05-20-2010, 06:22 PM | #45 |
Bad Lieutenant
233
Rep 3,517
That's what I was thinking, temperature shouldn't be that large of an issue, but overall airflow and expected airflow from the stock airbox could be the issue. I'm only basing this on the SIB stating that if the charcoal filter is removed, airflow is disturbed and strange things happen. Would like to hear a sound clip from this thing in action though.
05-20-2010, 06:56 PM | #46 |
Rep 1,269
It's not just a matter of putting insulation around the box. With the AFE intake you lose the ram-air effect which essentially acts like a very very tiny supercharger, especially at higher speeds with higher air pressure. This is the main reason that intakes like the AFE actually loses power compared to the stock airbox. Now if you can find a way to seal the box...
2019 Porsche 911 4 GTS
05-20-2010, 07:03 PM | #47 | |
Rep 165
05-20-2010, 07:23 PM | #48 | |
1M advocate
214
Rep 878
If you look at the intake designs of the e9x m3 and e46 m3 they actually have holes to allow the air to escape the airbox, essentially sucking away all the air that would be "rammed" into the intake. Intake tuning is alot like drinking water out of a hose, if you just turn water pressure to max and blast yourself in the face it's very difficult to drink, likewise if you don't have enough flow of water there isn't enough to drink, what you want is to find that balance of flow between too much where you can't swallow it all and not enough where you are taking small sips. Intake tuning is exactly the same idea. Look at all race cars every channel and duct is designed to channel air either into or around components or body & aero components. on the job of the component.Ram air is a marketing term. Which is why I don't trust aftermarket intakes which aren't designed using the same CFD analysis as the stock stuff, and I just don't think some dude in his garage can design something better then a team of BMW's engineers. Last edited by Serious; 05-20-2010 at 07:36 PM.. |
05-20-2010, 07:26 PM | #49 |
Rep 1,269
Who's saying anything about the scoop? I thought this thread is about the AFE intake?
The hole in the stock box is to drain out water/rain. It makes no difference to the "fact" that there's air-pressure building up in the stock airbox; the size of the hole just changes the amount of the pressure. You can say the term ram-air effect is a marketing term. But physics is physics. Edit: Nevermind I think you meant to reply to hansaysso.
2016 BMW M3 2008 BMW Z4M coupe Last edited by GP20; 05-20-2010 at 07:36 PM.. |
05-20-2010, 07:31 PM | #50 |
1M advocate
214
Rep 878
I was referring to the stock scoops and ducting and how they actually don't function to "ram" air at all.
2012 BMW S1000RR
2011 BMW M3 Last edited by Serious; 05-20-2010 at 07:36 PM.. |
05-20-2010, 07:46 PM | #51 |
Rep 1,269
You're right; some dude can't just do that in his garage. It'd take a lot of money, time and R&D. Not exactly something worth investing on for a car like the Z4. Which is why you see all the aftermarket companies simply come out with easily designed and manufactured hot-air intakes that make the cars sound nice while losing power at the same time.
05-20-2010, 07:47 PM | #52 |
Rep 1,269
Then you'd need to do more research on how the stock airbox works as well as the physics behind rammed air - 'cos you don't actually know what you're talking about.
05-20-2010, 10:09 PM | #53 | ||
1M advocate
214
Rep 878
Look at the design of the intake on the e9x m3 (and e46 m3 although it isn't as clear) there is a high pressure area on the front of the car where the air is drawn in, on the e9x m3 it has a hole cut in the hood, which is a notorious low pressure area at speed so, why would you want an air intake in a low pressure area?... its to allows the air being throught the 2 intakes in the front (behind the grills and drivers side brake duct) to escape, this allows more laminar flow and reduction in turbulence.
2012 BMW S1000RR
2011 BMW M3 Last edited by Serious; 05-20-2010 at 10:15 PM.. |
05-21-2010, 03:21 AM | #54 |
Rep 2,782
What we need is a video of a stock car vs. an aFe car. Any dramatic horsepower differences should show up there. I've seen a thread on a 5 series forum claiming that the aFe lost 30 hp or so, which I think is total BS. I'm as skeptical as anyone with regards to claimed hp gains, but I've seen post after post of rival companies saying aFe loses serious power (it doesn't). From what I could tell, those tests were disgustingly biased and anything but scientific. On one dyno the car was run hard time after time with no cool down period in order to intentionally induce heat soak and SURPRISE inlet air temps were around 140 degrees = loss of hp.
I think the best way to test if the car loses power is to run 2 cars with equal weight drivers in say a 2nd or 3rd gear pull. I bet the results will be pretty close. If anyone in the Fresno area has a stock car that would like to donate their time, I'm down to donate mine as well. Otherwise it'll probably be up to the SoCal members as your Z density is quite a bit higher As I've said before, the aFe probably doesn't gain any power, but there's definitely not a huge loss in power either. |
05-21-2010, 03:33 AM | #55 | |
1M advocate
214
Rep 878
The driveability are what keep me away from aftermarket intakes, the s54 has a tendency to die if you clutch it in from high rpm at high speeds... as well as the reduction in filtering ability and getting filter oil on the HFM. It's just not worth the 5hp on the top end to me personally, I think overall the stock system is best... but best doesn't always be maximum HP or performance.
2012 BMW S1000RR
2011 BMW M3 |
05-28-2010, 02:02 AM | #56 |
Rep 2,464
Okay here is a short video. Recorded with HD Hero. Sound is recorded with Zoom H2. Windows are closed. Zoom H2 is sitting on the passenger seat. Didn't rev up to redline. Will do longer videos & comparison with stock some time.
05-28-2010, 03:27 AM | #57 |
Rep 503
Drives: Z4 M Coupe
That sounds very cool. How about a longer video now?
02-27-2011, 07:01 PM | #61 | |
Rep 202
Z4 M coupe with Super Sprint exhaust and X pipe, RPI Scoop, AFE air intake, ESS tune, DINAN 4.10 Limited Slip Differential, OEM CF spoiler.
M3 E92 Coupe with DCT, Akrapovic Evolution exhaust, ESS tune, DINAN 3.62 Limited Slip Differential, OEM CF performance parts. 1M Coupe... Loving it |
03-28-2011, 09:31 AM | #62 |
Rep 34
I just installed my AFE this weekend... CAR SOUNDS WAY BETTER THAN STOCK.. i did notice better MPG.. and i did notice more pull on the freeway 50+ mph, i dont drive hard on the street
03-29-2011, 05:33 PM | #64 |
Rep 144
I did this mod purely for the intake sound. I track my car (HPDE) and I just flat out couldn't hear it at all, particularly if there were other cars nearby. Now at least I can hear the car rev when I'm on the throttle.
It doesn't hurt that most BMWs produce a fantastic intake sound.
2013 BMW M3 Coupe : Interlagos Blue : Silver Norvillo : 6MT : Competition Package : ACM exhaust - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - pics of M3 |
03-29-2011, 10:25 PM | #65 |
Custom User Title
147
Rep 661
RE: aFe intake for Z4M
These are currently $397.99 plus shipping from VR Speed Factory (vr-speed.com) part# 54-11521 Disclaimer: I am not affiliated with any vendor or reseller. But I CAN use the google. |
03-30-2011, 12:23 AM | #66 |
Rep 1,603
Drives: Imola Red Z4MC
wow only 397?? Is this standard or a sale price or somethin? seems like a good mod for this price
///M - Some Mods 'N Stuff
