06-22-2021, 03:47 PM | #1 |
Rep 229
Rod Bearings
Greetings. Has anyone had the "courage" to install a new set of rod bearings themselves? If so, I'd like to read all about it. Thanks!!
Ted |
06-23-2021, 02:26 PM | #2 |
Rep 2,868
You can probably find more info on the e46 M3 forums. Here's one example:
https://nam3forum.com/forums/forum/m...4-rod-bearings |
07-02-2021, 06:53 AM | #4 |
Rep 12,312
Did mine towards beginning of the year. It's actually not a bad job in the Z4M because you get quite a lot of room. Just take your time. I used the DIY's that are floating around the internet.
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
07-02-2021, 11:41 AM | #6 |
Rep 12,312
Angle torque with a nice Snap-On torque wrench
Current:
07-02-2021, 12:00 PM | #7 |
10883
Rep 4,896
Don't forget to check your oil pump pressure regulator piston while you're in there
07-03-2021, 09:16 AM | #8 |
Rep 229
I have the CDI Torque & Angle 1/2 Drive version. Very similar to the Snap-On. I'll use it this weekend to reinstall the aluminum reinforcement plate under the Z4. Had to look for the nuts, bolts and sockets that disappeared ;~).
Also, did you use OEM bolts? Lift or jack stands? Thanks!! Guido, I've received the DLC-coated stainless steel piston from Burkhart in Deutschland. Alas, they didn't carry a replacement spring. |
07-03-2021, 02:56 PM | #9 |
10883
Rep 4,896
You could buy part number 11411706809 and compare if it's the same spring as in the s54 oil pump
This is a coil spring that is used in the oil pump of the euro e36 m3 3.0 and in the US e36 3.2 M3, and it's also the same spring as in used in most chain tensioners. It's a cheap part: https://www.ecstuning.com/b-genuine-...g/11411706809/ Be sure to use that strange torque procedure as described in TIS if you replace the conrod bolts (so 1x complete torque procedure for plastigauge, 1x complete torque procedure for prestretch and 1x complete torque procedure for final fitting)
