03-18-2013, 04:51 PM | #1 |
Rep 247
Help..Will these fit??
I found a set of VMR v710s...
Front: 19 x 8.5 et 35 Rear: 19 x 10 et 38 will these fit on my MC with H&R springs installed without rubbing>>>??
| 2008 Interlagos Blue Z4MC | | AA Tuning | RPI Scoop | H&R Sport Springs | Sportline CS 16 CSL Wheels | Magna Flow Custom Exhaust | |
03-18-2013, 05:00 PM | #2 |
Not a New Member
94
Rep 925
you'll need a 13mm spacer in rear. front is perfect.
03-18-2013, 05:19 PM | #3 |
Rep 247
Is it bad to use spacers? I'd rather not but I think I can get a good deal on these wheels..
Now with that spacer added..I'd have to buy longer studs?..I'd like to use a stud conversion kit..
03-18-2013, 05:31 PM | #4 |
Not a New Member
94
Rep 925
i wouldn't say "bad"... maybe "not ideal" is more appropriate.
this would be an excellent opportunity to move over to a stud conversion. just remember that not all shops will have an extra-deep socket to get them off, so maybe get one of those as well and keep it in the car.
03-18-2013, 05:47 PM | #5 |
Rep 247
how do I know what length studs to get?
03-18-2013, 05:54 PM | #6 |
Rep 1,443
Also, be prepared for some places to refuse to work on your wheels/tires if you have a lug stud conversion. This happened to me recently at Discount Tire/American Tire. Not a big deal. Just keep in mind that, unless you find a shop that will (which I'm sure would be pretty easy) you'll have to transport the wheels to them for mounting/balancing etc.
03-18-2013, 06:00 PM | #7 |
Rep 247
Yea, I just have my local shop mount and balance, I like to do the work myself..
I just don't know how I feel about using spacers and rubbing in the rear.. Deciding on a set of wheels is turning out harder than I thought...
03-18-2013, 07:51 PM | #8 |
#dubspec
6328
Rep 5,200
Don't sweat it. If you get a 12mm spaced in the rear you will be fine. Burger tuning has spacer and longer bolt kits that are excellent quality. Nothing wrong with spacers or longer bolts.
Here you go http://www.ebay.com/itm/12MM-BMW-Whe...56c754&vxp=mtr
03-18-2013, 07:55 PM | #9 |
701
+1. 12mm spacer will have a hub-extender. Issues with spacers come in when something like a 10mm spacer that doesn't have a hub extender. With the right hardware and a good spacer (and good install) there isn't anything to worry about.
03-18-2013, 08:01 PM | #10 |
Rep 247
Sweet thanks for the info...I'm waiting to see if this guy accepts my offer..
03-20-2013, 04:37 PM | #11 | |
Rep 1
