01-29-2012, 04:35 PM | #1 |
Rep 5,329
e92 m3 18" wheels
im surprised no-one is using these, the offsets are bang on really ALITTLE aggressive upfront with 8.5 and +30 offset but with -2.6ish camber thy should tuck in nicely..... the rears are perfect offsets for the z4m... i think these would really look the business imo....
anyone running these or considered it??
01-30-2012, 05:08 AM | #2 |
Stupid as shit
26
Rep 367
I wouldn't call 18mm outer over stock bang on. Not at all trying to flame or anything, but for example this is a how 8,5x18 ET35 (5mm LESS outside than ET30) looks like with cca -1 camber from top.
Yes, you can cure some of that with 2.6 camber but there's more to it, than just fitting it under the fender as HACK recently posted http://www.zpost.com/forums/showpost...59&postcount=8 |
01-30-2012, 08:21 AM | #3 |
Rep 409
being a nitpick here... the fronts are 8.5" et29. not that 1mm matters much when you're already past aggressive; i'm just one for being accurate.
anywho... TAKU has already done this... http://www.zpost.com/forums/showthre...0&highlight=m3
01-30-2012, 08:42 AM | #4 | |
Rep 5,329
01-30-2012, 08:47 AM | #5 | |
Rep 5,329
my et32 sits well within the fender with a -2.5..... which really dials out some of that understeer and still gives a decent wear from the tyres with the amount of track action my car see's, if anything id like to bump that camber to -2.6 when my Clubsports go on...
01-30-2012, 08:55 AM | #6 |
Rep 409
imho... 8.5" et29 is too much for a track car; however, that doesn't mean it's too much for your car. "to each his own", as they say.
somebody on here with arc8's has way more aggressive offsets than that. i think he's running more neg camber up front than in back. i'll see if i can find the thread.
01-30-2012, 09:11 AM | #7 | |
Rep 5,329
yeah it seems so.... et32 with -2.5 works really well, that extra few mm just pushes it to far i guess... well, at least that cleared that up anyhow.... ow well!!
02-27-2012, 06:47 PM | #8 |
Rep 322
Installed!
I installed these today. I picked them up off of Craigslist for $800! I mounted them on Dunlop Direzza DZ101s 235/40-18 on the front and 275/35-18 on the rear. No issues with rubbing with the H&R coilovers installed and no spacers required. Since I mounted these I will be putting my Advan TCIIIs up for sale, so look for those.
02-27-2012, 06:52 PM | #9 |
#dubspec
6344
Rep 5,201
Those look great! Glad your keeping the car...
02-27-2012, 10:46 PM | #12 |
Commander
221
Rep 850
Drives: Z4MC/M5/640iX/M1000RR
Those look great jthorst, do you have any closeups on the fronts ? The rears I'm not worried about but the fronts concern me since i like to run 245s up front. How much camber are you running to get no rub ?
02-28-2012, 07:25 AM | #14 |
Rep 5,329
wow...... i thought these would look good!!! BUT surely the fronts must rub, how much camber are you needing to run??? -2.6-7ish??
i dont know how on full compression with lock this wouldnt rub..... again would like to know your camber setup :-)
02-28-2012, 08:06 AM | #15 |
Rep 4,320
Drives: '07 Z4 M Coupe
Those look great!
02-28-2012, 10:23 AM | #16 | |
Rep 892
02-28-2012, 10:53 AM | #17 |
instagram 997turbotom
284
Rep 7,377
The Advans would sell better if they were a darker color. Gunmetal looks great on that red car
Beedub, don't you have a set of RAC or something custom wheels on order?
02-28-2012, 12:30 PM | #18 |
Rep 385
Wow, that looks super clean.
+1 on front camber specs. It doesn't look like it took all that much, the angle looks pretty conservative.
02-28-2012, 12:32 PM | #19 |
Member
17
Rep 178
I'm running an ET35 up front on my track wheels w/around -3 camber and it looks like I could easily get away with a 10" spacer. In fact, I may even try it tonight to see if it works. I ran a ET30 up front last year at the track and never had one rubbing issue (with camber bolts)
02-28-2012, 01:37 PM | #20 |
Rep 322
Albuquerque offers some crappy roads and some windy roads and I didn't get any issues with these at all. I have about -2.5 camber but I think the no issues is due to the 235s possibly. I insatlled 10mm spacers all around and they didn't need them and plus it looked very silly with them. Anyways I am quite happy with them and would recommend them to anyone.
02-28-2012, 01:38 PM | #21 |
Rep 322
Rated M, did you see these on ABQ Craigslist? I couldn;t beleive they were these cheap but I knew the guy and he sold them to me before he was going to hike the price up.
02-28-2012, 02:54 PM | #22 |
Rep 5,329
i do :-) mid summer they arrive :-)
