      10-11-2019, 06:54 PM   #1
Enriqueruizfl
Drives: Bmw Z4m
Z4m rear camber arm install , help!!
Anyone do this before ? Any pointers in getting those inner bolts out near the diff?? ...thanks
      01-31-2020, 08:18 PM   #2
ANILE8
ANILE8's Avatar
No_Country
180
Drives: Z4 M Coupé - Carbon Black
The RHS is not too bad as it can be accessed by only dropping the rear output shaft but to access the LHS because the differential housing design is asymmetrical the three securing bolts have to be removed and the differential rotated into a position which will gain you greater clearance to remove the upper camber arm bolt.
See my install issues HERE
