01-11-2017, 02:20 PM | #1 |
Rep 15
Z4 M engine braces
I'm not sure how many of you have experienced this but the front end was making some noise when I went over rough pavement, driveway entrances and sometimes even when I would turn the wheel. Turns out the two braces under the hood were slightly loose. There was no movement when using your hand to shake the brace but taking a wrench to the nut showed they were just slightly loose. Tightened them right up and problem solved! Noise is gone and the feel is back to normal.
If you have experienced this, do you find that this happens over time and simply needs to be re-tightened every so often? I'm gonna add this to my maintenance checklist moving forward. |
01-11-2017, 02:56 PM | #2 |
Rep 5,327
make sure you Tq these to spec....
dont just tighten them up..... welcome to the forum btw haven't seen you around ! nice to see new members filtering through!
01-11-2017, 03:28 PM | #3 | |
Rep 15
Thanks for the heads up. Do you happen to know what the TQ spec is or where I can find it? I took it to an independent German shop and yes, he just tightened them up. |
01-11-2017, 03:33 PM | #4 | |
Rep 5,327
do a search on this forum, its been discussed quite a few times.... you dont want these over tightened these tabs have been know to snap, also certain models had new one time use stretch bolts.
01-11-2017, 03:48 PM | #5 | |
Rep 11,665
http://www.zpost.com/forums/showthread.php?t=717270
01-11-2017, 04:18 PM | #8 |
Rep 5,327
i use snap on... very nice stuff but very expensive. in reality any decent auto store ones will do what you need.
01-11-2017, 04:28 PM | #9 |
Rep 15
Awesome. I'm going to pick one up. From what I've been reading, seems like the tension should be 41Nm.
01-11-2017, 04:30 PM | #10 |
Rep 15
