      10-27-2012, 04:58 PM   #1
Kgolf31
Kgolf31's Avatar
459
Drives: 2007 Z4MC, 2012 128i
4 Point Harness w/out Harness Bar?
Is there any mounting bolts that we can secure a 4-point harness to for Auto-x? A local was showing me his harness mounting bolt in his GT3 that he discovered and I didn't know if there was anything similar.
      12-01-2012, 10:43 PM   #2
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
I don't think there's such a mounting point for the Z4s. Maybe the child safety lock points on the passenger side might suffice, but it'd be kinda risky I think. Better to get an actual bar at the very least, if not a half to a full cage.
      12-02-2012, 08:50 AM   #3
Beedub
funny.... i was wondering this same thing.... i saw a 1M at my local event and he fitted some bolt down eyelets to the seat mount points and attached them their... im not sure if this is legal or not.
      12-02-2012, 02:16 PM   #4
mfanatic325
///M-fanatic
Taiwan
193
If we had back seats, we could potentially use the rear seatbelt receptacles as some form of mounting
      12-02-2012, 02:17 PM   #5
beta
Drives: 2006 M Roadster
From what I understand you should only run a 4-point if you have a cage.
Otherwise in a roll-over the 4 point will keep you upright into to the collapsing roof/windshield. The hack went into it a bit here.
      12-02-2012, 02:26 PM   #6
Beedub
no no no.... his bolted straight down to the floor, they looped over the tops of the seats and was bolted down to where the runners are bolted to the floor..... like i say, i have no idea if this is sufficient in terms of safety.
      12-02-2012, 02:38 PM   #7
Kgolf31
Kgolf31's Avatar
459
Yea, that's a no-go.
You need to maintain a certain angle in relation to the seat for the straps behind the seats
      12-02-2012, 11:57 PM   #8
mfanatic325
///M-fanatic
Taiwan
193
Yup, the two shoulder straps cannot pull downwards on you.
      12-03-2012, 03:36 AM   #9
007MCoupe
007MCoupe's Avatar
Drives: '18 Sakhir M3 ZCP
how much does a harness bar typically cost? a half cage?
      12-03-2012, 10:21 AM   #10
Kgolf31
Kgolf31's Avatar
459
The main reason I asked this, is that I need to maintain class rules for SCCA Solo.
      12-03-2012, 12:13 PM   #11
mfanatic325
///M-fanatic
Taiwan
193
For a custom harness bar only, you're looking at upwards of $350 for materials and labor. If you want a half cage, that'll probably bump up to $500. And for full cage, depending on bolt in or weld in, I wouldn't be surprised if it went all the way up to $1,500 or more; as there's lots of labor involved.
      12-04-2012, 03:26 AM   #12
SmartBastard
Stupid as shit
SmartBastard's Avatar
Austria
25
Drives: '08 M Coupe
Hmm I newer looked into this so spare me some slack if this is a retarded idea, but couldn't you just get a rear strut bar and mount the harness there? Or is the rear strut bar not strong enough for that?
Can't find any Z4M rear strut bar, but what I mean is smth like this:
      12-04-2012, 04:01 AM   #13
mfanatic325
///M-fanatic
Taiwan
193
I suppose that might actually suffice as a shoulder strap bar. However, one would need to strip out everything behind the seats in order to get at the bar. Also, there's still the issue of the angle of the shoulder straps to where it's actually wrapped around/mounted. But interesting thought process there. I've never thought of using a rear strut bar for such a purpose
      12-04-2012, 10:54 AM   #14
AUTOX08MC
AUTOX08MC's Avatar
Drives: 16 M4
I believe a full roll cage, or partial roll cage/bar is permitted in any class of SCCA autocross.
2016 BMW M4 MW 6SPD,2005 Honda S2000
2014 Subaru STI (Sold),2008 BMW Z4 MC (Sold)
2012 VW GTI (Sold),2006 Subaru STI (Sold)
2003 Subaru WRX (Sold),1996 Mustang Cobra (Sold)
1986 Dodge Shelby Charger (Sold)
      12-04-2012, 12:15 PM   #15
Kgolf31
Kgolf31's Avatar
459
I will have to check, but I'm almost positive not.
You increase the stiffness of the chassis.
      12-04-2012, 12:49 PM   #16
AUTOX08MC
AUTOX08MC's Avatar
Drives: 16 M4
From the rulebook:
3.3.2 Roll Bars
Roll bars or roll cages are strongly recommended in all cars.
