06-24-2012, 07:43 AM | #1 |
Rep 1,351
Drives: in Anger.
Setup with 19" Sportlines, spacers, studs and H&R springs.
Hey all,
Just want to bounce a set up idea off of you all. Sportlines CS.16 19x8.5 ET35mm 19x9.5 ET22mm 245 front 275 rear 12mm spacers all around 75mm studs H&R sport springs Do we need spacers all around or what is pretty common for an aggressive street setup. Thank you in advance JHLC
AFE Intake/Euro Cats/CSL Headers/Sportline CSL/H&R Springs 1217/1815 !!! BOILER UP !!! |
06-24-2012, 09:23 AM | #2 |
Rep 820
Drives: 2007 Z4MR silver grey
That offset/rim width should get you pretty close to flush with no spacers IMO. Using the wheel offset calulator, you pick up another 13mm in the front and 14mm in the back in outside extension with this setup............... 12mm spacers and you'll be too wide. If you want an idea of how this size will look "as is", check out the Apex EC-7 thread in this section. They have coupe pics in this exact offset size (using 18" rims).
John |
06-24-2012, 01:12 PM | #3 |
#dubspec
6331
Rep 5,201
the specs you posted are perfect
06-24-2012, 03:27 PM | #4 |
Rep 1,739
Drives: 2008 Z4MC
I wouldn't run spacers with what you've mentioned. Make sue to dial in your camber property and you'll be set!
06-24-2012, 05:21 PM | #5 |
Rep 1,351
Drives: in Anger.
but will the studs stick out??? I would like for them to be flush.
06-24-2012, 08:04 PM | #6 | |
Rep 820
http://www.zpost.com/forums/showthread.php?t=486554 Order the 57mm since you will not be running spacers, should fit AND accept a closed end nut if you want John |
07-18-2012, 10:19 PM | #7 |
Rep 1,351
Drives: in Anger.
You all as usual were right!
08-08-2012, 05:04 PM | #8 |
Rep 146
Id skip the 12mm spacer in the et22 rear. Its just too much unless you are running more than -2.5deg camber. The front 12mm spacer on the et35 works great, if you have aggressive camber settings ~-3deg.
08-08-2012, 06:08 PM | #9 |
Rep 1,351
Drives: in Anger.
Thanks for the response. You couldnt be more right. I have the wheels on with no spacers or adjustments and they fit like an agressive factory setup.
08-08-2012, 06:28 PM | #11 |
#dubspec
6331
Rep 5,201
post pics
08-08-2012, 07:10 PM | #12 |
Rep 820
08-08-2012, 07:25 PM | #13 | |
701
08-08-2012, 08:51 PM | #14 |
Rep 4,531
