      05-21-2012, 10:20 AM   #1
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
Power steering fluid spilling out
When I run my car hard, the power steering fluid comes out of the little vent hole in the cap. I've noticed beedub put a sock on his. What do you guys do? Should I get a non-vented cap for the track?
      05-21-2012, 11:26 AM   #2
The HACK
The HACK's Avatar
1821
Wipe it clean, refill with fresh PS fluid when low. This way you don't even need to flush the power steering fluid!
      05-21-2012, 02:36 PM   #3
Shipkiller
Shipkiller's Avatar
Drives: Me
Never had this issue. I keep mine at the Max fill line.
Just came off of three days at VIR and this NEVER happens... I wonder if there is another issue?
      05-21-2012, 03:36 PM   #4
ZStig
279
      05-21-2012, 04:01 PM   #5
seank
enthusiast
seank's Avatar
48
I have had this issue with every BMW i owned---for track use. I put gasket sealant on mine. Just seal it up once a year when I check the fluid. Some use a sock, like a friend of mine who tracks his new M3 on Hoosiers. Quit pulling so many G's is another option.
      05-21-2012, 04:12 PM   #6
Beedub
tom, if you drain a small amount out then put cut down some material to place over the p/s unit it will completely stop any further issues, drive hard enough OP and you WILL get this issue, the stock car does too but you just cant see the mess!! lol, heres my solution OP !!
      05-21-2012, 04:14 PM   #7
Beedub
tom this will completely stop any spilling issues you have, Every bmw ive had does this once the fluid warms combined with the swilling around it comes out the vent hole, dont get a non vented cap however the system is designed to run vented, just drain alittle out, run alittle cap and you wont see even a mist from it :-) promise!!
      05-21-2012, 11:21 PM   #8
ZStig
279
I can't, I have a fighter pilot style helmet
I'll make a furry condom type thing for racing. Just made this thread for other ideas
      05-21-2012, 11:24 PM   #9
ZStig
279
beedub, why are your strut towers white? Shouldn't they be black or body color?
      05-22-2012, 12:47 AM   #10
Beedub
Tom their silver the sunny day combined with the flash makes them look white...., I wish BMW would properly finish the paint on the engine bay area!!!
      05-28-2012, 12:36 AM   #11
ZStig
279
Found a solution that SHOULD work. Haven't track tested it yet. I found a very small fuel filter, and stuck it into the spill-over hole. Now it will soak up any small overflowing spills AND it breathes well, and is only about 1" long.
      05-30-2012, 11:24 AM   #12
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
good idea
be sure to update after track test
      05-30-2012, 11:35 AM   #13
ZStig
279
Hoping to run it June 10th. You could also put a piece of black electric tape over the top of it to blend it in better, it would still vent on the bottom
      05-30-2012, 03:26 PM   #14
beta
Drives: 2006 M Roadster
I'm curious if this works out for you, please update and post a link or part number when you get a chance to try it out.
      06-01-2012, 05:22 PM   #15
Beedub
tom im pretty certain that wont work......
your best of draining alittle fluid and using the sock method!, its tried and tested !!! your little filter thing will end up like a condom full of sperm just waiting to burst and ruin your day......
lol..... was that the most graphic explantion on overflowing p/s tanks EVER???
      06-01-2012, 06:05 PM   #16
ZStig
279
I expect it to fill up, and slowly drip down. The membrane should keep the flow out much lower than without it, leaving minimal cleanup compared to the oem option of spraying shit everywhere. BUT, let me test it at my next autocross before we make any conclusions
      06-01-2012, 07:34 PM   #17
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
We have a winner!
      06-02-2012, 05:30 AM   #18
Beedub
Originally Posted by Finnegan View Post
We have a winner!
lol!!!
      06-10-2012, 06:54 PM   #19
ZStig
279
ok ok the filter didn't work. It still sprayed THROUGH the filter at the race today. I'm gonna make a little catch can
      06-11-2012, 02:23 AM   #20
Beedub
told you.
Why a catch can?? drop the level slightly make a sock and job done!!! Simple is Always best.
      06-11-2012, 10:46 PM   #21
ZStig
279
told you.
hey, if it worked as a way to slowly release pressure from there and just drip down, it would have been a great solution. I like testing new ideas =)
I don't mean a full can, just a small container with a line coming out of it. I'm probably overthinking it, just need a damn sock for the race days
      06-12-2012, 02:52 PM   #22
Beedub
let me tell you something, if you really want to help your car run better, run a catch can....... if you take off the plastic s/c outlet you'll be shocked by what you see, these car running Fi MUST have a catch can, your loosing valuable octane points but the blow by being ingested...
Re the powersteering tank just lower the level, make a little sock like i did, job done, you wont get a single bit of spray or mess!!
