      09-01-2020, 07:50 PM   #1
MadGus
Drives: 2006 Z4MR
2006 BMW Z4MR  [0.00]
Where on the E85 S54 engine is this??
Very detailed report from indie who basically did a full PPI for free before doing the alignment I paid them to do.
They are saying that I have a VCG leak on the rear of the engine, but I can't figure out where this picture is taken from!
I rebuilt the vanos this past winter and did the VCG and valve adjustment and plug replacements while she was open. I didn't RTV the rear half moons on the replacement gasket (but did on the front where vanos and block meet).
Thoughts??
      09-01-2020, 11:03 PM   #2
rsuhandy
rsuhandy's Avatar
Drives: F06 M6;E92 M3;E85 Z4M; 958 SEH
This is on the right rear side of the engine. If you did your VCG recently I would check to see if the leak is coming from your exhaust side camshaft sensor. There is an o-ring that typically fails that can be replaced.
MadGus79.50
      09-02-2020, 06:03 AM   #3
MadGus
Drives: 2006 Z4MR
Thanks rsuhandy! Will check that out.
      09-02-2020, 09:46 AM   #4
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
It could also be your gasket if you use an aftermarket one. I also thought it was my camshaft sensor o-ring leaking after I had my valve adjustment done, but it turned out to be the aftermarket Elring VCG that was leaking in that right rear corner, which was on top of the camshaft sensor.
kaybat125.50
      09-03-2020, 06:17 AM   #5
MadGus
Drives: 2006 Z4MR
I picked up a new o-ring for the sensor yesterday and will install that today. The leak must be very small, wherever it is coming from... will clean it up and see if it returns.
I did use the Elring aftermarket gasket set when I did the VCG work over the winter.
I am hoping to not have to open her back up to replace the VCG, but that will be my next step if this doesn't work.
      09-03-2020, 06:37 AM   #6
MadGus
Drives: 2006 Z4MR
Swapped the o-ring just now and cleaned the area around it. Will update after a few hours of driving!
      09-03-2020, 02:16 PM   #7
MadGus
Drives: 2006 Z4MR
Still leaks. Will replace VCG at next oil change. Grrrr...
      09-04-2020, 05:09 PM   #8
maupineda
Drives: E86 Z4MC
Could be your constant pressure valve o-ring. Is in that area. Google it, is a common source of leaks
      09-04-2020, 06:06 PM   #9
MadGus
Drives: 2006 Z4MR
Thx! Will add that to the list of things to check before I pull the VC back open.
      09-11-2020, 01:50 PM   #10
MadGus
Drives: 2006 Z4MR
Replaced with OEM VCG this morning and drove for ~30 miles. No leaks so far. Will monitor... probably with a nice, long weekend drive on Blueridge Pkwy in Virginia.
      09-13-2020, 04:56 PM   #11
MadGus
Drives: 2006 Z4MR
Well... after another 75 miles, she still has a slight leak in the exact same place. AND after reading up some more on this, and finally consulting the online TIS (yep, I should have done this during the initial change this past winter), I realized that I only put RTV on the front seams where the block and VANOS mate. Hoping that the third time is a charm, and I will actually RTV the VANOS seams and the corners of the half moons on the rear of the gasket.
SMH.
      09-20-2020, 03:00 PM   #12
MadGus
Drives: 2006 Z4MR
Third time was also a failure, despite adding RTV to the corners of the half moons. And then I found this article:
https://blog.fcpeuro.com/how-to-repl...-cover-gaskets
And for the 4th time, I pulled the valve cover gasket and followed these instructions. Will allow it to cure for the full 24 hours before taking it for a test drive tomorrow afternoon.
I really hope this fixes it!
      09-23-2020, 04:27 PM   #13
MadGus
Drives: 2006 Z4MR
OK... that worked after ~150 miles, absoultely no leak whatsoever.
