      08-08-2013, 12:30 PM   #89
seank
enthusiast
seank's Avatar
48
My 135mm crank pulley and 2345mm belt arrived today. That's fast and impressive for them to take care of the issue asap. Impressive to say the least. It will be installed today and I will give an update.
      08-08-2013, 05:13 PM   #90
seank
enthusiast
seank's Avatar
48
With the new 135mm pulley, it pulled 9.1psi on the first pull! Thanks George and ESS for being prompt to take care of it.
      08-08-2013, 05:45 PM   #91
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
daaamn! in what gear?
      08-08-2013, 05:49 PM   #92
seank
enthusiast
seank's Avatar
48
3rd at 7900 rpm's getting on the freeway. And I found that it was even higher in 4th.
      08-08-2013, 07:11 PM   #93
gmd2003
gmd2003's Avatar
352
Awesome Sean glad it worked out for you, I'm almost good to go as well.I just have to replace my original thermostat its sticking lol.... Overheated at idle , cooled flushed out the system and it was good to go, downside of running 100% water with water wetter you lose the lubricity of the antifreeze. Car is running strong though at full boost as well!. Dyno to come next Tuesday!
George
      08-08-2013, 10:29 PM   #94
ZStig
279
What size super charger pulley is on the 525? I want to check to make sure I have the correct size. There were a few additional parts, as well as some missing. I want to make sure someone didn't put the incorrect size in the box.
Did you figure out what size you have on the supercharger pulley?
My Vt2-500 kit lists the CRANK puller 5mm smaller, at 130mm. My supercharger pulley is listed at 3.33". I'd like to re-measure both tomorrow, I'm getting 1-2 psi lower boost in 3rd gear vs 2nd
      08-08-2013, 10:29 PM   #95
ZStig
279
George
Make sure its not your fan, mine was intermittent and then died. 70k miles on the clock
      08-08-2013, 10:30 PM   #96
ZStig
279
sean, you really need to go catless in section one, it makes a huge difference
      08-08-2013, 11:18 PM   #97
seank
enthusiast
seank's Avatar
48
Ours is the 525, not the 500.
I have measured both with calipers to confirm, but I now have what George said: 79mm supercharger pulley and 135mm crank pulley.
Beedub, said that his sc pulley measured 3.25" if I remember correctly.
Your saying that yours is 3.33"
0.22" converts to 5.588 mm which from my reading is a big difference in pulley sizes.
Mine and George's is 3.11". Btw, I am not sure if I should be worried, but I pulled more psi in 3rd gear: 9.6
Maybe I have the 570 kit
      08-08-2013, 11:28 PM   #98
seank
enthusiast
seank's Avatar
48
I'm sure it does but I don't need more than one cat less car. Btw, I told the misses that i would keep the car: stock, quiet, comfortable and civilized.
      08-08-2013, 11:54 PM   #99
Rated M Roadster
Rated M Roadster's Avatar
160
Drives: F10 M5, i3, Z4M
135mm and 79mm pulleys would spin the SC ~1000rpm faster (49000 vs 48000) than the 570 setup.
CURRENT ll F10 M5 l E85 Z4MR l I01 i3 REX
SOLD ll E70 X5M l E85 Z4MR VF570 l E36/7 Z3MR l E36 328i
      08-09-2013, 12:24 AM   #100
seank
enthusiast
seank's Avatar
48
Are you saying it is the wrong combo?
      08-09-2013, 12:26 AM   #101
Rated M Roadster
160
No, I'm saying you should get similar boost as the 570, maybe more.
      08-09-2013, 04:50 AM   #102
gmd2003
gmd2003's Avatar
352
George
I'm sure the return pipe from the radiator was cold despite water temps of 230 , when it popped back open temps went back down to 190's almost instantly , fan was running fine .
George
      08-09-2013, 04:51 AM   #103
gmd2003
gmd2003's Avatar
352
On 93 octane on a cool day we will be making over 450whp with this much boost !
George
      08-09-2013, 08:26 AM   #104
seank
enthusiast
seank's Avatar
48
Sweet.
      08-09-2013, 12:02 PM   #105
ZStig
279
how does the car feel sean? much stronger?
could you please post a pic of your intake setup?
      08-09-2013, 12:33 PM   #106
seank
enthusiast
seank's Avatar
48
Definitely stronger or more whine at 20mph, low rpm's. It feels amazing, beautiful and has me smiling.
I did not change the intake since I was dealing with the other stuff, like boost. Since, I am getting more boost now I probably won't do something as drastic as I was going to do.
I will definitely post pics of the construction.
      08-09-2013, 02:24 PM   #107
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
George
Hmmm... I thought they were designed to fail in the open position, with water cycling through the radiator. Might be a stupid question, but did you bleed the system after the flush?
      08-09-2013, 08:03 PM   #108
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
This is great news! Warp speed.
      08-09-2013, 08:51 PM   #109
seank
enthusiast
seank's Avatar
48
Scary in 4th at 6000 rpm's. Pulls like a freight train
      08-11-2013, 07:41 PM   #110
Finnegan
Finnegan's Avatar
Sean was kind enough to let me give his car a spin yesterday. Reactions: "wow", "holy cow", and uncontrollable laughter! Just driving normally, aside from a bit of whine, it's not there. But get on it, and the power keeps building and building. Sort of reminds me of the way power is delivered with the S65, but there's more here, and it's quicker and more intense.
Quite an unexpected treat to be able to give this car a spin, and the kit is quite amazing.
