08-07-2012, 08:18 AM | #1 |
Rep 83
M3 wheels on a Z4M?
Hey Guys,
Will stock E90/92 M3 size wheels fit our cars with no problems? F: 245/40 18x8.5, ET29 R: 265/40 18x9.5, ET23
M School |
08-07-2012, 08:30 AM | #2 |
Rep 5,327
ive actually tried a set on the car.... they need -2.5ish camber up front to make sure their is no rub on the outer fender, without the camber they stick out on the front massively and im guessing would rub significantly.
08-07-2012, 08:56 AM | #3 |
Not a New Member
94
Rep 925
a quick search found these...
http://www.zpost.com/forums/showthread.php?t=696300 http://www.zpost.com/forums/showthread.php?t=460759 http://www.zpost.com/forums/showthread.php?t=641664
08-07-2012, 05:43 PM | #4 |
Commander
219
Rep 850
Drives: Z4MC/M5/640iX/M1000RR
On stock suspension/camber settings you will rub.
I am currently lowered on H&R Springs & max camber I can get up front is -1.2, I am getting very minor rubbing on the outer edge of the front fender liners where the bumper meets the fender and my bumper is a little bit more "stretched out" than stock. If you try to run these wheels on stock suspension you will probably rub just enough to push the bumper out of its clips where it meets the fender (behind the headlight) and over time cause the clips to break. |
