      09-01-2013, 04:38 PM   #1
v8z4
Drives: 2003 Z4 roadster
LS7/T56 in Z4 build
Delete
Chris
      09-01-2013, 05:22 PM   #2
jra
Drives: 2005 z4
Awesome....How wide are your wheels?
      09-03-2013, 02:06 PM   #3
nekky
Wagon life
nekky's Avatar
Drives: '16 328d M Sport Touring
Very excited to see this...
      09-03-2013, 02:08 PM   #4
v8z4
265 rear (same as M). Unfortunately until someone makes a decent wide fender kit I don't have the room to do much larger. No clutch-dumps for me
Chris
      09-03-2013, 03:27 PM   #5
ricanbandit
ricanbandit's Avatar
29
Drives: 2011 30i
Seriously curious about how this beast is going to sound!
2011 30i
[SIGPIC]/SIGPIC]
      09-03-2013, 04:11 PM   #6
v8z4
Fairly mild idle, full on wild at WOT
Chris
      09-04-2013, 12:15 PM   #7
intoflatlines
intoflatlines's Avatar
Drives: Z4MR, E34, E30
subscribed
      09-08-2013, 09:47 AM   #8
rkstar9
Drives: '10 X5 3.5D
Nice! I think this will become such a popular mod for this car since they are such a good bang for the buck in the 2.5 trim at least
535D Xdrive DUDMD Stage 1
x5d e70 DUDMD stage 2 tune
      09-10-2013, 03:27 AM   #9
lsz4
Drives: Z4 6.0
Ls update
Hi Mate finally got photos off of my phone, this is where we're at.
Had it sitting on the scales weight is 51-49 to the front at this point
      09-10-2013, 05:54 AM   #10
IN10SS
Drives: 2007 Z4M Roadster
What a cool project!
      09-10-2013, 07:25 PM   #11
v8z4
Yeah, you are hacking the car up quite a bit. I'm just doing a direct swap leaving as much unmolested as possible. Difference in end goals (dedicated race car vs fun daily driver).
I'm currently working on the trans and motor mounts (planned to finish them this last weekend but got stuck in bed sick). I have enough room to easily use 2.5" exhaust pipe and it even looks like I can use 3" pipe.
      09-14-2013, 09:51 AM   #12
rkstar9
Drives: '10 X5 3.5D
Jesus if the front tires look like that what do the rear ones look like/?
      10-02-2013, 02:39 AM   #13
lsz4
Drives: Z4 6.0
Hi Chris
How's the build coming along?
      10-02-2013, 10:10 AM   #14
v8z4
Hey,
Well, engine work is still progressing.
I have been so busy with work and family responsibilities that I have not worked much the past month. I'm taking next week off from work so the plan is to go back to work. The transmission mount is 50% finished (machined out of aluminum) and I have to make motor mounts. At that point, things should really speed up.
Chris
Chris
      10-02-2013, 10:17 AM   #15
bjbstewart
bjbstewart's Avatar
Drives: 2007 BMW Z4MC
Can't wait to see more picts. I'm considering putting an LS-3 in a 2000 Boxster via renegadehybrids.com...
[SIGPIC][/SIGPIC]
      10-02-2013, 11:31 AM   #16
v8z4
Boxster would be a fun toy too! There are quite a few Porsche LS swaps out there to take ideas/how-to from.
Chris
      10-02-2013, 11:40 AM   #17
bjbstewart
bjbstewart's Avatar
Yeah, but the problem is CA. Poses a bit of a challenge, but I did get to take a ride in one at the factory in NV last weekend. Holy freakin' cow! Excellent balance of a Boxster, power of a corvette...hope I can pull it off...
[SIGPIC][/SIGPIC]
      10-02-2013, 11:53 AM   #18
v8z4
CA? Do you mean emissions?
I don't know how it IS in CA, but I understood that as long as the engine/ECU is from a newer vehicle (ie:in your case 2001+), the swap is acceptable. For tail pipe test, just install OEM CATs (C5 uses 4 small CATs) and a milder (not stock) cam.
I'm lucky that here in AZ it's just an OBD2 test only. I plan to use EFILive to flash the BMW vin into the GM ECU so the vins match on a scan test.
      01-29-2014, 08:21 PM   #19
mapleridge
Drives: E90 N52 AT
great thread. I called a shop about putting an LS into my e90 and he said not enough space between the frame rails. Can you measure how much space you have?
      01-29-2014, 09:25 PM   #20
v8z4
Then don't go to that shop anymore because the guy doesn't know what he's talking about. The frame rails on my Z4 are ~27-1/4" and there is plenty of room for the LS to "fit". The difficulty is (as we all know) the driver's side header/exhaust manifold. If I ever do another LSx BMW conversion (ie: wife's e46 325i), I will go with a single passenger's side mounted turbocharger. That way I can take the driver's side manifold forward, down, and to the passenger's side and avoid all the header issues (plus build far more HP/TQ).
A lot has happened over the past few months, but I have been so busy with work (and working on the car) that I have not been online much. The motor is currently mounted, I'm 80% done with the driver's side 1-7/8 long tube header, and I hope to start on the passenger's side this weekend. The rotating assembly is being balanced (my machinist had back surgery so was out of work for a few months) and the LS7 block is on its way to CA for a resleeve. Unfortunately, tax season is starting so most of my weekends (through April) will be spent at the office rather than in the garage. Shooting for a summer time completion (if everything works out).
Chris
      01-29-2014, 09:36 PM   #21
v8z4
Some shots from a few weeks ago:
Chris
      01-29-2014, 09:43 PM   #22
mapleridge
Drives: E90 N52 AT
On my Z4, the frame rails are ~27-1/4" and there is plenty of room for the LS to "fit". The difficulty is (as we all know) the driver's side header/exhaust manifold. If I ever do another LSx BMW conversion (ie: wife's e46 325i), I will go with a single passenger's side mounted turbocharger. That way I can take the driver's side manifold forward, down, and to the passenger's side and avoid all the header issues (plus build far more HP/TQ).
I hear you. An L33 with a single turbo would do the trick nicely and be relatively inexpensive. The shop was also terrified of the wiring. I am still searching for a shop to do it for me. What will you do for the electronics?
PS. I will post in this thread going forward. Saw you started this after posting in the other one. This thread is pure greatness.
