      08-01-2013, 01:36 PM   #23
Beedub
should we aim to replace the tensioners every 30k maybe....
      08-01-2013, 02:13 PM   #24
gmd2003
gmd2003's Avatar
352
I guess my point is if you are doing something that involves the belts or pulleys and are in that neighborhood why not replace a75 dollar part that could lead to catastrophic failure. Beedub I think they are good for longer than that , but it depends on use. Its easy to tell if you start losing boost and your belt is noticeably loser this is likely the culprit.
George
      08-01-2013, 04:09 PM   #25
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
I'm on 101k miles on my original tensioner. No slip, but I'm only doing 6 psi with no track time.
      08-01-2013, 06:45 PM   #26
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
Originally Posted by gmd2003 View Post
Ha , that's the million dollar question . I think I have the temperature side of things calmed down , fuel delivery is solid after the Aeromotive , colder plugs are in . I think it will be good , but I'm always an optimist .
George
Did you have to get a re-tune after the fuel pump upgrade?
      08-01-2013, 10:59 PM   #27
seank
enthusiast
seank's Avatar
48
Not to over run your thread, but thought I would let you know that there were know boost leaks. I will change the tensioner but the belts aren't glazed or make ANY noise
      08-02-2013, 05:02 AM   #28
gmd2003
gmd2003's Avatar
352
Hmm , well mine were glazed but I had zero noise . Well I could hear zero noise bc of my RE Diablos lol
George
      08-02-2013, 10:57 PM   #29
seank
enthusiast
seank's Avatar
48
Well, I emailed AJ. He said that I had a boost leak or air intake restrictions. I opened up the area around the air intake ( I made a wall that covered 1 inch of the back half of the filter). I pulled 7.3 psi in 3rd and did a pull on a nearly deserted freeway in 4th and got 9.3psi on peak recall. The car nearly scared the hell out of me. I will fabricate something to increase the air to the filter.
      08-03-2013, 05:42 AM   #30
exdos
England
Drives: Z3 M Coupe(S54) and Z4 M Coupe
Why would you get 2 psi more running in 4th gear compared to 3rd?
      08-03-2013, 07:02 AM   #31
Beedub
did you pop the limiter on your 4th gear run?? sounds like youy seeing just over 7lbs of boost but a spike caused by hitting the limiter gace you a high peak reading.... i will see well over 10lbs if i hit the limiter and try to gain a peak recall figure.... hence why on boost reading runs ill shift at 7700....
      08-03-2013, 10:54 AM   #32
seank
enthusiast
seank's Avatar
48
I am positive I didn't hit the limiter.
It makes sense, considering what the filter, slinky toy does before the super charger
      08-06-2013, 01:34 PM   #33
Gt4
Gt4's Avatar
Drives: 2006 E46 M3 Estoril blue 6mt
So when is your next track day schedule? Can't wait to hear back about that limp mode issue.
      08-06-2013, 08:53 PM   #34
gmd2003
gmd2003's Avatar
352
It's on the 17th and 18th . Just figured out what my issue was . I had the wrong sized crank pulley and supercharger pulley . The VT525 is supposed to come with a 135mm crank pulley and a 79mm SC pulley . My kit came with a 130mm crank and an 85mm SC pulley . That is why I had belt slip and only 5psi with no leaks , the tensioner was likely an innocent bystander .
George
      08-06-2013, 09:39 PM   #35
seank
enthusiast
seank's Avatar
48
George
This is craziness. I am checking all my pulley sizes tomorrow. Did AJ give you these pulley numbers?
      08-06-2013, 10:05 PM   #36
gmd2003
gmd2003's Avatar
352
George
Through Roman yes. It seems their fabricator screwed up and made 130mm pulleys instead of 135mm( measured on rib to rib) not external lip. I'd def check your sizes then give them a call, especially if you are still coming up short on boost.
George
      08-06-2013, 10:12 PM   #37
seank
enthusiast
seank's Avatar
48
George
What's the excuse for the super charger pulley? Are they sending the replacements free of charge?
      08-06-2013, 10:15 PM   #38
ZStig
279
whats the size of your belt?
      08-06-2013, 10:31 PM   #39
seank
enthusiast
seank's Avatar
48
My belt or George's?
      08-06-2013, 10:46 PM   #40
ZStig
279
yours. George's too if he has a 525 kit.
      08-06-2013, 10:59 PM   #41
Str8 RippiN
Str8 RippiN's Avatar
48
Drives: E46 ZCP ///M3
damn, i just got my 525 upgrade kit last week too, i wonder if i have the right size pullies or not now do you know if they just caught their mistake or was it something they caught early on?
-Tommy
"The Zillenium Falcon" mod journal - http://www.m3forum.net/m3forum/showthread.php?t=440670
      08-06-2013, 11:29 PM   #42
seank
enthusiast
seank's Avatar
48
It says 2360, but now George is making me think I may have the wrong size pulleys.
      08-07-2013, 04:29 AM   #43
Gt4
Gt4's Avatar
So anyone know the pulleys size and belt number for the Vt1-445?
      08-07-2013, 06:45 AM   #44
gmd2003
gmd2003's Avatar
352
My belt size is 2334 . They just messed up , and are overnighting me the correct crank pulley as soon as its made (my car is down until then ) . Apparently the 130mm with the 79mm is what the 500 kit used, this the mix up . The first time they sent an 85mm SC pulley so it was way off . I thought my shop messed when they said they had to use a smaller belt, but they didn't . I had just ordered new crank and DC pulleys with a new belt at my own cost bc I wasn't sure and then got the correct SC pulley but the incorrect crank pulley , with the correct belt . So again it didn't fit ( very loose) . When I called ESS and measured everything they figured out the last batch of 135mm pulleys was really 130mm . (They have no correct 135mm in house currently so if you recently got a kit it is likely wrong)
So frustrated right now. They are obviously refunding me the cost of the new belt and pulleys I ordered with shipping .
George.
