      07-29-2022, 07:58 PM   #1
jvx800
Drives: 2003 BMW Z4
Differential 3.0l vs 2.5l
I need a differential for my 2003 Z4 3.0l Automatic. Are the differentials in the 2.5l different than the 3.0l? I see that they have a different part number. I have tried searching this forum but have not come up with this particular answer. Thanks in advance.
Whining in Savannah,
Jay
      07-29-2022, 08:22 PM   #2
Steeler
Steeler's Avatar
2429
Jay
In my experience there is no physical difference between 2.5,3.0i or 3.0si diffs, auto or manual. there are different final drive ratios. Highlighted in yellow here.
      07-30-2022, 10:45 AM   #3
Beedub
in that case can you guys put in the ///M unit ?
      07-30-2022, 12:06 PM   #4
Piper1
Piper1's Avatar
Drives: E85
In short no. That chart is only for ratios.
      07-30-2022, 02:09 PM   #5
Steeler
Steeler's Avatar
2429
I wish it was that simple Byron. Alas no.
Takes substantial mods.
IE subrame etc.
      07-31-2022, 05:05 AM   #6
GuidoK
GuidoK's Avatar
10866
Drives: Z4 3.0i ESS TS2+
IE subrame etc.
for that mod you need the complete rear axle and the propshaft.
Not only has the M diff different mounting points in the subframe, it also has different input and outputflanges, (which cant be swapped out) and the M driveshafts wont fit the non M trailing arms.
Of course if you start off with a 5 speed or automatic, the M propshaft has the wrong lenght, so only a 3.0i/3.0si is really suitable for this conversion.
      10-10-2022, 09:53 PM   #7
Rafichicago
Rafichicago's Avatar
Drives: 2018 M5 2009 E63AMG Wagon
Manual And automatic axles differ as well. Ask me how I know.
