      06-28-2013, 10:40 AM   #23
gmd2003
gmd2003's Avatar
352
Originally Posted by seank View Post
Thanks for the tip. It was rubbing on the strut tower.
No worries , if it can be f'd up or happen I've done it or seen it at this point
37 degrees Celsius , oh no the English are melting!!! LMAO
      06-28-2013, 12:15 PM   #24
Beedub
I will look at that. I just didn't notice it a few days ago.
BTW, it 37 degrees Celcius in Sacramento.
i reported the intake rubbin the hood issue long long ago.. however, much trial and error as found the perfect position where it doesnt rub at all... i'll take some detailed pics...... also helps having the stiffer engine mounts as the motor moves ALOT with the stock mounts, i was getting the p/s tank cap fouling the hood under extreme driving!!
      06-28-2013, 12:35 PM   #25
gmd2003
gmd2003's Avatar
352
I believe you pioneered the P/S cap condom mod
      06-28-2013, 01:16 PM   #26
Beedub
loooool!!!! i think it MAY have came from me
ive noticed it a few times in different peoples pics lol!!!
definitely stops any excess liquid spewage
i trimmed the cap slightly too to give additional hood clearance, this combined with the competition mounts have stopped the contact issue..
      06-28-2013, 01:30 PM   #27
seank
enthusiast
seank's Avatar
48
What's that? Pics please.
      06-28-2013, 01:44 PM   #28
Beedub
37 Deg C huh??? very jealous....
luckily my jamaican skin doesn't melt when it gets hot .... were used to it where i come from!! sadly ended up in cold ass UK.......
      06-28-2013, 01:47 PM   #29
Beedub
the relocated powersteering tank lid WILL foul the hood under the extremes of driving.... you'll notice it takes the paint off after a trackday or really hard driving, if you shave off the "handles" at the 3'oclock position it will alevate the issue, the condom mod stops the fluid spraying all over the engine bay... which it WILL do too!! lol!!
shaving the handles combined with the VT engine mounts have stopped any rub issues ive had, including the intake top..... ive had the ess s/c system in 2 different guises over a good number of years so, ive done lots of trial and error with certain parts...
for example the ess supplied hose that connects the air filter to the s/c intake is rubbish, it needs replacing, it spits, goes brittle and falls to pieces....
      06-28-2013, 02:01 PM   #30
seank
enthusiast
seank's Avatar
48
41 degrees Celcius this weekend. I am going to melt.
I guess I need to see pics of the condom mod. I do have some splattering going on and she hasn't even been to the track.
      06-28-2013, 02:27 PM   #31
Beedub
wait till you get it to the track..... it will spray everywhere.... drop the level slightly and get making one of these bad bois!! lol!!! ahahhahahah!!
      07-01-2013, 04:34 PM   #32
seank
enthusiast
seank's Avatar
48
P3 Gauge Installed. Boost and LC-1 to be installed next week.
Beedub's oil catch can on its ways.
What next? 3.93?
      07-01-2013, 05:00 PM   #33
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
What next? 3.93?
How about some cooler weather so you can see what the kit is really like? Record heat isn't giving you full power.
      07-01-2013, 06:17 PM   #34
seank
enthusiast
seank's Avatar
48
Tell me about it. I also found that it feels very regular with the A/C at full blast. A friend of mine said "that's it."
I said "yes, with a 90 degree day and A/C full blast" These 107 degree days is not working for me.
      07-01-2013, 06:30 PM   #35
Finnegan
Finnegan's Avatar
A/C puts a noticeable load on this motor. 115 (46 c) maybe by mid-week.
Your friend needs another ride on an October morning.
      07-02-2013, 12:06 AM   #36
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
Maybe 3.91 or perhaps even 4.10 gearing
We all need to escape to Laguna for the 60* degree track weather
      07-02-2013, 01:40 AM   #37
Beedub
Yup .... High heat and using the car hard will have you wondering??? What did I just spend all that money on???? They really drop off, the inlet to the intercooler literally hot to the touch.
      07-02-2013, 07:03 PM   #38
Krypptic
Drives: E92M, GT3
With that being said, is this setup really a good track option? I'm sure spirited driving on public roads would be fine, but 30 minute sessions in Florida are probably worse than Arizona due to humidity. Sorry to go off topic. Feel free to pm me.
      07-02-2013, 07:13 PM   #39
seank
enthusiast
seank's Avatar
48
That's not off topic. You can pm GMD2003, since he tracks the ess 525. If you look at his posts, he found the lower hp ess kit to be the best for track with out additional mods like the radiator he just installed.
BTW, it still makes more power than stock when its hot. It just seems noticeable to me more than when she was NA. I also just got it, so my foot is in it a little more also.
      07-07-2013, 03:44 PM   #40
seank
enthusiast
seank's Avatar
48
Why does the e46 m3 get as ess 550 option at 9psi and we don't? Its has to be only a slightly smaller pully.
      07-09-2013, 03:10 PM   #41
nekky
Wagon life
nekky's Avatar
Drives: '16 328d M Sport Touring
Yo, Beedub what did you use for the "condom"??
      07-09-2013, 03:49 PM   #42
Beedub
we put some work in today .... 30 deg C all day (cool i guess compared to usa temps) , no water temp issues, oil keep really stable... traction???? a problem....
      07-09-2013, 04:37 PM   #43
Beedub
prepare to laugh.......
ermmm....... its quite scientific....
i used a thick sock.
cut in it half, and use the top condom end.... works perfectly and stops you engine bay being covered in p/s fluid...
      07-09-2013, 05:22 PM   #44
seank
enthusiast
seank's Avatar
48
And a rubber band?????????
Why wasn't the 550 kit available to us at only 1 psi more??????
