      10-17-2012, 09:51 PM   #23
Geauxkart
Geauxkart's Avatar
13
Drives: 2007 Z4 M Coupe Sepang
The length was close but doable, no doubt. I did the welding and fab myself, and I take my time and "do it right" per many hours of research. (All SS bungs / fittings / filler rod too!)
Yes, I have an OBDII scanner and it's clear.
      10-17-2012, 10:27 PM   #24
beta
Drives: 2006 M Roadster
Interesting.....
Since you ran headers w/o a tune for a while.
Did you find the the tune made a significant difference ?
Honestly, it was noticeable, but not a huge change. Unfortunately I didn't do before/after dynos like I should have; work was crazy busy at the time. The stock DME can do a lot of adapting on its own. Should be about as big a change as gferil's dyno that he posted today.
Originally Posted by JeffchaPz View Post
Anyone knows if we can buy post/down stream O2s with 4-5 feet of wire? this way we won't have to cut them? Then again if a tune can fix the problem then I rather put the $$ towards the tune.
How much is a tune that can fix that problem now days?
Look in crfine88's build thread. He actually explains how he built extenders, best solution IMO. Your other option is to buy euro O2s (which are longer), but you need to get those from europe and they're expensive.
      10-18-2012, 12:10 AM   #25
johanness
Drives: 2008 Z4MC
Who's tune are you running? I felt a big difference running my ESS 93oct tune. I was running headers/no tune for months and it was great. Extra power - fun.
But there was a definite change in the way the car pulls from 4500rpm++ when I got the tune (on top of headers). Cracks open so to speak.
AJ @ ESS is a master IMO
      10-18-2012, 06:54 AM   #26
kennyfrc
kennyfrc's Avatar
18
Drives: 2008 Z4MC
OP,
Microscopic leaks can cause O2 sensor voltage to go low. These are usaully found at the bung welds. If your voltage is too high I suspect a failed sensor or wiring issue.
Daily: 2010 Tacoma Double Cab
      10-18-2012, 06:59 AM   #27
SCHMOUPE
SCHMOUPE's Avatar
Drives: 2007 Z4M Coupe
2007 Z4M Coupe  [0.00]
Originally Posted by kennyfrc View Post
OP,
Thanks for your input confirming my hunch.
The Raspinator
      03-30-2013, 06:55 PM   #28
SCHMOUPE
SCHMOUPE's Avatar
Update: after a few times clearing the codes, my codes disappeared and I was able to pass state inspection today. Without getting too much ahead of myself, I think my car learned how to "fix" itself. Bow down to German engineering!!!
The Raspinator
      03-30-2013, 07:35 PM   #29
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
2006 Z4MC - #LL93158
      04-01-2013, 11:12 PM   #30
JeffchaPz
JeffchaPz's Avatar
16
Drives: 2007 Z4M
SCHMOUPE - how long or how many miles did you drive to make sure the ECU was ready for inspection. I know you cannot just clear the code and drive to the inspection place the same day.
Last night I replaced both of my O2 Sensors after cutting the original ones to extend them to the back on the section 1 .
However, I didn't clear the code, I'm hoping the car will noticed the change and turn off the SES light.
      04-02-2013, 12:50 PM   #31
SCHMOUPE
SCHMOUPE's Avatar
Every time you reset the codes, you need to go through an OBD II drive cycle which is typically 20-30 miles driving at different speeds and RPMs in different gears. Once you do this the monitors go from not ready state to ready.
The trouble I was having initially was that as soon as my monitors would become ready, the SES or the pending fault would come back. I think overall it took my 4-5 cycles to get rid of it. Mind you, I did the O2 relocation in October/November and my car has been in the garage most of the winter and it was driven once every few weeks.
The Raspinator
      04-02-2013, 01:30 PM   #32
beta
Not to be the bearer of bad news, but make sure you put it on a dyno that can read AFR. You need to make sure things are actually ok, and not that the car adapted to the bad conditions, giving you lower than expected performance.
      04-02-2013, 02:05 PM   #33
SCHMOUPE
SCHMOUPE's Avatar
Not to be the bearer of bad news, but make sure you put it on a dyno that can read AFR. You need to make sure things area actually ok, and not that the car adapted to the bad conditions, giving you lower than expected performance.
Just wondering, how would a bad rear O2 sensor decrease performance?
The Raspinator
      04-02-2013, 02:35 PM   #34
beta
Read this excellent PDF I found on the m5 board. At the very end of the document it goes into the rear O2s.
      04-02-2013, 08:35 PM   #35
SCHMOUPE
SCHMOUPE's Avatar
Interesting. Thanks for sharing
The Raspinator
Search this Thread:
Advanced Search
