      03-22-2014, 02:48 PM   #133
gmd2003
gmd2003's Avatar
352
Originally Posted by Beedub
we don't know for definitive that it is the walbro400 just because it looks the same and some dude on the internet says it is.......???? i will however concede it does appear to be identical to the walbro400 pics you posted even down the finite details... i believe the 340 can flow the same anyway and is a more reliable pump in general.... i would not call it a down grade...
also i agree the fuel setup is a nice design .. as id expect on and ///m car to be honest...
I would bet 1 million dollars it's a Bosch .Just bc the cap looks similar does not mean the pump is a Walbro . Not to mention people who run more than 550 hp have had to upgrade the pump due to inadequate fueling , Including ESS. The Walbro 400 would be plenty lol . BMW has never used anything besides a Bosch pump in any of their cars . Just bc one persons said it on a forum post DOES NOT make it true .
George
      03-22-2014, 03:31 PM   #134
tikamak
Lebanon
58
George
I just looked in the bosch catalog for Z4M 2006, it doesn't specify a fuel pump.
I'm pretty sure it's a walbro 400, even the base of the pump is wider than the top like the actual walbro 400.
      03-22-2014, 03:34 PM   #135
gmd2003
gmd2003's Avatar
352
George
All these pumps look very similar , you can't tell by the size and casing . At any rate for a VT -500 kit which you have and no hard track use a stock pump will be fine .
      03-22-2014, 03:39 PM   #136
tikamak
Lebanon
58
Yes I agree, when i will replace my fuel pump, i will cannibalize the casing and get to the pump and see what's written on it.
      03-22-2014, 03:42 PM   #137
tikamak
Lebanon
58
mmm, actually the fuel assembly part from bosch website looks different than the repair kit i bought from ecstuning.com
http://www.boschautoparts.com/Vehicl...part_num=69841
Maybe the repair kit is a walbro 400 and the one put in the car is not.
George do you have your old pump before the aeromotive swap ?
      03-22-2014, 04:20 PM   #138
tikamak
Lebanon
58
I think i'm on to something:
The bosch part on the link i gave earlier says bosch on it.
On the repair kit i bought from ecstuning it doesn't say bosch and the part number written on it is: 7 198 097 and assembled in mexico
While the part number on realoem for the fuel pump repair kit is 1 6 11 7 198 099
So i think that in the USA it was cheaper to install a walbro 400 so the original pump in the car might not be a walbro 400 but buying the repair kit from ecstuning.com, you would be provided with a walbro 400 intank fuel pump.
I would need to take pics once i replace my pump to see if my theory is correct. Till then, if anyone attempts to replace his fuel pump, post some pics in here so that we can get to the bottom of this.
      03-22-2014, 04:43 PM   #139
tikamak
Lebanon
58
There you go
ti automotive Fuel pump:
http://www.maperformance.com/ti-auto...f90000262.html
It was also clear to me that the housing has some breathing system inside of it that forbids fuel starvation.
The area where the fuel pump draws the fuel is a small confined space as if it represents a fuel surge tank.
When you installed your pump george, does the white casing in my previous image gets mounted horizontally or vertically?
And what does the couple of white tubes plug into? inside the tank? they could be used as a pickup from another "small" fuel pump as well that is not fuel pressure regulated.
I'm not sure if my english is correct in that last sentence but it's 12:00 over here.
      03-22-2014, 07:18 PM   #140
gmd2003
gmd2003's Avatar
352
Of course the pump can be anything from an aftermarket company . See don't put too much stock in one post as definitive fact lol. Anyway , yes the white plastic "case" acts as a surge tank for when the main tank is low/ in high speed turns . It does sit vertically in the tank .
George
      03-23-2014, 04:49 AM   #141
Beedub
Originally Posted by tikamak View Post
There you go
well.... the dude off the internet that told you the stock pump was walbro may have been right......
      05-23-2014, 12:04 PM   #142
07tundra
Drives: 8.1L Chevy 2500hd
Hey guys not trying to troll but when we 335i e90 went to start running e85 we started having problems with pressure and volume. So what we do is run a pump in line and leave the oem pump in place. I dont have the stock twins any longer I have a big single and I am able to run 100% e85 currently tuning so Im at only 18psi (500+whp).
The benefit of running inline is is that you leave the stock config of the bucket alone. The 450 walbro is e85 compatible and running it inline you will have more than enough fuel. The oem pump cant handle high e85 content so thats where the 450 walbro comes in and doesnt let it struggle.
There is a 255 inline kit out there but then you'd be running 2 non e85 compatible pumps.
Not sure if any of you would benefit from this or not? I know in our cars (e90x runs flawless plenty of guys hitting 600+hp on this kit. DME controls voltage many are running the stock fuse but you could go 1 step up from 20 amp to a 25amp. please feel free to txt me 505 908 4916 with any question. I am not a vendor so I am not stating that Im selling these but if you have questions txt me
2008 335i FFTEC ST 6266,), Boostbox, VRSF 3.5 exhaust, mtech front and rear, KWVll, APEX 18x9.0, 18x12= 305/35/18 NTO1s, BMS OCC, Rb PVC, M3 tri-color stitched S-wheel,MT SWAPPED, M3 LSD diff
2008 135i mods coming soon!
