      02-09-2017, 11:24 AM   #265
3002 tii
3002 tii's Avatar
2288
Originally Posted by xxrando View Post
I'm fitting 225/45/18, 255/40/18 on my 3.0si roadster with stock 8/8.5 wheels and sport suspension. Right now, it bottoms out going in/out of my driveway on stock rubber.
I'd like to get a more flush look as well. Will 12/15 work with the taller tires without rubbing?
Like you said you're dealing with a height (too tall) issue, not width. Your tires are nearly an inch taller than the stock fitment of 225/40 and 255/35. So if you're rubbing now it'll probably be worse with spacers.
Follow for latest mods
      02-10-2017, 01:30 AM   #266
xxrando
xxrando's Avatar
Drives: 2006 Z4 3.0si
Sorry, I wasn't clear. I will be upsizing to keep the UNDERCARRIAGE from scraping on the CONCRETE. My driveway has a steep crown! Using the stock M size rubber (225/45 and 255/40) will lift it a half inch. I don't have any rubbing (tire on fender/liner) now and assume the M guys don't have rubbing issues with stock tires either.
The question is can I run the taller M tires with 12/15 spacers to get a flush look and avoid rubbing.
      02-11-2017, 07:55 PM   #267
E86Z
Drives: 3.0si
Isn't upsizing an issue for the differential and speedo accuracy?
      02-12-2017, 09:26 AM   #268
christophertemple
Drives: 2004 Z4 E85 3.0
2004 Z4 Non-M - Stock suspension
Sharing ...
19x8.5 ET38 (235/35/19) - Rubs a little on big dips, should go with 225/30 instead
19x9.5 ET45 (265/30/19) - No issues
Wheels are MRR GT-1's $150.00 each shipped. Great deal from this Ebay seller.
http://stores.ebay.com/aspiremotoring/
      02-12-2017, 08:37 PM   #269
xxrando
xxrando's Avatar
I had the 5% taller profile tires mounted and I did a speed check today on the highway. It looks like the speedometer is between 0 and 1% under-reporting compared to GPS.
Speedometer: 70mph
GPS: 31.3 - 31.6m/s = 70.0 - 70.7mph
It looks like there should be enough room to move the wheels out flush without rubbing. Hopefully someone who's converted to the stock M size tires can comment.
      02-12-2017, 09:32 PM   #270
E86Z
Drives: 3.0si
Speedometer: 70mph
What size were/are you running?
      02-13-2017, 02:04 PM   #271
xxrando
xxrando's Avatar
It was previously stock 225/40/18, 255/35/18 and is now 225/45/18, 255/40/18.
      02-14-2017, 10:08 AM   #272
3GFX
3GFX's Avatar
Drives: 2003 BMW Z4 3.0i
This shouldn't be an issue, it's not a wild change by any means. Suits the needs of your goals.
I do believe that the suspension and finders are different on the M as that version of the Z can accommodate wider tires and offsets compared to ours.
      02-20-2017, 09:15 PM   #273
RichZ4
Drives: Z4 coupe 3.0si
I've read this thread three times and I'm still confused.
Which size offset CSL replica 19s will work without spacers and will not rub on a 2007 3.0 si coupe?
Which brand is better than another Sportline? VMR? Avant garde? The threads I'm reading on this subject are 5 years old I can't find anything current.
Thanks in advance.
      02-21-2017, 05:35 AM   #274
Mercurien
Drives: Z4 E85 2.5I
Originally Posted by Mercurien View Post
Hello guys !
I need some advice on wheel fitment. I have an 2.5i and will be installing bilstein B12 kit which is about a 30mm drop. I will be running 17" JR9 wheels with 225/45 tyres all around.
Do you think that I can run one of this setup without rub or have to add camber ?
- Front : 225/45/17 7.5X17 ET25 or ET35
- Rear : 225/45/17 8.5X17 ET20 or ET25
Thanks everyone!
UP ?
thx
      03-19-2017, 05:32 AM   #275
MainThink
Drives: 2007 E86 Z4 Coupé
Hello everyone!
Like Rich two posts above I've read everything a couple of times and not found an answer...
I recently bought a 2007 E86 with M sport suspension (S704A) and standard star spoke 200 17" wheels, 8Jx17 ET46 with stock 225/45/17 winter tires.
This summer (that is... like... now ) I wish to buy a set of 18" BBS CH-R's; their configurator is telling me:
- 8Jx18 ET40 225/40 front
- 9Jx18 ET44 255/35 rear
Does it sound correct thus I can trust the configurator? I don't (yet?) have enough experience to judge, especially the offsets.
Thanks!
PS: first post hype!!
      03-28-2017, 08:20 PM   #276
imported_mega
No_Country
123
Drives: various bmw's
I've read this thread twice and it's hard to find much on square setups for a 2006 3.0i roadster
I'm looking at 225/45/17" tires, are a 17x8 et38-40 and a spacer in the back a reasonable compromise? considering beyern aviatic in et35 if it'll fit pretty reasonable price it's my kids car so cheap is good but tire rack does not have much of anything I would trust in that size
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
Driving e82, e72, e85, R53 Gone but not forgotten..
1974 2002, many various 3s.
      03-29-2017, 02:15 AM   #277
StigJ
StigJ's Avatar
Norway
333
Drives: '06 Z4 Coupe & '14 F30
For the fronts:
If you want the wheels to sit more flush you can even go down to ET30 if you are running 8" with 225/45. So 8" ET35 is safe. My 8,5" ET34 pokes 6mm more than that setup. I have no issues.
Please don't comment the look of the following wheels They are only my storage wheels. Got them for free and are ugly as...
7,5x17 on all 4. Fronts are ET40 and rears are ET20. 205/50-17 Toyo-something tires.
8" ET35 poke 11mm more than this.
Even had 9x19" ET44 as square setup once. A little rub in the front. But that would have been fixed with 225/35.
Regarding the rears you can easily put on 15mm spacers for the 8" ET35.
      03-29-2017, 06:30 AM   #278
imported_mega
No_Country
123
my goal is same size wheels front/back so I can rotate the tires
      04-05-2017, 10:20 AM   #279
nate96
Drives: TI Silver 06 Z4 Coupe
After reading this thread a few times I finally made a decision on wheels and fitment. My previous setup was 19x8.5 ET35, 19x9.5 ET40 wrapped in 235/35 and 265/30. It sat really flush but there was rubbing on the fronts.
New Setup:
Wheels:
Vertini RF1.2 – Black Tint Face
Fronts: 19x8.5 ET 40
Rears: 19x9.5 ET 45
http://vertiniwheels.com/Wheels_P43%20RF1.2.html
Tires:
Toyo Proxes 4 Plus
Fronts: 225/35/19
Rears: 255/30/19
There is no rubbing whatsoever. The smaller tire made a huge difference. I also think I might be able to do a 5 or 10mm spacer to get more flush. Still on the fence about it.
I need to get some better pics but this gives you an idea.
      04-05-2017, 12:15 PM   #280
3GFX
3GFX's Avatar
Looks good, but how come you didn`t go 265 in the rear?
      04-05-2017, 12:41 PM   #281
nate96
The place where I ordered everything from would not honor the guaranteed fitment policy going with a 265. Although I know they would fit with no issues I have had problems in the past with wheels not fitting correctly and had to return them. I didn't want to take the chance on these. 265 on the rear would have given a better OD fitment to the 225 but a few tire companies didn't recommend going with a 225 front and 265 rear.
      04-05-2017, 01:12 PM   #282
3GFX
3GFX's Avatar
I know the options are limited on the 265/30/19 but good to know.
      05-05-2017, 11:26 PM   #283
miscbrah
Drives: Z4 3.0si
I think I have the answer but can anyone confirm:
18x8.5 ET35 all around will work? 3.0SI roadster
      05-08-2017, 09:23 AM   #284
3GFX
3GFX's Avatar
Yes. But you're going narrower than stock on the rear and why would you wanna do that?
      05-11-2017, 04:55 AM   #285
Twixboy
Drives: '04 Z4 3.0i 6spd
Sharing ...
Good price; did you just re-use your old BMW center caps? One issue I have w/discount wheels is whether or not the BMW center caps will fit or not. It usually doesn't say!
Does anyone know if there a list anywhere of brands that accept the OEM center caps? I ran into this problem with a set of winter wheels I got for my Audi Q5. I bought every size center cap I could find off ebay and none of them fit. I don't want to run into this issue for the Z4 since it's a far more beautiful car and not just a family hauler
      06-07-2017, 11:31 AM   #286
miscbrah
Drives: Z4 3.0si
How so? Isn't stock rear8.5" on a 3.0si?
