      07-20-2022, 07:48 PM   #1
loukywells
Drives: 2007 BMW Z4 3.0SI
'07 Z4 3.0 coolant light staying on
I recently replaced the water pump & the thermostat housing...everything ran perfect. Reservoir tank then had a crack, replaced that and the sensor in the bottom. I have bled the system multiple times using the automatic bleed method and unscrewing the vent and letting it bleed...never had bubbles. It has never overheated and runs great, just can't figure out why the coolant sensor is still on. Can visibly see the indicator popping up and that is fine as well. I need some help!
      07-20-2022, 09:33 PM   #2
vt100
vt100's Avatar
126
Drives: '06 Z4MC, '12 128i
what code it's showing?
