      05-21-2022, 03:33 AM   #1
1zpower7
Drives: BMW Z4
BMW Z4M fuel system upgrade
My ///M becomes FI and will run on E85 fuel (I upgraded my fuel pump to WALBRO HELLCAT 525LPH).
I want to upgrade the entire fuel system of my ///M with radium components in order to support it in the best and safest way.
I have already radium s54 fuel rail + fuel flex.
Does anyone have experience with this and can help me choose the right components? (PushLok Hose Ends, DMR, Fuel Pulse Damper and etc...)
      05-21-2022, 04:21 AM   #2
GuidoK
GuidoK's Avatar
10866
Drives: Z4 3.0i ESS TS2+
Originally Posted by 1zpower7 View Post
PushLok Hose Ends
whatever you do with pushlok, always use a hoseclamp on those barbs, even though they say it's not needed.
      05-21-2022, 01:07 PM   #3
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
This!! Exactly!
Btw, you need the radium fuel pulse damper otherwise you'll get erratic injection if your running that rail. I have the same setup on mine and I love it. There's also the surge pump from radium that's a good buy, esp.if your running e85. Bit exy, but well worth it.
      05-21-2022, 01:22 PM   #4
1zpower7
Drives: BMW Z4
Originally Posted by Vanne View Post
This!! Exactly!
Thank you for the reply!
1. My fuel lines will be 6AN so I'm guessing I'll need the "FPD-XR, Inline, 6AN" option:
http://www.radiumauto.com/Fuel-Pulse...Kits-P751.aspx
2. Can you provide a link the surge pump from radium? Will it work with WALBRO HELLCAT 525LPH?
