      08-11-2014, 05:05 AM   #1
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Removing track day rubber from paint
This may be something that you guys have already discovered, but I found a new (to me) easy way to get track rubber off the paint.
I had been doing the clay bar thing up to now, but found it painfully tedious.
I happened to have a spray bottle of citrus degreaser sitting on the bench (bought for another purpose) and thought; what the hell, & gave all the rubber marks a spritz to pre soak.
....also zapped all the glued on bugs.
I was surprised when I started washing that the rubber lifted right off with little to no extra effort.
Turned my track day cleanup into little more than a normal wash
The product I used was just a generic citrus degreaser that I picked up at Home Depot.
      08-11-2014, 08:09 AM   #2
Mirko
Mirko's Avatar
interesting .. will have to look into .. thanks
      08-11-2014, 08:22 PM   #3
Krypptic
Drives: E92M, GT3
I can confirm. I used Goo Gone and it made the job much easier.
      08-11-2014, 09:07 PM   #4
Steeler
Steeler's Avatar
2429
We used to smear Vaseline on the rear quarters during my drag racing days.
Bit messy but nothing stuck. Might not be the best idea thinking about it if it were to get on the tire tread
      08-11-2014, 11:14 PM   #5
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Will the citrus degreaser strip your wax as well?
      08-12-2014, 04:47 AM   #6
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Not sure, Probably, but so does clay bar.
I always put on a fresh layer of sealant prior to a track day. (I don't use wax)
      08-12-2014, 12:32 PM   #7
jmillet
jmillet's Avatar
64
I find that the Mr. Clean Magic Eraser with lots of lubricant like Final Inspection, Quick Detailer, or concentrated car wash soap takes track rubber off without a swirl or scratch. Use light pressure and rub gently; magically the track rubber disappears.
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red
SOLD: 2007 BMW Z4 M Coupe Imola Red
      08-16-2014, 06:10 AM   #8
DerekSelmanRacing
DerekSelmanRacing's Avatar
Drives: 05 Z4 3.0 SMG, 01 530
I use Turtle Wax bug and tar remover. Let it soak awhile.
      09-14-2014, 09:32 PM   #9
sipman
Drives: 2007 Z4MC
check out mothers R8. supposed to be for track worm mark removal.
      09-24-2014, 08:59 PM   #10
BookerM3
BookerM3's Avatar
Drives: Z4 M Coupe
Spray nine also works...
      09-24-2014, 09:51 PM   #11
papak
Drives: 2008 Z4 3.0si Coupe
WD-40. It is about 1 molecule away from kerosene. No paint damage and it removes the stuff easily. Old concours trick. You could also use 3M Adhesive Remover. That works well also. I keep both on the shelf.
