      10-26-2010, 05:57 PM   #45
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
Sure, I'll send Ronald an e-mail right now and see if it's possible. So just the two of you guys are requesting the threaded?
      10-26-2010, 05:58 PM   #46
dorifto88
Drives: 88 Nissan Pathfinder
this alone would totally make it all worth it for me haha
      10-26-2010, 06:02 PM   #47
mfanatic325
///M-fanatic
Taiwan
193
lol why? what shift knobs are you guys using?
      10-26-2010, 06:20 PM   #48
dorifto88
DSG Delrin Shift Knob
      10-26-2010, 06:22 PM   #49
mfanatic325
///M-fanatic
Taiwan
193
ahh interesting. Ball shift knob
I have similar on my MR2
      10-27-2010, 06:38 AM   #50
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
This is how I would do the breakdown using a 0-5 scale (0 being ridiculously low shift knob/base ; and 5 being half a foot in length above the shift boot)
stock E46 M3 shifter --> 4
stock Z4M shifter --> 4
Z4M + ZHP shift knob --> 3.5
Z4M +stock shift knob + AS SSK --> 3
Z4M + ZHP shift knob + AS SSK --> 2.5
stock s2k shifter --> 2.75
MR2 + sunk shift kit --> 0
Hope that helps =/
^Thanks.
In that case I'll probably go back to the stock knob.
...I'll see if there's a way to add a little weight to it.
      10-27-2010, 11:17 AM   #51
mfanatic325
///M-fanatic
Taiwan
193
Perhaps lead tape or somethin'? =P
      10-27-2010, 11:22 AM   #52
mfanatic325
///M-fanatic
Taiwan
193
Ronald says he needs specs for those of you that need threaded tops for your special shift knobs. Please PM me if you need those, so that I can let him know ASAP!
Also, he may hafta charge up to $20 more to ship kits outside of the USA.
RHD model will not be an issue. You're covered.
      10-27-2010, 11:46 AM   #53
onebluemcm
onebluemcm's Avatar
42
Drives: '07 Z4MC
^Thanks.
JB Weld can be a way to add weight as well if there is a void where the stuff can be poured in. I (some what shamefully admit) have an '89 Camaro that I put a different shifter in and it had a smaller diameter threaded end on it than stock. So, I just filled up the hole in the knob with JB Weld, drilled it and tapped it for the correct thread size and it worked out great, and added a bit of weight too. It may or may not work for our application, dunno because I've never had the stock knob off to see what it looks like.
<img src=http://i284.photobucket.com/albums/ll30/onebluemcm/RG63_08-1-1.jpg border=0 alt= />
|=.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-.=|
Silbergrau A08 / Sepang Brown LSD6 / Carbon Leather 4MY (1 of 3, this combo)
RAC RG63 | Conti EC-DW | GC/Koni-Dinan | Rogue RSM | Arqray | Autosolutions | BMW brace | Pinnacle tint
      10-27-2010, 12:53 PM   #54
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
No problem; I assume that will be sorted via email from Ronald?
      10-27-2010, 01:33 PM   #55
mfanatic325
///M-fanatic
Taiwan
193
Yes, I'm assuming that he will go through the list of everyone's contact info and proceed to collect funds thereafter.
But I'm pretty sure he won't start requesting funds until AFTER the kits have finished production and are ready to be shipped out.
      10-27-2010, 02:42 PM   #56
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
FYI.. Autosolutions has a lot of interesting info on their website
      10-27-2010, 03:00 PM   #57
mfanatic325
///M-fanatic
Taiwan
193
Yeah they're pretty well known company with lots of experience, so I trust them wholeheartedly.
      10-27-2010, 03:49 PM   #58
mfanatic325
///M-fanatic
Taiwan
193
This was Ronald's response in regards to the threaded top request:
That's not a problem but I cannot guarantee against breakage at or above the threaded area. the standard shaft is approx 15mm in diameter. For a shift knob to safely work you would need the threads to be used strictly for retaining the knob and not to be subject to shear. I.e you would need the knob to apply force to the 15mm shaft and not to the threads. Thus the knob in question must be checked for dimensions that would allow the force to be applied to the 15mm shaft. please remember that the outer lever is 6061 t6 aluminium and not steel.
Hope that explains my position in this regard.
I told him that you guys wanted 10x1.25 thread pitch, at 1 inch length down from the top tip of the lever.
Diokef and Dorifto, please let me know ASAP if you guys still want to proceed with the threaded request. All these need to be sorted out before Ronald can go ahead into production.
      10-27-2010, 06:56 PM   #59
Z4-VILLA
Afghanistan
111
Drives: Z4M Hardtop Roadster
i want one but im still not sure. i dont want play i know thats for certain.
      10-27-2010, 07:08 PM   #60
mfanatic325
///M-fanatic
Taiwan
193
The GB list is filled right now anyway, so you'd have to wait to see if someone doesn't pay up. Then you could probably take the opening spot =P
There was absolutely no play in the shifter when I test-drove. It was actually so solid that it felt tight. I know we all like that tight feel >_^
As for the threaded tops, we've all decided to not take any risks and just go with OEM-style shift knobs instead
      11-03-2010, 11:01 PM   #61
Z4-VILLA
Afghanistan
111
great im the loser that showed up late...:-(
      11-03-2010, 11:26 PM   #62
mfanatic325
///M-fanatic
Taiwan
193
LoL I could've sworn you already knew about it? =P
      11-04-2010, 08:47 AM   #63
Z4-VILLA
Afghanistan
111
yes....i competely f'd this up.....
      11-06-2010, 01:23 AM   #64
mfanatic325
///M-fanatic
Taiwan
193
So unfortunately we're slightly behind schedule. Ronald informed me of production plans this upcoming week instead of this past week
I'm kind of antsy to get this kit in my car as I'm planning on tracking the car more and more.
Please bear with me guys! I want this to be finished and ready just as much as anyone, if not moreso
      11-06-2010, 02:32 AM   #65
Z4-VILLA
Afghanistan
111
i spoke to him this morning, i already sent payment.....
      11-06-2010, 03:21 AM   #66
mfanatic325
///M-fanatic
Taiwan
193
Wait what?! So he's making more than 10? Cuz as far as I know, everyone on the GB list plans on paying up whenever they're ready.
