      02-11-2013, 09:53 AM   #1
Bad_Pritt
Bad_Pritt's Avatar
Belgium
Drives: Z4R E85 2.2i
Red symmetrical taillights: MOT-proof!
Found this how-to on a dutch forum actually. So here's a quick translation for you guys! (sorry if this a re-post)
This is an easy mod for this type of tail lights:
So the problem is that the single reversing light is no longer white. However, the indicator glass is still clear and could be used both as an indicator and reversing lights. This way you can do a fun mod: install TWO reversing lights and TWO rear fog lights!
What you need is a small round led light that you can fix on top of the indicator light holder:
On the holder of the reversing light, solder the red and black cable of the led rings:
It should look like this now:
And the final result (he only did one side):
I'll give this a go myself if I can find the right parts!
      02-11-2013, 01:38 PM   #2
Bad_Pritt
Bad_Pritt's Avatar
Belgium
OK... seems to be a little harder than I thought it would be. The holes for the indicators are pretty small. No way to get those rings in there... I'll have to look for an alternative with smaller superbright leds. The story continues!
      02-11-2013, 01:45 PM   #3
psygnosis
psygnosis's Avatar
23
Drives: '04 Z4 3.0i Sport
on US cars, there are two reverse lights and for 2005 all four circles are white
      02-11-2013, 03:29 PM   #4
Bad_Pritt
Bad_Pritt's Avatar
Belgium
Yes, I've seen it before...might be easier to convert to that...
      02-12-2013, 09:17 PM   #5
Z@T
Pilot
Z@T's Avatar
Drives: M3, Vantage, 997, ModelX
This doesn't work for the US
Over here are both inners are clear as well. You can't even order the British one from the US.
I ordered the British one in Germany and bought a German one for the other side. I had the vendor let both ship to Florida. Worked perfect and I'm probably the only one with a setup like that.
