      05-25-2009, 01:10 AM   #23
Z4MCJJ
Z4MCJJ's Avatar
Drives: Z4MC
RussRamz,
Can you attach some additional pics of your rollbar/cage? I've been thinking of having one fabricated locally and some additional pics would be helpful. Thanks.
      05-25-2009, 11:48 AM   #24
bkz4mc
Mars Bitches... Red Rocks !
bkz4mc's Avatar
Drives: '07 Z4 M Coupe
Originally Posted by Z4MCJJ View Post
RussRamz,
And some pics of the wiring for your passenger occupancy mat...
I'll be posting pics of my harness bar when I get it all sorted out and put in. Just in the process of getting the seat mounts built, lightweight battery mount built and my secondary cat delete... yes, I took on too many projects at once. hahaha
      06-09-2009, 10:23 AM   #25
RussRamz
M Slut
RussRamz's Avatar
Drives: 2011 M3 Coupe Mineral White
Location: Adenau, GE via 3 years in dreadful El Paso, TX
Rollbar
Here are a few pictures I took this afternoon. They were difficult to take with the lighting, but I hope they convey the installation.
You have to be 100% behind someone before you can stab them in the back.
David Brent
      06-09-2009, 10:25 AM   #26
RussRamz
M Slut
RussRamz's Avatar
This link also shows some pictures of the installation in the trunk before the trim was reinstalled.
http://picasaweb.google.com/david.ra...titionRollBar#
David Brent
      06-09-2009, 10:29 AM   #27
RussRamz
M Slut
RussRamz's Avatar
Photographing this proved to be unsuccessful. I would need to remove my Recaro seat. I inspected the wiring and found the sensor mat was connected (it contains a small little electronic module) and is unique to the newer BMW autos. You might be able to order one without ripping apart the seat, but I don't plan to ever reinstall the OEM seats so I didn't care. The driver seat is a nice game seat now...
David Brent
      06-09-2009, 12:37 PM   #28
bkz4mc
bkz4mc's Avatar
All good... I actually went ahead and removed the mat from my stock seat. So I used the stock seat belt receptacles with the firing mechanism's and the pass occupancy. Too bad I had the battery connected when I took the seats out because now I need to go get my SRS light fixed at the dealer....
I'll pop some pics of my install as well for you to peep. I actually posed a couple pics in the Gerneral forum under the "Installing Recaro PP's" thread.
B
      06-09-2009, 03:41 PM   #29
Z4MCJJ
Z4MCJJ's Avatar
Drives: Z4MC
Yes...let's see them.....
Russ...wow I can't believe that the cross bar goes in front of the center console....doesn't seem like enough room to make driving comfortable. Maybe with recaros the clearance behind the seat is better. I think if you did that with OEM seats your chest would be against the steering wheel.
      06-09-2009, 03:47 PM   #30
F360C
Drives: E86 S54
Do you know if the shop that built yours would want to ship some to the US?
07 Z4 M Coupe AW/IR
      06-09-2009, 04:09 PM   #31
bkz4mc
bkz4mc's Avatar
Here's the outside drivers side mount I built... that upside down T bracket holds the stock seat belt anchoring plate.
      06-10-2009, 01:18 AM   #32
RussRamz
M Slut
RussRamz's Avatar
Yes to both...
http://www.wiechers-sport.de/
They offer two options for the Z4. One is a roll bar like mine and the other is a full cage. They will also do a welded cage, but the car needs to be completely stripped at their facility to do it. Eventually, it is the route I will go...
David Brent
      06-10-2009, 01:20 AM   #33
RussRamz
M Slut
RussRamz's Avatar
Recaros provide a lot more clearance. They also save a LOT of weight. With the change (including harness and all), I saved 14 kg per seat!!!
David Brent
      06-10-2009, 01:33 AM   #34
bkz4mc
bkz4mc's Avatar
Hey Russ... does your the back of your right arm ( tricep ) hit the seat when you shift ? Mine does and after 2 days... it's kinda buggin me. hahahaha Note to self : Accept the new lack of practicality, you asked for it !
I think I need to move back one setting and maybe tip the front up a notch as well.... might do the trick.
      06-10-2009, 03:59 AM   #35
RussRamz
M Slut
RussRamz's Avatar
Yes it did. I have installed a UUC short shifter and it fixed the problem, not to mention the shifts are much more "crisp" now.
David Brent
      06-10-2009, 10:26 AM   #36
bkz4mc
bkz4mc's Avatar
I put one of those in a couple months ago...def makes the shifts better and crisper. Maybe I just need to adjust it and make it shorter so the throw is a little less. I'll figure it out.
      06-19-2009, 03:01 PM   #37
jragan
Imola Lover
jragan's Avatar
Racing crash of Z4M: http://www.zpost.com/forums/showthre...85#post5359985 . You might see what you can see of the roll-cage for hints
Hers: 997-1 C4S: Pics
      06-19-2009, 06:28 PM   #38
Z4MCJJ
Z4MCJJ's Avatar
Drives: Z4MC
Holy crap...I need a roll cage!!!
      07-14-2009, 03:26 PM   #39
RussRamz
M Slut
RussRamz's Avatar
My car is running well with the changes...
Quick observations:
KW Rocks!
TC Kline sucks (at least for the 'ring)
StopTech works well
Nitto NT-01's are on par with Michelin Cups and even slightly superior wet performance (neither are good)
TR Motorsport wheels so far and strong enough...
David Brent
      07-14-2009, 03:46 PM   #40
OutOn
zetero
OutOn's Avatar
Spain
Drives: Z4M Coupe
David, can I ask you how much is the Wiechers Roll Cage if I go and buy it in Germany? Your car is looking great BTW.
      07-14-2009, 10:49 PM   #41
RussRamz
M Slut
RussRamz's Avatar
Thanks! I paid roughly 800 Euro for the 1/2 cage. I may pull it this winter and install a full cage.
David Brent
      07-15-2009, 04:49 AM   #42
OutOn
zetero
OutOn's Avatar
Spain
Drives: Z4M Coupe
I could be interested in your 1/2 cage if you decide to upgrade to full cage. Iīll be around.
      08-03-2009, 02:00 PM   #43
JCz04Bimmer
JCz04Bimmer's Avatar
31
Drives: 06 Z4MC
Any update on how one could go about getting the half-cage outside of Germany??
      08-04-2009, 10:55 AM   #44
OutOn
zetero
OutOn's Avatar
Spain
Drives: Z4M Coupe
In my case itīs just to give them a call as they send the cage anywhere in Europe. Not sure about shipping overseas though.
