      04-19-2011, 09:23 PM   #1
johanness
Drives: 2008 Z4MC
Euro Header install
SO FAR:
Ceramic coated Euro Headers
Window cut in heat shield and 90 Degree bungs welded in
EGT sensor location
To avoid it being a rock-catcher, welded a cover over the area
More to come...
      04-19-2011, 09:53 PM   #2
fr8tdog
International Bar Hopper
fr8tdog's Avatar
25
Drives: 2006 Imola Red Z4 M Roadster
looking real nice Johan!
2006 Imola Red Z4 M, ESS VT2-500 Supercharged, SS V2 step headers, AEM water/meth, Nitto NT555R Drag Radials, ESS VT3 coming
      04-19-2011, 10:32 PM   #3
dorifto88
Drives: 88 Nissan Pathfinder
excited, i am. i am wondering, if you dont mind, how you plan to extend the wires?
      04-19-2011, 10:49 PM   #4
ZStig
instagram 997turbotom
286
Drives: Interlagos Z4MR
what kind of coating is that? (hehehe)
      04-19-2011, 10:50 PM   #5
franco209
Drives: 2010 M3 Coupe
Do you think the sensors are sitting too far back in the bungs?
      04-19-2011, 10:54 PM   #6
Z4-VILLA
Afghanistan
114
Drives: Z4M Hardtop Roadster
that looks like jet hot to me....just not the high end 2000 degree coating that im sporting.
jet hot headers FTMFW!
      04-19-2011, 10:55 PM   #7
z4mnyc
z4mnyc's Avatar
14
Drives: Z4 M Coupe
Looks like you placed the EGT way down the line. Mine is right up on the headers. What's your take on this?
| Z4MC | KW Clubsport | BBS-RGR 19 + Bridgestone RE11 | BBS-RGR 18 + Hoosier R6 | Sparco DTM RS | Vorshlag mounts | Braille battery | Euro Headers | Supersprint exhaust | Stoptech lines | Stongstrut | TCK camber arms | UUC SSK | APR GT-200 wing & splitter | ESS Tune | Speedware Motorsports custom roll cage | Schroth harness |
      04-19-2011, 10:56 PM   #8
ZStig
286
      04-19-2011, 11:26 PM   #9
Z4-VILLA
Afghanistan
114
^^^word
      04-19-2011, 11:29 PM   #10
johanness
Drives: 2008 Z4MC
They are getting unfolded from the ECU back, and run on the opposite side underneath.
The EGT is placed here as per the Euro spec Section 1
See pic:
Apparently, they only do one thing - tell the computer the cats are working. They don't do a myriad of calculations like other cars. (disclaimer: this is what I've been told).
I will check on this and get back to you tomorrow. There was a reasoning behind this, but I've misplaced it in my brain.
Cross my fingers for day 2...
      04-20-2011, 12:00 AM   #11
franco209
Good Luck!! Let us know and post some pics of your wiring if you could.
      04-20-2011, 12:16 AM   #12
z4mnyc
z4mnyc's Avatar
14
Drives: Z4 M Coupe
I sometimes see an EGT plausibility fault code in the ECU. What software are you going to run, if any?
      04-20-2011, 01:25 PM   #13
johanness
Drives: 2008 Z4MC
Response: the farther back the better. we want there to be different readings compared to the front ones, the more different the readings the better the ecu thinks that cat is.
Sounds good to me
      04-20-2011, 01:34 PM   #14
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
nice work on the bungs, one of the best I've seen yet!
      04-20-2011, 01:45 PM   #15
Starscream
Starscream's Avatar
+1,
and those headers are more beautiful jet hot coated than my Supersprint V2's!!!
Really setting the expression, Do it right, Do it once,
Imola Red Roadster
      04-20-2011, 01:51 PM   #16
crfine88
crfine88's Avatar
442
Drives: E86M
Originally Posted by Starscream View Post
+1,
+2^
Greeat work
Getting it done the right way the first time
      04-20-2011, 09:26 PM   #17
johanness
Drives: 2008 Z4MC
Some more shots of the install.
Fitment of the headers is 100% bang on. Freed up a lot of room as well. I have to say a HUGE thanks to CG Motorsports of Richmond, BC. They are true BMW guru's.
The rear O2's were run above the heat shield, securely fastened. The job really looks stock, with no giveaways from underneath unless you're looking for it.
The best part? NO CODES!
The car feels like it went on an extreme diet, and the right pedal seems much more sensitive than before. Then there's the noise.
I'll save my full review for tomorrow once I've put some miles on.
Quick question: Is there a resetting of anything I should be doing in lieu of not having a specific Euro-tune for the car? Or does it not matter and the ECU will adjust accordingly?
      04-20-2011, 09:42 PM   #18
Rated M
Drives: 2007 IB Z4MC
ECU will adapt itself.. Glad your happy with your setup!!!
      04-20-2011, 09:48 PM   #19
fr8tdog
fr8tdog's Avatar
25
F'n Beautiful!!!! nice work
      04-20-2011, 11:07 PM   #20
alvinli217
alvinli217's Avatar
Drives: Imola RED dIrTy Z4MR - SOLD
i saw it in person today!!! NICE as hell!!!!!!
NICELY done John!!!!
now i know locally in Vancouver, there is a shop that can do such nice work and with no codes running headers...so tempted now
RPI scoop|BMC drop in filter|EAS V1 aluminum mount|ZHP shiftknob|RHO plate holder|matte black grill|LED interior & license plate light|RE SSK|RE tranny mount|UUC engine mount|Bavarian CDV|clutch stop|18" Forgestar CF5 GOLD|RPI exhaust|H&R coilovers| RE RSM|
coming soon: aFe intake|tune|secondary cat delete|
      04-21-2011, 12:38 AM   #21
dorifto88
egg cerrent... may i ask how difficult it was for the shop to run the wires? i hope to not pay an outrageous amount for that part of the install.
thanks.
      04-21-2011, 03:01 PM   #22
johanness
Drives: 2008 Z4MC
thanks.
Install for running the wires, cutting it back from the ECU and running it above heat shield and securing them properly etc cost $172.80 CAD.
Less than the cost of a set of new O2's and EGT from Europe (the right length out of the box)? Not sure on that. Maybe someone can chime in
