      01-22-2017, 11:08 AM   #1
EMP07
EMP07's Avatar
37
Drives: Z4M
Euro headers
I had these on for about 4 years. Have not been driving the car much in the last 2.
Passed Cali emissions 2 years ago, no issues. Now I have persistent error 29F5 but not CEL.
Resetting code means, another round of drive cycle etc...
Any thoughts? New O2 or Fuel delivery?
BSM Z4M Coupe
      01-22-2017, 12:37 PM   #2
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Code is for bank 2 CAT.
It will be either of, bank 2 O2 or the CAT itself.
Did you pull any other codes?
I had one primary O2 go bad at 32k miles, but I also had other O2 codes.
      01-22-2017, 04:56 PM   #3
EMP07
EMP07's Avatar
37
Drives: Z4M
I had one secondary O2 go bad at 32k miles, but I also had other O2 codes.
Do you also have Euro headers? If so what replacement length O2 did you get i.e. EU spec at ~1300mm or NA spec at ~1050mm
This is the one that pops up consistently. In one instance I had a EGT code, but when I cleared it nothing else came up
Maybe I replace the O2 and the plugs.
BSM Z4M Coupe
      01-27-2017, 07:45 PM   #4
Jumbosock
Jumbosock's Avatar
76
Drives: 2007 M coupe
What are you using for cats and where did you place your O2 sensors?
      01-28-2017, 09:57 AM   #5
EMP07
EMP07's Avatar
37
Drives: Z4M
Jumbo, nothing out of the "norm".
NA oem cat2's with Euro like placement.
BSM Z4M Coupe
      01-28-2017, 06:28 PM   #6
Jumbosock
Jumbosock's Avatar
76
Oh that's probably your problem. The North American cats in section 1 are very short so they don't do a very good job on their own. The Euro cats in section 1 use twice as much cat material. You could try to add a non-fouler to trick the O2 sensors.
CSL headers*Euro cats*Arqray exhaust*DKF hangers*Evolve Tune*Genuine CSL rims*10mm Macht Schnell front spacers*modified Hamann bumper*Tekarbon 2X2 CF spoiler*Turner CF grills*AS SSK*KWV3*OEM Strut bar*Rogue RSM*Polyurethane anti-roll bar bushings*Deka ETX30L battery*Nav Video module*front & rear cameras*Ipod module*stubby antenna*R-Dash LED license lights*LED Ziza interior lights
      01-31-2017, 12:51 AM   #7
Arsonism
Arsonism's Avatar
Drives: '08 M Coupe
Curious to this question as I may be looking at it as well.
NA specs are here
http://www.realoem.com/bmw/enUS/show...diagId=18_0664
Similar parts can be found on lovely sites like this:
https://www.amazon.com/Bosch-15168-O...ype=automotive
I haven't looked for the others recently.
◙ Shane
      01-31-2017, 07:44 AM   #8
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
The NA ones work fine with the harness extended, although one is a little tighter than the other.
I'm using the original with no problem, but if I was to replace,
I would just get the longer NA one for both.
bTW when I replaced my primarys I used aftermarket, not OE.
They work fine.
      01-31-2017, 11:43 PM   #9
EMP07
EMP07's Avatar
37
Drives: Z4M
They work fine.
Thanks! You cannot use the longer O2 sensors on both as the connectors are different (in case that is what you meant).
I'm replacing both O2 sensors and the EGT, then plugs and a fuel clean to see how it goes. fingers and toes crossed.
BSM Z4M Coupe
