10-29-2022, 04:43 PM | #1 |
Rep 45
OEM Exhaust Alignment
Hello,
I have a 07 z4m coupe. I just realized that the OEM exhaust is hanging lower than normal from the rear. Is there a way to adjust the position of the rear mufflers? Thanks |
10-29-2022, 04:48 PM | #2 |
Rep 1,543
Use the two bolts connecting to the x pipe to adjust. Tighten or loosen each bolt separately to adjust to your preference.
Also, by turning the flange to different positions to adjust the direction of the adjustment.. HTHs, .
10-29-2022, 05:52 PM | #4 |
Rep 2,866
See this thread => https://www.bimmerpost.com/forums/sh....php?p=8832394
10-30-2022, 11:24 AM | #5 |
Rep 975
Yes, it can be baffling at start but at least in my car the way to get the mufflers to rise I had put the flanges vertically and started bolting the “top” bolt to the point I needed to back off as it was now too high. One side could not be risen as much but enough to look spot on.
You need to make sure all mounts and supports are still good. Otherwise you will be chasing your tail. Last edited by maupineda; 10-30-2022 at 10:50 PM.. |
