06-12-2012, 02:36 AM | #661 |
Rep 2,460
wheel hop also breaks tail lamps, tail lamp bulbs, and eventually separates the rear bumper....:-)
06-12-2012, 01:38 PM | #662 |
instagram 997turbotom
279
Rep 7,377
that happened to your car?
06-15-2012, 05:43 AM | #665 |
Rep 2,460
06-15-2012, 05:45 AM | #666 |
Rep 2,460
06-18-2012, 02:12 PM | #667 | |
279
Rep 7,377
06-18-2012, 02:13 PM | #668 |
279
Rep 7,377
Don't say that, you KNOW there's a lot more thats just waiting for you to break
06-18-2012, 02:53 PM | #669 |
279
Rep 7,377
Drove Philly to Ft. Lauderdale yesterday. I've done this trip before without stopping for sleep, but had to do it this time for 4 hours. Took me a personal best 18.5 hours if you exclude my mid-trip nap.
Car performed flawlessly, with a trunk and passenger seat filled to the brink with cargo. Even weighed the car at a truck stop (165lbs driver, full tank of gas, + a LOT of cargo). Also did a quick sprint on a desolate road, but didn't go faster because I was holding the camera phone in my right hand, and was afraid the extra cargo's weight would make it unsafe. The HR coilovers helped the car feel very planted at 130mph, and the car accelerated there very reasonably in just the 6th gear
06-18-2012, 07:59 PM | #670 |
#dubspec
6336
Rep 5,201
glad you made it safe and sound. keep us updated on how things turn out in miami for you
06-19-2012, 01:13 PM | #671 |
Rep 5,328
well done BRO!!!! mad props for just taking the leap!!! if you ever decide to pass thru the UK be sure to look me up :-)
06-19-2012, 01:55 PM | #672 | |
279
Rep 7,377
06-19-2012, 01:56 PM | #673 | |
279
Rep 7,377
06-22-2012, 05:10 PM | #674 |
279
Rep 7,377
electric exhaust cutouts are the next ordered mod. Will have these installed after the x-pipe but before the muffler. Should sound like Satan at full throttle, but flick the switch, and back to no-drone quiet exhaust =). Screw aftermarket mufflers!! Ordering the best quality ones I could find.
There's a small wait on these DMH low profile units, 5-15 days.
06-24-2012, 04:59 AM | #675 | |
Rep 5,328
06-24-2012, 10:18 AM | #676 |
Rep 2,460
06-25-2012, 07:13 PM | #677 |
279
Rep 7,377
Its designed to hold a lot of power and rev quickly, not to be smoother than stock. No lighter aftermarket kit will be smoother than stock (which is fine for me at this power level)
06-25-2012, 07:15 PM | #678 |
279
Rep 7,377
Did you install it yet? Beedub asked you before and you didn't say anything
07-13-2012, 04:54 AM | #680 |
Rep 5,328
tom, well with all the bad weather weve been having over here, im going to do the clubsport install while the cars stuck in..... also with my reinforced front upright domes and will also be also adding my Re Rear mounts, getting alittle excited about it now!!
any tips for me?? im going to do this with the hardtop on, so the roof will be down, will this be an issue in terms of removing the trim on the trunk?? Was going to spread this over 2 days taking my time.
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com Last edited by Beedub; 07-13-2012 at 05:53 AM.. |
07-13-2012, 09:17 AM | #681 |
279
Rep 7,377
Since I've had the chance to take apart my trunk (boot) twice to access the rear shocks, I've realized on my second time that you don't have to take EVERYTHING apart. Only the big tray, the thing with the tray hinges on both sides, and then you can kinda peel away the side carpets after removing the things that hold them. Don't bother taking off the carpet in the bottom of the trunk, or anything around the tail lights. Hardtop should not be a problem, I think..
Also make sure you remember how the washers are installed on the stock shocks, as installing them wrong can make a shock punch through the hole. Happened to me. Also, the first thing you should do is remove the big bolt on the bottom of the shock, to allow the suspension to fully drop down, which will make the springs install very easy with just your hands. Don't overtighten the nuts holding the front strut assembly up (the 3 poking through the top). They strip easily
07-14-2012, 03:54 AM | #682 | |
Rep 5,328
on the rear be careful with washer layout.. bear in mind im using Re mounts... Only need to remove the tray, is this difficult or piece of piss?? the fronts im always very careful with the nuts, Tq figure is 35nm.... will grab the tis to get Tq figures for all parts.... all in all, is this something you felt comfortable doing?? ill then drive to a shop to get alignment.... i will be trying to lower the car the minimum amount possble....
