06-28-2012, 02:23 PM | #1 |
New Lifetime Replacement Policy
821
Rep 11,738
:: ECS Tuning :: ECS 6-Piston Big Brake Kit E85/E86 2.5i and 3.0i and E36/7 Non-M
Big. Honkin. Brakes. If that's what you want, we have what you need. Our Big Brake Kits are back in stock and ready to ship. The features list for these beauties is too long to fit here, so why not click through and check out the details. We can tell you that this set is way too handsome to hide behind wheels, bolts on easily with common hand tools, and stops as good as it looks. Check 'em out, and order your set before they're gone! Click HERE to order!!! Click HERE to skip a step of the ordering process Last edited by ECSTuning; 07-02-2012 at 09:41 AM.. |
06-29-2012, 08:48 AM | #5 |
821
Rep 11,738
Nothing for the M..... The brakes on the M are already pretty righteous, so developing a kit which out preforms them without destroying the balance of the breaking system takes a good bit more time and effort.
06-29-2012, 09:10 AM | #7 |
Rep 12,570
no rear kit available but if they did, then i'd consider it since bias would be maintained. i think shifting more bias to the front would cause more understeer.
06-29-2012, 09:48 AM | #8 |
Rep 4,531
06-29-2012, 12:27 PM | #9 | |
Rep 892
CURRENT ll F10 M5 l E85 Z4MR l I01 i3 REX SOLD ll E70 X5M l E85 Z4MR VF570 l E36/7 Z3MR l E36 328i |
06-29-2012, 01:05 PM | #10 |
Rep 4,531
06-30-2012, 01:52 PM | #12 |
The Wrapgician
47
Rep 354
Drives: z4si
even e46 330ci, z4 3.0i M54/N52, z4 3.0si N52 has sme front end set up and using same king pin but ECS claim that this kit wont fit 3.0si. which is why I havnt put my money on it... any idea they will fit 3.0si?
07-02-2012, 09:59 AM | #13 | ||||
821
Rep 11,738
Guys make sure you're wheels will clear the BBK, some people have noted needing 5mm spacers to clear the calipers. HERE is a template we have that you can print, cut out, and use on your wheels to see if the rotors and calipers will clear the spokes and barrels. Last edited by ECSTuning; 07-02-2012 at 10:10 AM.. |
07-02-2012, 10:59 AM | #14 |
Rep 12,570
3.0si shares same fronts as e46 330i/ci
3.0i shares same fronts as e46 non-m, non-330 |
07-03-2012, 09:05 AM | #16 | |
821
Rep 11,738
07-31-2012, 08:29 AM | #18 |
821
Rep 11,738
07-31-2012, 09:44 AM | #19 |
Rep 12,570
If 17's fit, then 18's with same offset and width would definitely fit. The question is width and offset though...
07-31-2012, 09:49 AM | #20 | |
821
Rep 11,738
Spoke design has a lot to do with wheel fitment as well, not all wheels of XX offset are designed equally. That's why I suggest printing out the pdf found HERE to scale, and using it to double check your clearances. |
11-08-2012, 03:57 PM | #21 |
821
Rep 11,738
11-09-2012, 08:12 AM | #22 |
Mechanical Engineer
96
Rep 1,025
Holy cow that is a good price.
Another person in for an M kit. Could you make an M kit that uses those calipers with the stock rotors? Just calipers, modified carriers, pads, and hardware? And maybe a well matched rear pad to keep the bias in check? |
