      06-07-2011, 09:39 PM   #67
beta
Drives: 2006 M Roadster
Originally Posted by RobMCoupe View Post
I finally installed Euro headers and section 1 last week. Put about 50 miles on it so far. No CEL/SES code so far. My shop reset ECU and adaptation. No ECU tune. It is looking good so far. The real test is if it will pass CA smog later this year.
+1 Suscribed. I'd be very interested to know if you would pass CA smog with the full euro setup. I like keeping things OEM, and as I see it the original european spec is more OEM
      06-08-2011, 08:55 AM   #68
RobMCoupe
RobMCoupe's Avatar
60
Drives: 2007 Z4 M Coupe
I hear many E46 M3s passed smog with Euro specs. They all have some ECU tune. I will report back later this year when I am due for smog check.
      06-08-2011, 09:26 AM   #69
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
2 locals shops are having problems finding a 90* 02 bung, and think fabricating it will be pretty hard. Can anyone help?
      06-08-2011, 10:20 AM   #70
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
Great info in this thread!
I purchased Euro section 1 used. My shop used the original O2 sensors.
Where did you find a Euro section 1 and how much if you don't mind?
      06-08-2011, 03:02 PM   #71
RobMCoupe
RobMCoupe's Avatar
60
Section 1 for Z4M is hard to come by. I happen to run across it on this board from a UK user. The best route is to modify an existing US section 1.
      06-08-2011, 04:11 PM   #72
MPOWER78
MPOWER78's Avatar
Guatemala
Drives: 08 /// M
Were can i get a EGT bung, i'm going to do my headers soon . I got them form Diokaef.
      06-08-2011, 04:42 PM   #73
ZStig
279
looks like I found a 90 degree bung, not sure if the threading is universal
http://stores.channeladvisor.com/aut...temid=13552227
      06-08-2011, 04:46 PM   #74
johanness
Drives: 2008 Z4MC
Congrats!
So to be clear... the shop just 'unfolded' the needed length from the ECU or you used the original O2's that came with the Euro (longer) ones?
I'm under the firm belief that the cat-count of the Euro section 1's are different than ours (greater count, as it's their primary).
Any rasp?
      06-08-2011, 06:28 PM   #75
MPOWER78
MPOWER78's Avatar
Guatemala
Drives: 08 /// M
Originally Posted by johanness View Post
Just so everyone knows... Despite being what I consider the perfect install, I keep throwing a CEL related to 2C7E - Oxygen sensor after Cat trim control.
In the process of working it out. Car pulls like a banshee tho. Absolutely the best mod thus far.
It looks like your down strem o.2. sensors are too far down the the cat: convetor , and they are picking up unburned HC & CO . I am very confident if you move your o.2. sensor ferder down pass the ceramic interier your s.e.s. light should be fixed...
      06-08-2011, 06:50 PM   #76
ZStig
279
eh, screw it, I'll just get a blower and the tune will assure I won't have to spend money relocating the sensors
      06-08-2011, 07:11 PM   #77
johanness
Drives: 2008 Z4MC
When you lift/remove the heat shield, you will see the flat spots that represent the stock Euro locations for their O2's. That's why they were mounted there (much like others on this forum). It's clear to see where they 'should' go. Can you please expand on your idea so I understand where you're suggesting? Please use my pic as a reference.
      06-08-2011, 07:36 PM   #78
RobMCoupe
RobMCoupe's Avatar
60
Congrats!
Any rasp?
Just unfolded the original O2s. I'm not sure if you can call it rasp, but it has a distinct sound over 5k RPM. It sounds like stock during normal driving.
      06-08-2011, 07:41 PM   #79
MPOWER78
MPOWER78's Avatar
Guatemala
Drives: 08 /// M
I have seen others on the forums and the bungs are closer to the locations were i'm pointing at . your o.2. are picking up too much unbured gases ..becaues of the locations of the buns..
      06-08-2011, 08:06 PM   #80
MPOWER78
MPOWER78's Avatar
Guatemala
Drives: 08 /// M
some pics i found here..
      06-08-2011, 09:09 PM   #81
johanness
Drives: 2008 Z4MC
^^^ Hmm. I'm open to others comments about this before I commit to changing the locations of them. My only concern is that you can see exactly where they're mounted on the Euro Sec 1's.
Maybe Rob can comment on their location of his recent install?
      06-08-2011, 09:14 PM   #82
MPOWER78
MPOWER78's Avatar
Guatemala
Drives: 08 /// M
Ya , but or cats are not euro spec..
      06-08-2011, 09:21 PM   #83
MPOWER78
MPOWER78's Avatar
Guatemala
Drives: 08 /// M
one more..
      06-08-2011, 10:26 PM   #84
dorifto88
Drives: 88 Nissan Pathfinder
yes please, if rob could provide pictures of his section one and show exactly those o2 sensors go id super appreciate it !
      06-08-2011, 10:39 PM   #85
RobMCoupe
RobMCoupe's Avatar
60
I will try to get some pics this week. Have to go back to shop and put it on the lift. I had my section 1 at the shop for a month and don't remember the exact location. It was pretty far back and behind the cat. I'll try to get the pics by Friday.
      06-08-2011, 10:44 PM   #86
dorifto88
thanks. your car is at performance technique, right? I saw it there when my ssk was being installed
      06-08-2011, 10:52 PM   #87
RobMCoupe
RobMCoupe's Avatar
60
Yes, that was my car. I will get my Sromung this Friday and try to get it install the same day. Will get pics then.
      06-11-2011, 02:23 PM   #88
Blind32
Blind32's Avatar
Drives: '07 Z4MC
Great pics, Very interested in as many pics as I can get to show the exhaust shop I'm taking mine to.
