07-16-2013, 11:06 AM | #1 |
Rep 12,565
How Many of You Actually Rotate Tires?
For those with a square setup, do you actually rotate or bother flipping asymmetrical tires?
07-16-2013, 10:07 PM | #3 |
enthusiast
48
Rep 1,695
Yes, on the track car every track day. But for the z4m with square set-up, I switch inside to out side rather than front to back. This is because I have more camber in the front, and I have found that if I rotate and flip, I have less contact patch in the rear and more in the front which makes me uncomfortable.
Lesson learned: don't run more camber than you need so your tires will wear evenly from inside to outside. |
07-16-2013, 10:57 PM | #4 | |
Rep 12,565
07-16-2013, 11:38 PM | #5 |
enthusiast
48
Rep 1,695
07-17-2013, 01:22 AM | #6 |
Rep 516
i flip fronts to back, to lazy to go to tire shop to flip left to rights
2007 BSM Z4M Coupe - 18" VOLK TE37 - 18" Apex ARC-8 - GC Track/Street
07-17-2013, 09:36 AM | #7 | |
Bimmer Noob
30
Rep 566
+1 left -> right, same reason, high neg camber.
08 Z4MC /// DKF Exhaust, Stoptech 6/4 BBK, TCK Coilovers, Strong-Strut, Apex EC-7's, APR Splitter/Wing, AFE Intake, Underdrive pulleys, AS SSK, Jaffster, UUC Tranny Mounts, Matte Grill, RPI Scoop, CF Badges |
07-17-2013, 12:11 PM | #8 |
Rep 4,531
Staggered, not square set-up.
I dismounted and flipped my tires for even wear. Too much outside shoulder wear, wanted to prolong the tires past 2 seasons...if possible. Yes it cost money. But it is either that or paying for another set of tires when I cord the outside. You need to pick your battles IMO |
07-17-2013, 01:06 PM | #9 | |
Rep 12,565
07-17-2013, 03:35 PM | #10 |
enthusiast
48
Rep 1,695
Not if you don't pay full price. It's $80 which is a lot cheaper than expensive new tires.
07-17-2013, 08:30 PM | #11 |
instagram 997turbotom
279
Rep 7,377
I flip my fronts to the back when the inside edges get visibly worn from the camber up front
directional tires, so no point in dismounting and reversing
08-05-2013, 01:44 AM | #12 |
Track Addict
110
Rep 813
Drives: 2010 BMW M3 E92 | 2008 Z4M E86
If you know shop owner you can get it done for 40 or maybe even less if you go often enough. I get mine done for 40 (remove, mount, balance)
BMW ///M3 Coupe
Completed November 16, 2009 Received December 29,2009 |
08-05-2013, 07:42 AM | #13 |
Rep 317
I'd swap em left to right too, about every other event.
K&W v3, APR splitter, magnaflow axle back35% tint, stubby antenna, Jet black, and interlagos blue stock wheels, clutch delay delete, illuminated ZHP shift knob, Leather Z m shift boot, and arm rest.
08-09-2013, 03:05 PM | #14 |
Rep 753
I rotate assymetric tires left to right every few track days.
And recently had my tire shop flip front tires inside/out on directional NT-05s that were wearing out driver side outer edge. |
08-09-2013, 09:50 PM | #15 |
enthusiast
48
Rep 1,695
08-19-2013, 09:08 AM | #16 |
Rep 753
I know. I am running about -2.3° and that has been good for street and track.
