      08-10-2023, 06:23 PM   #1
FullVanos
FullVanos's Avatar
Drives: E46 M3
Bilstein B16 (PSS10) Coilover Kit
Like new B16 kit that has less than 3,500 miles. They worked very well and put the exclamation point on Z4M's great handling and chassis rigidity. Only selling as I'm putting my coupe back to stock to sell it.
Save yourself the time and hassle of having to deal with a spring compressor. These come with strut mounts so they are ready to swap in.
Asking $1,800 and located in SoCal. Will ship at buyer's expense. They are securely packaged and ready to go.
"The engineers at BILSTEIN have created the ultimate race inspired suspension: The BILSTEIN B16 PSS9/PSS10. This innovative suspension system delivers unsurpassed driving performance. The manually adjustable damping mono-tube gas shock absorbers feature 9 or 10-stage precise compression and rebound settings, from comfort to competition. The threaded body allows accurate adjustability of the front and rear progressive rate springs to achieve the vehicle ride height, center of gravity and level of performance handling desired. The Bilstein B16 system puts you in complete control, providing the kind of precise suspension tuning formerly available only on race cars. From a weekend of competition to daily driving, this system provides perfect handling performance for every situation.
Features and Benefits:
-Individual settings ranging from maximum Comfort to aggressive Sport can be selected by the twist of a dial (9 on PSS9, 10 on PSS10)
-Threaded body adjustable range of 20 mm at both axles
-Lowering of approx. 30-50 mm at front and rear
-Road-tested and fine-tuned by BILSTEIN ride engineers, under extreme motorsports conditions
-Spring plates and lock nuts made from a special aluminum alloy Surface coating using Triple-C-Technology for long-lasting corrosion resistance
-This kit is designed to fit E85 Z4 M Roadster and E86 Z4 M Coupe (2006, 2007, 2008)."
      10-03-2023, 10:10 PM   #2
FullVanos
FullVanos's Avatar
Drives: E46 M3
To the top
      10-16-2023, 02:58 PM   #3
FullVanos
FullVanos's Avatar
Drives: E46 M3
Boxed up and ready to go out. If you’re interested in getting a shipping quote the dimensions are 43”x20”x8” and it weighs about 70lbs.
      10-16-2023, 09:00 PM   #4
maupineda
Drives: E86 Z4MC
If I could get the certainty these would be better than my current setup, i would get them off you.
Anyone with first hand experience on how this good, or bad ride?
      10-23-2023, 05:03 PM   #5
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
What is your current setup? I have these installed on my Z4MC with Vorshlag camber plates and spring perches and it does a good balance of street and fun driving. Replaced a set of KW Clubsports that were dreamy on track and rubbish on the street. Definitely recommend the PSS10 over stock.
You have to spend 2X+ to get any marginal improvement
      11-13-2023, 03:16 PM   #6
FullVanos
FullVanos's Avatar
Drives: E46 M3
Still available, boxed and ready to go on your Z!
      11-13-2023, 03:53 PM   #7
amcp
Drives: Z4 M coupe
PMed
      11-28-2023, 11:41 AM   #8
FullVanos
FullVanos's Avatar
Drives: E46 M3
Let's get these sold. Lots of interest but no one has come through after the shipping quotes (at most $175).
