      08-07-2012, 08:18 AM   #1
dsgrillot
dsgrillot's Avatar
Drives: 2008 Z4M Roadster
M3 wheels on a Z4M?
Hey Guys,
Will stock E90/92 M3 size wheels fit our cars with no problems?
F: 245/40 18x8.5, ET29
R: 265/40 18x9.5, ET23
M School
      08-07-2012, 08:30 AM   #2
Beedub
ive actually tried a set on the car.... they need -2.5ish camber up front to make sure their is no rub on the outer fender, without the camber they stick out on the front massively and im guessing would rub significantly.
      08-07-2012, 08:56 AM   #3
v3.2mc
Not a New Member
v3.2mc's Avatar
2007 ///M Coupé  [10.00]
a quick search found these...
http://www.zpost.com/forums/showthread.php?t=696300
http://www.zpost.com/forums/showthread.php?t=460759
http://www.zpost.com/forums/showthread.php?t=641664
      08-07-2012, 05:43 PM   #4
Daemonblitz
Commander
Daemonblitz's Avatar
221
Drives: Z4MC/M5/640iX/M1000RR
2008 BMW M5  [9.50]
2006 Z4M Coupe  [8.77]
2010 BMW S1000RR  [10.00]
On stock suspension/camber settings you will rub.
I am currently lowered on H&R Springs & max camber I can get up front is -1.2, I am getting very minor rubbing on the outer edge of the front fender liners where the bumper meets the fender and my bumper is a little bit more "stretched out" than stock.
If you try to run these wheels on stock suspension you will probably rub just enough to push the bumper out of its clips where it meets the fender (behind the headlight) and over time cause the clips to break.
