      03-30-2012, 10:02 AM   #1
pingpong
Drives: BMW
New rear tires causing DSC to go off?
I recently replaced my rear tires with a pair of Goodyear F1 Asymmetric 2. The fronts are still the previous version Goodyear F1 Asymmetrics. On sweeping freeway onramp and offramps, DSC kicks in very very early, causing the car to understeer pretty dramatically.
Now before anyone says "the tires need to be broken in", there tires have well over 500 miles AND I can't even break them loose on hard corners stomping on the accelerator, so I'm very confident that they have plenty of grip.
From what I've read, it seems like the rear tires are probably bigger than the fronts, resulting in the car thinking the rotational speed between the front and rears are off, causing the DSC to kick in. Assuming that's the case, is there any way to reset the sensor associated with the DSC? My front's still have about 40% tread, so I don't really want to replace them.
      03-30-2012, 10:15 AM   #2
prodigal_m
Member
prodigal_m's Avatar
Drives: 2018 Estoril Blue/Black F31
It may be as simple as having too much grip in the rear...turn off the DSC and see if it feels ok.
      03-30-2012, 10:37 AM   #3
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
+1
I'm not sure about the answer to your question about reprogramming DSC, but your conclusion about the difference in rotational speeds is accurate.
      03-30-2012, 10:50 AM   #4
The HACK
The HACK's Avatar
1820
DSC requires a circumferential difference of at least 5% to make a fuss. If you retained stock diameters then even fully worn front down to the cords vs brand new rears won't have more than 1% difference in overall circumference.
DSC's not the issue here. If there's a dramatic difference in age and use between the front and rear wheels, there can be a significant enough difference in grip for DSC to start complaining.
      03-30-2012, 10:58 AM   #5
pingpong
Drives: BMW
The thing is, if I turn off DSC and DTC the car handles just fine. With it on, it understeers pretty bad at speeds north of 50 on gentle curves (scared the crap out of me the first time that happened). South of 50 I can toss it around even with the DSC on and it won't kick in.
      03-30-2012, 11:01 AM   #6
prodigal_m
Member
prodigal_m's Avatar
Buy new front tires...problem solved.
      03-30-2012, 11:04 AM   #7
pingpong
Drives: BMW
I would but I still have a ton of tread left in the front. Odds are once the new rears wear out the fronts will need to go too, but to replace all 4 at the same time is pretty pricey.
      03-30-2012, 11:33 AM   #8
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
Check your tire pressures too
      03-30-2012, 11:42 AM   #9
pingpong
Drives: BMW
Checked those, 33/38 which is what the manual says.
      03-30-2012, 01:08 PM   #10
ZStig
279
38 rear? Whaaaaaaaaat? Check your door jamb
      03-30-2012, 01:48 PM   #11
Incompatible
Drives: 07 AW Z4C 3.0Si
That sounds about right. For my 07 Si with 225/40f and 255/35r the door jamb sticker shows 33f and 39r. From other posts, it seems that BMW dropped the pressure to 38 for the rears on later cars?
      03-30-2012, 01:54 PM   #12
davesz4mc
Drives: 2007 z4mc
I thought the door said 30/30 for the M's? Do not know about the others...
      03-30-2012, 02:07 PM   #13
Beedub
I run 35psi all round. Perfect.
      03-30-2012, 03:13 PM   #14
pingpong
Drives: BMW
My 07 si with the sports package (225/40, 255/35) says 33/38 on the door jamb. Mines a roadster though, so many it's 1 less than the coupe?
      03-30-2012, 04:08 PM   #15
ZStig
279
exactly what I run, thats why I was so surprised
      03-30-2012, 04:09 PM   #16
ZStig
279
drop the rears to 30psi for better traction broski
      03-30-2012, 04:46 PM   #17
seank
enthusiast
seank's Avatar
48
The tire pressures in the door are the safe UNDERSTEER pressures.
      03-30-2012, 04:59 PM   #18
Beedub
30psi is way to low for me...... i do more track work remember, ideal hot temps are 40psi, im running the stock CSL rims with stock csl sizes, they were bmw recommended 35psi all round and this works very well for me... i tried it lower and i dont like the soft feel to the car.....
      03-30-2012, 05:49 PM   #19
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Guys,
OP has a 3.0, not an M I believe. Recommended pressures are not the same across M and non-M models.
      03-30-2012, 07:28 PM   #20
pokeybritches
2006 BMW Z4M  [8.50]
OP - What tire sizes do you have on the car right now?
      03-30-2012, 09:31 PM   #21
kklin
Drives: BMW Z4 M Coupe
pingpong,
Here's how to determine the production date - http://www.tirerack.com/tires/tirete....jsp?techid=11.
While you're looking, check for dry rot, which looks like fine cracks in your tire. When it occurs, I usually see it around the base of the tread blocks.
      04-02-2012, 01:33 PM   #22
pingpong
Drives: BMW
OEM sizes: 225/40 fronts and 255/35 rears.
