01-07-2011, 05:06 PM | #1 |
Rep 576
Drives: Interlagos Z4 M Coupe
Noob question about sound improvement
Which will yield a larger overall sound increase: rpi axe-back, jvt headers, or xpipe?
Im sure this is a dumbass question, but i honestly dont know- thanks for the help |
01-07-2011, 05:45 PM | #3 |
Rep 12,570
have f360 chime in, i know he has the ebay headers. and i believe starscream has the xpipe (or full ss setup minus headers).
01-07-2011, 08:43 PM | #5 |
Rep 1,739
Drives: 2008 Z4MC
I connected the Supersprint X-Pipe to my stock mufflers and noticed a nice increase in growl. Not a lot, but definitely sounds meaner than the stock setup. Our stock cans are quite quiet.
01-07-2011, 09:33 PM | #6 |
Rep 421
The RPI will be the loudest without question. I had the BMS axle-back only then went back to full stock then went to JVT's only then back to stock. The exhaust cans definitely have the biggest impact on volume. Headers on an otherwise stock system will give you slightly more volume but are more noticeable in how they change the tone to a raspier note.
01-07-2011, 09:48 PM | #7 | |
Rep 576
thanks guys
01-08-2011, 12:38 AM | #8 |
Viper Driver
36
Rep 1,311
^might i add a consideration for intakes? gruppe m + anything above 4000 rpms = aural intoxication. anything less than 4000 rpms is nice and peaceful with a tinge more growl and bass than stock. albeit, intakes are all engine sound. exhaust note will have zero change.
01-08-2011, 03:36 AM | #9 |
///M-fanatic
193
Rep 3,885
Mufflers are definitely louder over headers or section 2/x-pipe. If you want louder, do mufflers first. If you want the most power gain, do headers first.
01-08-2011, 09:11 AM | #10 |
Rep 3,004
LOVE my Rogue Engineering Diablos....low growl, sounds like it looks now....plus, save significant weight which lowers the CG.
Racerbruce
01-08-2011, 10:27 AM | #11 |
Rep 1,002
I have SS X-Pipe and Race Cans! Definitely gives the a much deeper, loud tones and rumbles that you could feel in the cabin. The best parts are the fabulous burbling noise when downshifting (or when slightly tap on the throttle). There are some droning around 2800rpm; i always try not to be at that range for long (which easy to do except in the city or traffic situation). Not sure about the weight savings but they are definitely much lighter than OEM.
01-08-2011, 10:58 AM | #12 |
Rep 120
Might be slightly off topic but what do you guys think the sound/performance gains would be from doing a supersprint section 1 cat delete plus the X-pipe to the stock cans?
01-08-2011, 11:11 AM | #13 | |
Rep 1,002
http://www.europeancarweb.com/projec...n_s/index.html |
01-08-2011, 11:14 AM | #14 | |
Rep 1,002
http://www.europeancarweb.com/projec...car/index.html |
01-08-2011, 11:21 AM | #15 | |
///M-fanatic
193
Rep 3,885
headers section 1 section 2 mufflers |
01-08-2011, 03:23 PM | #16 |
Rep 576
thanks for the help- so it seems unanimous that the most sound increase comes from mufflers, and the most hp comes from headers?
01-08-2011, 03:55 PM | #17 |
Rep 421
The wife wasn't thrilled with the exhaust. (I think I'm going to put it back on this spring anyway) I loved the headers but hated the SES light and I wasn't about to spend a grand on a simple tune. I have a SS catless section 1 that I haven't tried yet as well. It may be the solution to get a little more volume without the hassles associated with the headers.
01-08-2011, 04:16 PM | #18 | |
Rep 576
01-10-2011, 01:53 PM | #19 |
Rep 120
So realistically doing section 1 and section 2 would be a noticeable gain compared to just muffers. As far as I know nobody has replaced both sections while leaving the oem mufflers on?
01-10-2011, 02:32 PM | #20 |
///M-fanatic
193
Rep 3,885
01-10-2011, 03:11 PM | #21 |
Rep 120
Well I think it'll please me to be the first!. I'll probably order up the Rogue X-pipe and have a local shop fab up some section 1 pipes. I'll start another thread and keep you guys posted
01-10-2011, 05:56 PM | #22 |
instagram 997turbotom
286
Rep 7,377
are you sure it woulnd't RAISE the center of gravity?
