      02-07-2010, 06:20 PM   #1
blender
Custom User Title
blender's Avatar
Drives: black
powder coated Ultimate Pedals installed
I sprung for the pedals and found a local shop to Powder Coat them in flat black. The rest of the car is triple black and the natural aluminum color was too "bright" for my taste. Overall very pleased... heel and toe [side-to-side?] is much easier.
FYI this is a Mason Engineering clutch pedal [E46M3 model] which provides a much more positive feel and a very short ~4" throw. It sits deeper in the footwell, so it looks smaller in the photos. The pedals are identical.
Here are the pics:
Some install tips I begged from others:
  • Pre-paint screws if desired, they can dry while you drill the holes.
  • Mark holes in advance with a white grease pencil, silver paint marker or similar [ i covered the underlying pedal with blue painters tape for drilling]
  • Accel and footrest pedals screw down on top of the existing plastic gas/footrest, using qty-4 ea. medium diameter sheet metal screws. Easy.
  • Brake and Clutch must be drilled out, different diameter bolts with nuts & washers. Make these holes over-sized for fine position adjustments. These are tough steel, recommend pre-drilling with small diameter high-grade bit first [or dremel]. 4x bolts each provided.
  • Note the diameter of the bolts requires a larger a hole than the threaded screws above---So Do NOT pre-drill everything with the same bit, or the threads won't grab.
  • Put down a newspaper or a rag in the footwell to catch the many shards of steel from the drilling. Do NOT jam these into your fingers. A magnet cleans these up nicely too.
      02-07-2010, 07:58 PM   #2
jra
Drives: 2005 z4
looks awesome. do you have black wheels?
      02-07-2010, 09:03 PM   #3
Incompatible
Drives: 07 AW Z4C 3.0Si
They do look good, although I don't know how durable the powder coating will be. Keep us informed. Thanks
      02-08-2010, 09:51 AM   #4
onelove
Track Head
onelove's Avatar
Drives: 07 Z4M
Where did you purchase the pedals from ? Would like to look into getting a set, a much needed upgrade in the coupe.
      02-08-2010, 10:19 AM   #5
Incompatible
I assume they relocated the pivot point and would expect a slightly heavier (good thing) and faster (shorter as noted) engagement. Any problems with the clutch-in disconnect switch for the starter?
      02-08-2010, 12:54 PM   #6
blender
Custom User Title
blender's Avatar
Drives: black
Ultimate Pedals website link
http://www.ultimatepedals.com/catalog/index.php
      02-08-2010, 01:22 PM   #7
blender
Custom User Title
blender's Avatar
Drives: black
Re: clutch pedal
Correct. No problems with starter, you just have to *fully* depress the clutch to get it to light up. I have a replacement left knee and this pedal makes driving a standard transmission pain-free & enjoyable. Factory clutch pedal felt "wobbly" and required a high lift to cover the clutch. The Mason is worlds better.
      02-08-2010, 01:46 PM   #8
Incompatible
Thanks for the info, This is something I need to look into. Any difficulties swapping over?
      02-08-2010, 08:27 PM   #9
blender
Custom User Title
blender's Avatar
Drives: black
No fitment problems. Here is the Mason E46 Clutch pedal, which sits about 4" deeper in the foot-well.
Attachment 347815
and a link to the website. John is a real pro. I suggest emailing him about the clutch from the website.
good luck.
RC.
      01-14-2011, 05:31 PM   #10
blender
Custom User Title
blender's Avatar
Drives: black
Update - Eleven months later, still looking good.
Update - to show the durability after ~15K spirited miles.
The pedals still look very good, got a bit of wear on the edges of the brake & clutch pedal. I suppose I could paint that over if I really wanted them to look prisitine. But I want people to see I drive this beast
low-res iphone picture, but you get the idea.
Attachment 474887
      01-14-2011, 05:43 PM   #11
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
probably time to clean them
      01-17-2011, 05:10 AM   #12
Samjam927
The One And Only
Samjam927's Avatar
15
Drives: 2006 TiAg ///M Roadster
2006 Z4M Roadster  [10.00]
2003 Z4  [5.00]
Those look sick!
Tags
accelerator, clutch, pedals, ultimate pedals
