      01-23-2016, 04:11 PM   #23
3002 tii
3002 tii's Avatar
2282
On my research, ive also seen comments regarding hose size.
All these kits and backing plates are based on 3" hose.
I have seen discussion on whether 3" is appropriate for our type of use, if not a full blown track beast.
With a BBK and track pads you need a good amount of heat to have them in the proper operating range.
If you cool them too much you won't get proper pad transfer, will not brake as well and wear the rotors more......
Though was that 2 - 2.5" might be more appropriate ??????
3002 tii ; you've been running yours for a while now.
Any credence to this line of thinking?
3" may be better than 2 but not if the extra width requires more bends. Suffice to say any ducting is better than none so I would go as big as you can that will fit without having to run extra length or bends.
Another thing to keep in mind is plastic flanges may flex when you tighten the clamp around the hose so be sure to pick hardware that's rigid. I went plastic first time but it was a major PITA to secure the hoses so I later swapped for metal ones.
Follow for latest mods
      01-24-2016, 02:19 PM   #24
Beedub
Originally Posted by Vanne View Post
Byron, I meant if somehow we could modify the backing part black plastic bit on the back of the OEM intake hole.. and connect a 2.5 or 2 inch pipe to that puppy. If you pull the plastic flange, there is room enough behind there for a radiator, so a 2 to 2.5inch hose should fit, as Ian mentioned, the problem will be though the mount parts of the flange.. either that or completely do away with that bit and make something new that fits behind there..
next time i have the bumper off ill have a good look see, (that might be pretty soon as i foresee i am going to have issues fitting this OEM CSL Snork part of my intake)
kinda like these, minus the cost of course...
http://www.turnermotorsport.com/p-21...otorsport.aspx
i hear you buddy.... i wish bmw would have done this properly from the off tbh as the vents in the lower section are in a great position to feed air into the wheel area.... sadly they left it at that...
      01-31-2016, 10:16 PM   #25
longress
longress's Avatar
Drives: 2007 Z4M Coupe
I can report that the e46m backing plates from Hard Motorsport are not going to work. The knuckle bolt pattern is off and the steering arm will not allow the duct mount to clear. I'm altering the plates to make them work but it would of been the same amount of work just to fab plates from scratch. I had to cut off the duct and drill new mount holes as well as a hole for the wheel speed sensor.
I need to cover the current holes on the plate and relocate the duct mount then start on the other side.
      02-01-2016, 06:58 AM   #26
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Thanks for the update.
I'm not sure if the E36 will be much better.
      02-01-2016, 08:39 AM   #27
Beedub
I've emailed but this company seems to refuse to respond ... which is frustrating.
      02-01-2016, 11:05 AM   #28
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
^ I have had a couple of emails with them, their response was quick.
I may end up starting from scratch rather than order the E36 and find it doesn't work.
I'm thinking about contacting Turner, they used to sell an E85 plate.
They might be able to shed a little more light on this.
      02-01-2016, 11:14 AM   #29
Steeler
Steeler's Avatar
2428
http://www.turnermotorsport.com/BMW-...ng-plates.aspx
worth a call or an email Ian. They do list them, but nothing listed on the page they direct you to
      02-01-2016, 11:27 AM   #30
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Thanks, yeah I found that with Google as well, but if you go through the menu items it doesn't come up.
I suspect it's a discontinued product.
The other complication for me is the BBK and that I want to run 2" duct to make routing easier.
      02-01-2016, 12:11 PM   #31
Beedub
keep me in the loop with what turner say please :-)
      02-01-2016, 12:22 PM   #32
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Will do.
      02-01-2016, 01:49 PM   #33
longress
longress's Avatar
Yeah I contacted Turner on this before and they said that the e86 kit was discontinued. I think you were right before Ian. The e36 kit may have been closer to correct then the e46 but it's kind of an expensive experiment.
      02-01-2016, 02:18 PM   #34
Beedub
looks like it... but the bolt locations look the same as the e46 ones, so I'm guessing this will need to be re-drilled.... tbh i didn't really the hubs were e36, i though they were e46 to use the CSL rotor and caliper.
      02-01-2016, 04:26 PM   #35
longress
longress's Avatar
Yes I think the CSL is the same part number on the oem for the backing plates between m3 and z4m. I looked for m3 csl brake duct backing plates but couldn't find any for sale. Probably because they're just as rare on the road as our cars.
      02-03-2016, 07:05 PM   #36
longress
longress's Avatar
So all my parts are in for the brake duct job but still need to finish up the backing plates. The car is torn apart to do some other repairs as well so it may be a few weeks before it's on the ground again.
Below is a good picture of what I will be doing with the duct inlet. I need to do some prep to get the black to stick to the aluminum but I think it's worth it.
      05-16-2016, 06:25 PM   #37
z4m_06
Drives: 2006 BMW Z4 M Roadster
Hi longress, any updates on this? What was the total cost? How effective is the upgrade?
Thanks!
      05-16-2016, 06:52 PM   #38
longress
longress's Avatar
I was just getting ready to update on this. I've been busy with several projects on the car but I got around to putting my finished backing plates, solid caliper bushings, and pfc08 pads on this weekend. I have to install the inlets, run the duct, bleed the brakes, and test on the track yet. 😊
I'll update the thread ASAP. Thanks
      05-16-2016, 09:11 PM   #39
Bossdog
Bossdog's Avatar
27
Drives: 2006 Z4MR Imola Red
I have access to a fab shop. Has anyone taken the existing backing plate and cut a hole and welded an inlet flange on it?
      05-17-2016, 06:03 AM   #40
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
The OE isn't ideal to modify because it steps away from the rotor at the front with a quasi air scoop.
The inner sector of the rotor (air inlet) needs to be closed off as much as possible with the hose flange injecting air at that point so that air draws up and through the rotor vanes.
      05-17-2016, 07:54 PM   #41
Frank851
Admiral
Drives: '07 Z4MC, '19 X5 xDrive40i
What is the progress on the CF inlet runners that another member was working on for this application?
Any news on that set-up?
      05-17-2016, 09:51 PM   #42
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
No news that I'm aware of.
      05-17-2016, 10:14 PM   #43
Frank851
Admiral
http://www.zpost.com/forums/showthread.php?t=1232700 is the link to the cf brake runners. I bmped the post and hopefully we will get an update.
      05-25-2016, 11:43 AM   #44
longress
longress's Avatar
Update
Ducts are installed but I've yet to have time to hit the track. I'm happy with the fit and the clearance is good with size tire and offset I'm running up front. The tire only makes contact with the duct at full lock.
I'm still trying to figure out some sort of wide mesh I can use to cover the duct opening to keep debris out or maybe just a plug I can use for street driving.
