      07-14-2016, 10:46 PM   #1
Bossdog
Bossdog's Avatar
27
Drives: 2006 Z4MR Imola Red
Z4M Clutch slipping
What is a CDV?
      07-14-2016, 10:53 PM   #2
N55_Mike
N55_Mike's Avatar
Drives: 135i, Z4MC, MK7 GTI
You can go with this kit, seems reasonable.
https://www.turnermotorsport.com/p-8...FVBbfgod-wcClA
      07-15-2016, 01:56 AM   #3
Westersund
Westersund's Avatar
Sweden
499
Drives: BMW
Did you drive it with the sport button activated? If you did, DON'T! That thing will mess up the clutch fast in combination with the CDV (Clutch Delay Valve) if you do some spirited driving/Auto-X.
LuK is an OEM supplier and they make quality products.
      07-15-2016, 04:28 PM   #4
Bossdog
Bossdog's Avatar
27
I do not use the sport button and recently removed the CDV. However, as I said, I just acquired the vehicle.
      07-15-2016, 04:32 PM   #5
Bossdog
Bossdog's Avatar
27
From what I have read, the lightweight flywheel is pretty noisy. I really do not want to add additional noise.
      07-15-2016, 05:48 PM   #6
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
There are driveability issues as well.
      07-16-2016, 09:38 AM   #7
N55_Mike
N55_Mike's Avatar
Oh okay, good to know!
      07-16-2016, 09:51 AM   #8
gmd2003
gmd2003's Avatar
352
There are destroying your motor issues as well lol .
      07-16-2016, 12:03 PM   #9
pungo
pungo's Avatar
It seems very few miles to need a new clutch???
I don't have any suggestions for replacement parts, but you're right, that is very few miles to need a clutch. Do you know the history and driving habits of the previous owner. Have you had a blackstone oil report done? If not I highly recommend it in case the previous owner spent allot of time near redline (they may have since the clutch is spent at 41k) which can prematurely wear out the rod bearings.
      07-16-2016, 12:23 PM   #10
wdb
dances with roads
wdb's Avatar
4722
Blackstone report sounds like a good idea to me too. Clutch shot at 41K miles indicates one of two things:
  • novice driver
  • car was flogged
Considering the car I lean towards the latter.
      08-03-2016, 05:50 AM   #11
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
07 z4 3.0si  [0.00]
Sport button messing up the clutch? That's new news to me....id go with the notion that previous owner beat the snot out of the car.
kaybat125.50
      08-04-2016, 04:12 AM   #12
Westersund
Westersund's Avatar
Sweden
499
Drives: BMW
Well, the sport button fucks up the throttle response making it too sensitive and that creates a perfect storm for slipping the clutch while doing some spirited driving. The throttle response is awesomely linear without the sport button, don't understand why anyone would want to get rid of that. It doesn't give you anything in an M except for the fucked up throttle response.
      08-04-2016, 07:08 AM   #13
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
I agree completely.
I can't count the number of times I've heard guys asking "why does this car jack rabbit so badly when starting off?"
Often, they are using sport mode.
      08-04-2016, 10:36 AM   #14
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6158
Drives: ‘06 Z4MR, ‘20 X7, ‘22 M4x
This comes to mind lol
Love sport mode btw, will admit it's tough in sandals though
she’s home! '22 M4 Comp xDrive
      08-04-2016, 12:30 PM   #15
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
lol, what a dipshit!
Pretty bad if he can tell the difference between cutch and rubber smoke.
      08-05-2016, 02:11 AM   #16
StickMon
StickMon's Avatar
Drives: 2006 MR
This came to mind for me.
Over 140k miles in sport mode. Clutch is fine.
OP's PO must have been PoS.
      08-05-2016, 11:14 AM   #17
SCHMOUPE
SCHMOUPE's Avatar
Drives: 2007 Z4M Coupe
2007 Z4M Coupe  [0.00]
Amazing! Love hearing stories like this
The Raspinator
      08-06-2016, 08:53 AM   #18
dre99gsx
Drives: 1994 Toyota Supra
Clutches will wear, regardless of mileage. Previous owner could have abused it (it's what these cars are great for!). You really should attempt to locate another Z4 (or any other vehicle for that matter) who uses an aluminum flywheel (or single mass), and sprung disc/aftermarket clutch setup, and drive it around. The chatter isn't all that bad depending what disc you go for (go for full face, not a puck setup). Pedal engagement is still fantastic.
I run a setup on my Supra and never looked back.
In the end, you save hundreds to thousands of dollars for clutch, flywheel and pressure plate vs. going all OEM replacement. You should resurface or replace the flywheel (I believe dual mass flywheels are non-serviceable). TurnerMotorsports option linked above is a good one, also Clutchmasters sells a complete kit for the Z4M.
