01-04-2017, 11:52 AM | #1 |
Rep 139
lowered car too much? front suspension design?
So, I lowered my 07 Z4 M Coupe quite a bit. Unfortunately I lost the original ride height measurements but I think I'm at about an inch and a half. I used coilovers. I'm getting some seriously LOUD clunks/bangs when I go over sharp bumps in which something seems to bottom out. I can't see how it could be the coilovers so is there some control arm banging against some other part when this happens? I'm already resolved that I have to raise it but just want to confirm that this would actually help.
Thanks |
01-04-2017, 06:45 PM | #3 |
Rep 912
Raising will definitely help but it's not necessarily the cure to your problems.
Being low can cause rubbing of the tire or rim onto the fender, or inner fenders. But this is more of a rubbing noise and will happen more on dips and bumps. You can also have binding of the spring or collars that will cause a different clank. Or you could have loose items like the struts. Maybe your bushings are gone and its now just more noticeable. Tire size and rim can make all the difference on a lowered car as well. Your car does not look as low as some and it doesnt look like the tires poke out or are too wide. Get under the car, check it out. Look everything over, get a buddy to ride with you. Take the tires off, look for rubbing on the fenders or inner wheel wells. This is all standard territory for a lowered car. Good luck. |
01-05-2017, 04:46 PM | #5 | |
Rep 139
It does rub in the right rear a bit, but that's not what I'm talking about. I'm talking a big LOUD BANG when I hit a sharp edged bump. It's likely that the strut is bottoming out in terms of travel. Not sure what hits though. Perhaps the top of the outside of the shock hitting the bottom of the radial bearing area.
01-05-2017, 05:35 PM | #6 |
Rep 139
Thanks!
Front Wheel Fitment 2 x APEX ARC-8 18x9.5" ET35 Wheel Hyper Silver $628.00 ARC81895ET35HS Rear Wheel Fitment 2 x APEX ARC-8 18x10" ET25 Wheel Hyper Silver $648.00 I believe 275/35 18's in the back and 255/35 18's in the front. |
01-05-2017, 05:37 PM | #7 |
1820
Rep 5,337
Which coil-over?
01-05-2017, 05:40 PM | #8 |
Rep 139
I'm a big fan of these guys after how responsive they've been to all my many questions, and the price and quality so I'd rather not say yet in case it's not on their end.
01-05-2017, 05:49 PM | #9 | |
Rep 1,395
Drives: Porsche 993, 2014 MB GLK
01-05-2017, 05:55 PM | #10 |
Rep 1,395
01-05-2017, 07:01 PM | #11 |
Get off my lawn
932
Rep 1,158
Drives: 6MT
Garage List 2023 GR Corolla [0.00]
2022 BMW X3 M40i [10.00] 2007 BMW Z4M Coupe [0.00] 2002 BMW 325xiT [0.00] 1991 BMW 318is [0.00] |
Running that wide of a wheel and tirewall in front is likely causing your car to rub for sure - otherwise the low stance is nothing new for these cars. How is your alignment?
01-06-2017, 12:35 PM | #12 |
Rep 912
I'm not a tech, but a loud bang doesn't sound to good. Sometimes springs will turn within the perch and will make a loud bang, but only on cheaper coil overs (not that yours are, its just common with some brands).
You mentioned the manufacturer has been quite responsive. Have they offered any insight? |
01-06-2017, 01:59 PM | #13 |
Ammar
73
Rep 406
Im not too saavy in these things, but I can agree with you that its got something to do with the suspension. Probably not bc of the wheel/tire fitment.
2018 F150 Platinum - Black/Black - Leveled on 34's - DD |
01-06-2017, 04:39 PM | #14 | |
Rep 11,667
You likely have very little clearance wheel to strut. If on something like KW3 with the shape of the spring you could be hitting it under compression
01-06-2017, 05:15 PM | #15 | ||
Rep 398
It doesnt seem anything ridiculous from the photo but it would help if you also provide more info such as your current ride height front/rear (Measured from the fender to the wheel cap center OR from the fender to the bottom of the wheel) |
01-09-2017, 11:45 PM | #16 |
Rep 987
On my KWV3 I had to use 10mm spacers up front to not hit the strut. I also remember a story of somebody installing the rears on the wrong side (there is a left and a right) and it was making a huge bang when he hit a bump. He reversed the components and it went away.
CSL headers*Euro cats*Arqray exhaust*DKF hangers*Evolve Tune*Genuine CSL rims*10mm Macht Schnell front spacers*modified Hamann bumper*Tekarbon 2X2 CF spoiler*Turner CF grills*AS SSK*KWV3*OEM Strut bar*Rogue RSM*Polyurethane anti-roll bar bushings*Deka ETX30L battery*Nav Video module*front & rear cameras*Ipod module*stubby antenna*R-Dash LED license lights*LED Ziza interior lights |
01-20-2017, 03:33 PM | #17 |
Rep 911
I am lowered on BC BR coilovers and get loud bangs on the rear only. From what I recall, this is usually caused by the pillow ball mounts on the shocks. I get the noise even if I raise it up 1". I'll point the finger on "cheap" coilovers.
example:
Andre - 2J into a Z4 Coupe!
filtercoffee106.00 |
01-20-2017, 05:56 PM | #18 |
Rep 139
Oh my goodness, the last notification I got on this thread was 15 days ago. Ever since I joined here the notifications have been crap!
Anyway, I'll try to find some time soon to reply to you guys. Thanks for the suggestions. |
