      08-22-2016, 01:15 PM   #1
3GFX
3GFX's Avatar
Drives: 2003 BMW Z4 3.0i
Gains gains gains...
The majority of my search for power has been largely sad and discouraging. I have an M54B30 motor in a 2003 Z4. I can say that I am actually happy with my finals results after much contemplation on if I should do any modification at all.
My mods consist of catless headers, Dinan muffler, panel filter and a Eurocharged tune.
My stock crank hp was listed from BMW as 225. I dyno'd at 229 wheel and the ecu was still adjusting. with simple loss correction I'm making roughly 270 crank. I mostly notice the correction of power delivery under 2500 rpm.
I would recommend headers and a Eurocharged tune all day.
Dyno attached only shows gains after tune. I don't have a dyno pre-headers and filter.
      08-26-2016, 09:25 AM   #2
Taskmaster
Japan
2465
Drives: M235i 6MT / E92 328 Msport 6MT
Those are healthy numbers, but you're leaving some power on the table - a good exhaust, intake and underdrive accessory pulleys (as well as a mechanical fan delete) can really put you over the top with extra power everywhere and no downside. Expect an additional 10whp+ PEAK when all those are done.
3GFX722.50
      08-26-2016, 10:32 AM   #3
3GFX
3GFX's Avatar
Where can I find more information on the fan delete?
Can you recommend a thread?
      08-26-2016, 10:48 AM   #4
Taskmaster
Japan
2465
Does your car have a mechanical fan? (I looked it up, it looks like it doesn't)
Here is my "build" on my M52TU with dynos. The M54 is almost the exact same motor:
http://forum.e46fanatics.com/showthr...546&highlight=
Here is the dyno thread I made for M52tu/M54 Motors:
http://forum.e46fanatics.com/showthr...715&highlight=
