03-28-2013, 12:08 PM | #1 |
Rep 308
Where to get Techron fuel treatment in Toronto?
Does anyone know where to get Techron fuel system treatment?
I've tried look for one from CT with no success. |
03-28-2013, 01:36 PM | #2 |
Rep 11,667
Its not available here.
you can buy the OE stuff from the stealer, which IIRC is rebranded Techron. I ended up using the Lucas product.
03-28-2013, 04:40 PM | #4 |
Rep 11,667
IIRC its in the maintenance manual (I think)
Jus to keep things clean.
03-28-2013, 06:08 PM | #5 | |
M = Midlife Crisis
65
Rep 2,006
I'm using the Redline SI-1 now. I gave you a bottle too Ian? http://www.redlineoil.com/product.aspx?product=60103
2006 Z4MC - #LL93158
03-28-2013, 06:11 PM | #6 | |
Rep 11,667
03-28-2013, 06:52 PM | #8 |
Rep 11,667
Ill run one through this spring & that'll be it for the year.
03-28-2013, 07:00 PM | #9 |
Rep 415
Drives: 2005 z4 3.0
is this an M-specific thing or should i be doing this too?
2005 Z4 3.0 steptronic | TiSilver on Black | sport & premium package | 108s | Msport seats | wind deflector OMP strut bar | blacked out emblems | de-french-fried | sound gen | DIY aux input | custom speedo logos | stubby antenna | polished exhaust tips |
03-28-2013, 07:14 PM | #10 |
M = Midlife Crisis
65
Rep 2,006
It's just a routine maintenance thing. I stored the car with a full bottle this winter. I general for me its a once a year thing because I only put 4-5K on per year.
03-28-2013, 07:15 PM | #11 |
M = Midlife Crisis
65
Rep 2,006
I use it in all my cars...
03-28-2013, 08:08 PM | #12 | |
Rep 832
03-28-2013, 08:20 PM | #13 |
M = Midlife Crisis
65
Rep 2,006
The last order was from TMS; however I think Precision Tuning has it or can get it...
03-28-2013, 08:45 PM | #14 | |
Rep 12,565
http://www.zpost.com/forums/showthread.php?p=13721361 |
03-28-2013, 11:19 PM | #15 |
Rep 415
Drives: 2005 z4 3.0
apparently Lordco (don't think they exist outside BC though) sells redline stuff will check tomorrow if they stock it and report back
03-28-2013, 11:41 PM | #16 | |
Rep 2,866
03-29-2013, 07:22 AM | #17 |
M = Midlife Crisis
65
Rep 2,006
Don't you have Chevron Fuel Stations in BC?
03-29-2013, 07:43 AM | #18 | |
M = Midlife Crisis
65
Rep 2,006
82 14 0 413 341 Direct from BMW, TIS Technical Bulletin #13 05 06: SITUATION Recent field experiences have shown a significant increase in various drivability complaints due to excessive carbon deposits in engine's combustion chambers, on the intake valves and fuel injectors. The overall rise in carbon deposits accumulation is generally attributed to poor gasoline quality, namely, low level of cleaning additives and fuel contamination. TECHNICAL BACKGROUND Combustion chamber deposit formation is a by-product of the gasoline burning process. Fuel injector and intake valve deposits may become less troublesome with the recently introduced Top Tier Detergent Gasoline deposit control standards, which are exceeding the detergent requirements imposed by the EPA since 1995. However, vehicles that do not exclusively use a Top Tier Detergent Gasoline, or are regularly driven in severe service conditions, such as stop-and-go traffic, high ambient temperatures, and high altitude can experience performance problems caused by intake system and combustion chamber deposits. RECOMMENDATION BMW recommends using TOP TIER Detergent Gasoline of minimum octane rating of AKI 91 and with alcohol content of less then 10% by volume (or any other oxygenates with up to 2.8% of oxygen by weight). Only the exclusive usage of TOP TIER Detergent Gasoline provides the full benefit of reducing deposits formation. For more information related to TOP TIER Gasoline refer to SI B13 02 06. If the TOP TIER Detergent Gasoline is unavailable, we recommend BMW Group Fuel System Cleaner Plus (PN 82 14 0 413 341) be added to the gas tank. For optimum cleaning and deposits control, add a 20 fl. oz. bottle every 3,000 miles when refueling. Regular use of BMW Group Fuel System Cleaner Plus can help address carbon deposits related symptoms listed above. By removing these deposits, an engine may experience restored power, performance and fuel efficiency, a smoother idle running, lower emissions, and reduced octane requirement. BMW Group Fuel System Cleaner Plus uses polyether amine TECHRONŽ based technology developed and patented by Chevron. BMW Group Fuel System Cleaner Plus has proven to clean up deposits in fuel injectors, ports & intake valves and reduces the harmful effects of combustion chamber deposits. It helps restore performance lost due to deposit build-up. Chevron and BMW have run an extensive "no harm" tests with polyether amine technology. When used as directed, it will not harm catalytic converters, oxygen sensors, or any other mechanical components of the engine, or fuel delivery system. The effectiveness of the additive depends on its presence in the gasoline in large concentrations for short periods of time. One treatment is usually sufficient, but a second treatment (one 20 oz bottle per each, consecutive full tank of gas) may give additional benefits. To keep your fuel intake system clean, we recommend usage at every 3000 miles. Additionally, vehicle's fuel sending units equipped with silver plated resistor card/contacts are especially vulnerable to attacks by elemental sulfur and/or hydrogen sulfide found in fuels. Adding BMW Group Fuel System Cleaner Plus immediately upon noticing erratic fuel gauge behavior may, in many cases, restore proper performance due to the additive's ability to remove the harmful sulfur compounds from the sending unit's contact surface. Additionally, BMW Group Fuel System Cleaner Plus can help protect the fuel gauge from future malfunctioning by coating all metal surfaces of the fuel system. BMW Group Fuel System Cleaner Plus. PN 82 14 0 413 341, 1 bottle, 20 fl. oz.
03-29-2013, 07:50 AM | #19 |
M = Midlife Crisis
65
Rep 2,006
Must have been a short period where they were working out the licensing and packaging when it was unavailable. The new packaging has "Techron" on the label and references Chevron.
03-29-2013, 08:22 AM | #20 |
Rep 832
Interesting TIS. I had wondered if they weren't recommending it for when using lower grade fuels. ALL I put in my car is PetroCanada Ultra 94 so I am probably good without the additive. Might not hurt to run a bottle through every year or two but I'm not going to stress about it.
03-29-2013, 08:45 AM | #21 |
Rep 307
Mike one thing to keep in mind with PetroCan Ultra 94 is that it's still 10% ethanol. If you want a fuel without ethanol added your only choice (AFAIK) is Shell 91, all petrol no ethanol.
03-29-2013, 10:08 AM | #22 |
Rep 11,667
I also avoid the petro 94.
