did a freeway on-ramp today with concrete barriers and the sound was epic! I stuffed up the recording up of this unfortunately. - I've never been in a car with a CSL intake and I'd be really keen to see how they compare. - Overall, I'm happy with the plenum and knowing what I know now, I would still buy it. I made a video, which includes the car in stock form, with Supersprint V2 headers and cat'd S-pipe, and then with headers, s-pipe, x-pipe, Powerloops and Eventuri and the current spec which is all the previous except the x-pipe (which I took off a while ago) plus the Karbonius plenum. I included the videos of the stock intake with the headers and s-pipe because when I added these it was much harder to hear the intake. So, this is probably the best baseline for the Karbonius plenum. Sorry for the funny framing in some of the videos - no one wants to see my face! Video link: https://youtu.be/az7Qdm6EMbo |
grannyknot953.00 GuggagZ4M22.00 |
11-20-2022, 12:32 PM | #277 |
Rep 977
Sound clips
I made some videos, I logged the rev range where CSL noise is more prevalent in general
So here is the first. The Karb OE Style box and no sound generator, with OE air filter https://youtube.com/shorts/bmSzhwQCnwM?feature=share This is with the sound generator and the foam filter in the pipe https://youtube.com/shorts/fNH9vhFaSO0?feature=share This is with the sound generator and the foam filter removed https://youtube.com/shorts/4Asysvdy3aQ?feature=share I think I like the foam option, without it, the noise is to rich in bass, and sounds synthetic, so I will run it with it and when the Eventuri comes, it would be the perfect combo IMO Last edited by maupineda; 11-20-2022 at 12:47 PM.. |
11-20-2022, 05:49 PM | #278 |
///M Enthusiast
43
Rep 110
11-20-2022, 06:47 PM | #279 |
Rep 977
11-21-2022, 02:49 AM | #280 | |
Rep 40
I use or sell a completely different sound generator than the one from the link in the quoted article. It is not the sound generator from the M54 engines e.g. from the Z4 3.0i etc. or E46 Compact. Mine is an own tested development with components from BMW and another high quality car manufacturer. I always add a piece of normal foam as insulation (you can get it anywhere in a DIY store). This can be cut even shorter to create an individual sound. If, for example, you find the sound too loud or annoying on longer journeys (this is also the case with the original CSL airbox...), you can use it. People who drive this in everyday life or on long journeys are sometimes annoyed by it. With the sound generator, you can simply pull the hose out of the interior in 10 seconds with a flick of the wrist and then drive absolutely standard. If you want the sound again, just put the hose back in the hole and you're done. The sound of the sound generator is very similar to that of the CSL airbox or the Karbonius OEM airbox. However, it is a bit bassier (depending on how you use the foam). Some even find it better. I prefer it a bit brighter myself. But all in all, you can say: The volume of the sound generator and the OEM Karbonius airbox is identical on the inside. The sound of the sound generator is about 90% the same as that of the Karbonius airbox. Just a bit bassier. The rest is identical (speed ranges etc. are operated in exactly the same way). The big difference is the price, as I explained above. The Karbonius OEM style airbox, including the rubber pipes etc., costs 1985€ in Germany, including tax. The sound generator 399€ + tax and shipping. I personally like the sound of the Karbonius OEM airbox a bit better. But if I had to decide again, I would go for the own sound generator again because of the 1500€ extra cost.
Insta: bmw_e86_m_legend
Interested in SOUNDGENERATOR like Airboxsound for S54? Whatsapp to +49 171 - 9945373 |
11-21-2022, 04:55 AM | #281 |
Rep 28
I am still waiting for my Karbonius carbon plenum, and the CSL hose won't arrive until February next year. I am not exactly sure how much louder the air intake sound will be with the Karbonius or if the intake sound will be more evident than my exhaust sound (SS V1 headers, resonated S pipes, OEM Hpipe and Strungmun mufflers).
If I find the intake induction music isn't loud enough, I'm thinking about doing the following mod. what do you think? https://www.fosterscmods.com/collections/universal-kit |
11-21-2022, 05:04 AM | #282 | |
Rep 28
have you tried other sound generators with less bassy sounds? such as the ones from Alfa Romeo, Ferrari 488, or Mini? or if there's a way to amplify the S54 induction sound without using a generator?
Would you consider making a version of your intake sound enhancer without the sound generator? Quote:
11-21-2022, 05:37 AM | #283 | |
Rep 40
The best is now that, what I use. It has to be a membrane. Because like the guy in the video, it's far too dangerous in the long run to drive without a proper membrane. I can explain why directly: The membrane prevents the wrong air from being drawn in and at the same time transmits the sound through the vibrating membrane. It is also very important that the membrane is durable in the long run. This means not only withstanding heat and micro-vibrations, but also misfires that can return to the intake system (this happens from time to time in all sport engines). In addition, the membrane must also be resistant to petrol, as otherwise gases and petrol backflows could dissolve the membrane in the long term. So this is not as simple an issue as some people think. The problem with the one in the video is clearly the danger of driving around with the wrong air and therefore too lean mixture. And at the end it should be said again: My sound generator makes it "a little" bassier than a bright sounding airbox,... but also only a "little" bassier (approx 10% more bass than orig. CSL Sound).
11-21-2022, 11:09 AM | #284 | |
Rep 28
the kit he uses has a membrane, just without the sound generator.
11-21-2022, 11:14 AM | #285 | ||
Rep 40
A Soundgenerator is just a membrane. Not more
11-22-2022, 10:46 AM | #286 |
Rep 919
Just got mine in. Seems like they placed a felt tape around the edge of the intake inlet from the elbow.
Also this is an in stock option in the states for the hose. https://www.ecstuning.com/b-turner-m.../018562la02~a/
2018 F80 ZCP 6MT YMB/SO 2015 F82 M4 6MT AW/SO - SOLD |
