12-20-2012, 10:13 AM | #155 |
Rep 12,565
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.22] |
Check with the guys at Apex, all those wheel fitments were on stock suspension so you may be able to get away without camber plates. But if you used those fixed plates I was referring to, your tire wear wouldn't be excessive. In fact I think I may have had less than 1.8*, maybe closer to 1.5* which is totally streetable.
01-07-2013, 07:37 PM | #156 |
Rep 258
This is a great thread. Buying a new set of wheels is more involved than I would have guessed, especially since I'm trying to keep a stock look.
03-25-2013, 03:06 PM | #157 |
Rep 45
Hello all,
I need help deciding what tires to get. I have 2.5i non sport with Apex arc-8, 18x8.5 et38 with Hankook ventus V12 225/40/18 up front, on the rear I have 18x9 et42 with V12's 255/35/18. When I first got them, I had a stock suspension. I recently installed a set of H&R street performance coilovers. There is no rubbing with this set up. But the tires just look too skinny for my liking. I'd like to replaced the tires with meatier looking tires to fill in the wheel well. I'm considering for the front 235/40/18 or 225/45/18. for the rear 265/35/18 or 255/40/18. Any thoughts or suggestions? Thanks Last edited by lrcigar; 03-27-2013 at 08:20 AM.. |
03-26-2013, 03:06 AM | #158 |
Rep 509
235/40 on 8,5 is perfect. I think 265/35 also would look good on 9". A nice meaty look.
My Hellrot '06 BMW Z4 3.0si Coupe and My Mineral Grey '14 F30 (sold) New daily: Sunset Orange 330E G20 Instagram: @StigJ77 & @bmwe86driver |
03-29-2013, 12:45 PM | #159 |
Rep 45
03-29-2013, 01:58 PM | #160 |
Rep 12,565
235/40 may rub up front with 38 offset.
03-29-2013, 09:23 PM | #162 |
Rep 12,565
No, spacers if anything might worsen it. Spacers will push the wheels out, and would only be helpful if you were rubbing against the inside, ie the suspension parts.
Your issue with a 235/40 on 8.5" and 38 offset is that 1) the wheel is sticking further out than it normally would 2) the 235/40 tire is 1/3rd" TALLER than a 225/40 I think it'll rub because I once ran a style 197 (oem sport wheel off the e90 328i) and that had a 8" front and high 30 offset. I too ran a 235/40-18 and I rubbed against the outer fender liner, right by the sidemarker. So given that you're running a rim that's 0.5" wider, I would think you'd encounter the same issue. I would stick to a 225/40-18 up front and 255/35-18 in the rear. It'll look a tiny bit stretched but nothing to be overly concerned with. If you're set on running a 235/40, adding negative camber may help. |
03-31-2013, 09:57 AM | #163 | |
Rep 45
04-19-2013, 01:44 AM | #164 |
Rep 6
Hi all
Planning to get new wheels and like the wide look.. I have found following: 8,5x19 et38 10x19 et33 I believe it will work if i run 225/35 and 235/35 ? Got the m-tech chassi... But like an additional drop. What you think ? |
04-27-2013, 04:41 PM | #166 | ||
Rep 1,530
04-29-2013, 01:13 PM | #167 |
Rep 45
I decided to take a chance and went ahead got 235/40 front, and 256/35 rears. Raised the coilovers 3/4" front and 1' rear. I'm very happy with the look. and no rubbing at all.
05-03-2013, 07:37 AM | #169 |
Rep 1,530
05-03-2013, 09:19 AM | #170 |
Rep 12,565
Just becareful the running isn't noticeable at first (not static) but develops over time as you drive the car, go over bumps, turn full lock, etc.
05-04-2013, 03:35 PM | #171 |
Rep 45
05-04-2013, 03:38 PM | #172 |
Rep 45
05-12-2013, 07:41 PM | #173 | |
Rep 1,530
Can anyone else recommend a reliable place?
05-16-2013, 03:48 PM | #174 |
Rep 45
I got the wheels from apex, and the tires from tire rack. I took the car to precision auto works in long island city, NY. They also had installed my coilovers, and made the final adjustments.
05-28-2013, 10:06 PM | #175 |
Rep 415
Drives: 2005 z4 3.0
thanks for all the info everyone, really useful. With summer just around the corner,I'm starting to search for wheels as my rubber likely won't last till the fall (my 108's have some kerbing from the PO and fixing them is almost as much as a new set of wheels) So I figured I'd step up to 19s. So I'm looking into sizing them correctly etc.
Thing is, I'm not sure what different suspension geometries are around, some people talk of zhp and sport suspensions, but I'm not sure what identifies either on the car. I think I'm running stock although my car does have the sport and premium packages if that makes a difference. Is there a simple way for me to check what suspension I have ie go measure under bumper and it should be x inches high off the ground kinda thing? Any ideas?
2005 Z4 3.0 steptronic | TiSilver on Black | sport & premium package | 108s | Msport seats | wind deflector OMP strut bar | blacked out emblems | de-french-fried | sound gen | DIY aux input | custom speedo logos | stubby antenna | polished exhaust tips |
05-29-2013, 04:25 AM | #176 |
Rep 1,546
I'll be getting new wheels in the near future and I came across this site in my searches:
http://www.tuneruniversity.com/blog/...n-performance/ Read through parts 1 and 2 as well, but part 3 relates to width specifically. There's also a calculator he provides here that you can type in wheel and tire sizes you're thinking about and see if they'll fit. Don't know if anyone else has ran across this site, but it's super good info!
