      11-14-2013, 09:02 AM   #45
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Originally Posted by David70 View Post
At what point is 15W50 better than 5W50 when it comes to adequate lubrication? From your second response above, best I can tell is the 5W50 may not be needed but why wouldn't you prefer it?
Also, why did you go with Redline 15W50 over the Redline 10W60? Seems like 10W60 would be the normal choice, any data to back up 15W50? You said lower operating temperature but wasn't this at the same time of changing weights and brands of oil? Just curious.
Some tiny amount better mpg makes no difference to me compared to a little less bearing wear.
in a nut shell TWS shears down to close to a 50 weight and Redline 60 holds up much better.
So in effect the 60 weight redine ends up being a little too heavy.
I have used & tested both.^
as a result will be changing to Redline 50 weight next year.
      11-14-2013, 11:48 AM   #46
David70
You tested Redline 60 and Redline 50? How did you test it?
      11-14-2013, 01:02 PM   #47
ricanbandit
ricanbandit's Avatar
29
Drives: 2011 30i
So gents I am about to do my first oil change (myself) I usually just take it to an indy and or dealer as I still have one year on the extended service plan and do the regular TWS 10w60. Now that I have a garage, figured just how hard could it be.
That being said... What should I use? I have changed the oil religiously every 5K miles ever since I got the car with 7100. I don't track it, daily driver with about 39500 on it now with 70% highway miles. Should I go with the 15w50 or stick with the TWS 60? I currently live in DC and am new to the area, but it is not as cold as CT and the 10w60 was used there.
BTW read the whole thread, just want your more experienced opinions.
2011 30i
[SIGPIC]/SIGPIC]
      11-14-2013, 02:50 PM   #48
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
No... TWS 10W60 & Redline 10W60.
Sample test at oil change.
      11-15-2013, 07:03 AM   #49
David70
It seems like some are going to 50 but I haven't seen any data to back this up. Interested in seeing it if anyone has it.
