      07-04-2012, 06:55 PM   #1
Karacticus
Karacticus's Avatar
Drives: 2007 Z4 3.0si Coupe
Wheel center cap removal
Has anyone found a good tool for removing the wheel center caps without removing the wheels first?
I've got lots of picks, but they scratch the caps when they slip. Some kind of suction device would appear to be ideal, but I haven't found a suitable one in the 1 1/2" size that would appear best suited.
2007 3.0si Coupe
Dinan Stage I Suspension (Shocks, Struts, Springs), Ground Control Front Camber Plates, Treehouse Racing Front Control Arm Bushings, RTAB Bushing Limiters
      07-04-2012, 07:06 PM   #2
GammaZeta
Drives: 1
YES! I just did this yesterday.
I used two methods:
1. Get a good suction cup, something like you find in the shower that really sticks on hard. Apply and pull. Check in the shower aisle where the shower caddys are in your Target or Walmart. The one you tried using was probably a regular arts and craft one. Get one that flips down to add extra suction, almost like a double suction cup in one. I had one in my shower already.
2. If you do NOT plan on keep the caps and are replacing them, drill a screw into the middle just a little bit, enough for grip. Grab a pair of pliers and yank it off.
BTW, the new style caps for our Z4Ms are on sale for like $60 shipped at ECS. The new styles look so much better than the old ones. Worth the $60 bucks.
      07-05-2012, 08:18 AM   #3
SCHMOUPE
SCHMOUPE's Avatar
Drives: 2007 Z4M Coupe
2007 Z4M Coupe  [0.00]
http://www.ecstuning.com/BMW-Z4-M_Co..._Caps/ES65747/
The Raspinator
      07-05-2012, 09:34 AM   #4
Karacticus
Karacticus's Avatar
That looks like a paint can opener, except when I used to get those for free from the hardware store, the handle end incorporated a bottle opener!
I think I still may have one or too of those laying around-- I'll see if I can find one and see how it works.
2007 3.0si Coupe
      07-12-2012, 12:15 PM   #5
Karacticus
Karacticus's Avatar
Problem solved-- these work great, at least on the new type center caps
http://www.oxo.com/p-1128-stronghold...-hook-set.aspx
2007 3.0si Coupe
