      03-11-2013, 04:26 PM   #1
sadar
Drives: Z4M roadster
E46 M3 gearbox into a Z4M
Has anyone tried this swap seeing that the Z4M gearbox is so troublesome on the 2nd gear - gearshifts ?
Will it even work ?
2007 Z4Mcoupe - track car.
      03-11-2013, 04:39 PM   #2
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Won't fit into the tunnel
      03-11-2013, 05:00 PM   #3
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
Yeah otherwise we would've had them already
You can reduce 2nd gear grind by any or all of the following ways:
1) upgrade the transmission mount bushings
2) install a short shift kit such as AutoSolutions
3) learn to shift correctly
For #3, I don't mean it in a derogatory way, but rather a serious tone. It has been discussed that for our transmissions, pulling straight down into 2nd is not the correct way to shift. Instead, put more force towards the left while pulling down. Try to keep your shift action short, precise, and crisp. No right-hand jerks
      03-11-2013, 06:04 PM   #4
RobMCoupe
RobMCoupe's Avatar
60
Drives: 2007 Z4 M Coupe
E46 M3 have similar problem with 1>2 shift. What works for me is don't force it into second. Give it a little pause help smooth out the shift. Also VibraTechnic engine mount along with others mention help a bunch.
      03-11-2013, 06:23 PM   #5
beta
Drives: 2006 M Roadster
The reason we got a different gearbox than the e46 one is because that one didn't fit. I wouldn't expect you to be able to fit it for a reasonable cost if BMW gave up on the idea.
The only real thing that helps the grinding so far is the vibra technics engine mounts.
I'm not convinced stiffer transmission mounts help that much, but I don't have them installed so I cannot say for certain.
I don't think SSK helps either, I do have that installed (and it's worth every penny, just not for fixing grind).
I'm hoping that vibra-technics makes us a transmission brace. That + engine mounts has a real possibility of fixing the grind (or at least making it so you have to slam the transmission into second to have a problem). Read the thread I linked for more info.
Other than that, search the forum. This topic has been covered 5 million times. The current best answer is what Rob says above: learn how to do a heartbeat pause between 1st and 2nd.
      03-11-2013, 06:53 PM   #6
bignosejim
bignosejim's Avatar
Drives: 2007 IB M Coupe
Here's another vote for the Vibra-Technics engine mounts. Not only does the car shift sooo much smoother, but when you hit the gas the car just goes. They are worth the cost and are the best mod I've done to the car (and I have the AS SSK).
      03-12-2013, 06:29 AM   #7
Beedub
seriously agree!!!! Theyve made a huge difference to my car!! HUGE!!
      03-12-2013, 07:31 AM   #8
sadar
I've changed to stiffer transmission mounts , but still have gear change issues.
I must try these engine mounts.
But what is actually the problem ? can the gearbox be modified (by opening it up) to stop this behavior ?
The denial and popping out of gear, from 3rd down to 2nd really grates my sack.
      03-12-2013, 12:48 PM   #9
beta
More than likely it's the amount of rotation between gear box / engine under acceleration or hard cornering. Only way to make sure though is to wait for vibra to make us a brace. If that still doesn't solve it, it means it's an issue with the gearbox itself.
The 3->2 denial AFAIK is fixed with stiffer mounts + engine mounts. It's the 1->2 that's better, but not completely fixed.
      03-12-2013, 01:05 PM   #10
mfanatic325
///M-fanatic
Taiwan
193
It's odd because I only have tranny mounts + the AS ssk and I've never had 1st to 2nd grind nor 3rd to 2nd rejection, even at the track. Maybe you really just have to slow down your shifts and/or gently guide the lever into each shift gate?
      03-12-2013, 01:12 PM   #11
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
IIRC vibra stated that there was not a lot to be gained with a new trany mount.
The multi axis OE design is pretty good.
I'm looking forward to getting my vibra's installed to see just how good they are.
      03-12-2013, 08:35 PM   #12
bignosejim
bignosejim's Avatar
You won't be disappointed!
      03-20-2023, 08:54 AM   #13
dre99gsx
Drives: 1994 Toyota Supra
10 years later...
I'm not sure how much longer my OEM 6spd is going to last with the abuse I am putting on it, but my only reasonable upgrade would be the E46 transmission.
Instead of relying on anecdotes, has anyone *tried* to install one in the z4 chassis? Any data on why it doesn't fit? Too long/too short, hits the tunnel in some particular spot, etc?
Can it fit with some minor fab work and not tear apart the tunnel completely?
      06-08-2023, 10:24 AM   #14
Terraphantm
Drives: E46 M3 Coupe
I’m not convinced it wouldn’t fit, but I haven’t seen anyone try.
There are other upgrade possibilities such as the n54 transmissions, but would require some additional modifications.
      07-09-2023, 12:56 PM   #15
///Mcoupe
Drives: 2007 M Coupe
I don't believe it doesn't fit, BMW said the 6 speed doesn't fit in the 2001-2002 z3m and they put the 5 speed, that was a lie , it fits.
I think BMW lied again as the ZF they put is cheaper than the Getrag 420 of the M3.
There is a shop in south africa that has a 1400 whp turbo z4m coupe and they put the 6 speed from the M3 in it.
      07-09-2023, 02:24 PM   #16
Willy Sea
Drives: BMW M Coupe S54, E36 M3 Evo,
Correct, but with an unbelievable amount of fabrication work, to the firewall and floor as the getrag is a wider transmission, and shorter too. Remember the M3 is a wider car and you sit on the floor pan. Our beloved E86 chassis we sit within.
We have a S54 Z3MC, E46M3, E86MC and E86 3.0si and never experience any issues with shifting up or down, the proviso here is: the engine and gearbox must be up to operating temperature. From cold, yes, can be baulking a little. Royal Purple or Redline oils may assist here, various race shop technicians swear by these products to solve the issues discussed above.
