      11-07-2019, 01:26 PM   #23
vt100
vt100's Avatar
126
Drives: '06 Z4MC, '12 128i
Originally Posted by Vanne View Post
Hey bud, its been a few weeks now since your install. How do you like it? anything you'd change?
Also, if it's possible, would be good to update / re-upload the pics I don't see most of them for some reason
      11-15-2019, 09:39 PM   #24
Arietis
Drives: Z4M Coupe
Great review, I was also on the market for one and after driving Vanne's car I knew I wanted one but the butchering of the interior was a deal breaker.
I finally pulled the trigger on a IRP (which I will post a review) and like Vanne said it's the best Mod ever for the Z
      12-28-2020, 10:01 PM   #25
ANILE8
ANILE8's Avatar
No_Country
180
Drives: Z4 M Coupé - Carbon Black
Just an update for anyone who is thinking about doing this. Do NOT forget to re-use the OEM rubber shifter boot. I originally junked mine because it was easier and as a result the heat rising from that area was insane. It felt like you had the heater turned up to max all the time.
Needless to say, I had to do the entire unpleasant job twice as it was unbearable. Had to buy a new one and do a little trimming for it to fit, but after installing it the difference was incredible.
wdb4732.00
TRiCC264.50
      01-19-2021, 10:58 AM   #26
1messedupZ4M
Drives: 2007 Z4M, 2003 E46 M3
Looks like their website lists it as "Pre-order". Wonder if they still make them?
      01-19-2021, 11:21 AM   #27
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
You can check out PSDesign shifter.. they are the same thing. Same origin I heard.. no affiliation.
      01-19-2021, 03:38 PM   #28
1messedupZ4M
Interesting...
      01-19-2021, 06:06 PM   #29
ANILE8
ANILE8's Avatar
No_Country
180
The PSDesign shifter does look to be made by RTD just rebranded under their own name. This wouldn't be a huge surprise as they seem to be an RTD dealer.
However, the PSDesign shifter is not a lockout design nor does it feature adjustable side stops for 1-2 and 5-6 shift like CAE and the RTD REVO1.
Never the less it is available in both 300mm and 360mm heights if that is all you are looking for.
RTD is still available, look at their Instagram page for updates on production timeframes. Maher always delivers.
      01-19-2021, 08:25 PM   #30
TRiCC
E86 M Coupe
TRiCC's Avatar
265
Drives: Z4M Coupe
I have a PSDesigns chassis mounted 300mm shifter! Hands down one of my favorite mods! Thanks for making this thread! Helped tremendously!
      01-20-2021, 11:35 AM   #31
FarmerD
FarmerD's Avatar
73
Drives: M340i Touring
Hi mate
Quick Q - I have a psd shifter being installed next week and have a new oem dust boot ready to go on. It looks like you’ve just trimmed the top tube which the shaft goes through, and then bolted the shifter on top of the rubber on the transmission tunnel. Do you feel any slop/slack in the shift given the shifter cage is sitting on the rubber and not the chassis direct? Also I not you’ve not cut off the bottom of the boot? Does this interfere with the shift action?
Thanks for the idea of doing this in the first place - great encouragement to get on with it!
      01-20-2021, 03:11 PM   #32
ANILE8
ANILE8's Avatar
No_Country
180
Originally Posted by FarmerD View Post
Hi mate
I am glad I have helped some people get this done, with a few key pointers it can make the job much smoother.
Well no, firstly the shifter is not 'sitting' on the rubber boot. Please look carefully at the picture and you will see I used three washers to clear the bottom lip of the boot from the top. The front washer I ground one side a bit flat to clear the boot so I did not have to trim the top flange.
The washers I used were thicker than the thin rubber base flange on the top side. Believe me, when you torque all three bolts down it is metal on metal contact.
Secondly, the bottom of the boot has been cut to clear the front bolt and DSSR. Please see the second picture. If you do not do this you will get rubbing as it sits very close to the bottom of the trans tunnel already.
      01-20-2021, 03:45 PM   #33
FarmerD
FarmerD's Avatar
73
You sir are a legend. Thank you for this. Can’t wait!!!
      02-05-2021, 04:15 PM   #34
FarmerD
FarmerD's Avatar
73
Just to update the thread, I’ve now fitted the psd shifter per Mr Anile8’s instructions with the oem boot in place. Works perfectly with no additional noise but a much shorter, crisper shift. Very pleased.
Ps no idea why photo is upside down!
      08-05-2022, 12:28 PM   #35
NLE
Drives: BMW M3 & Z4M
RTD’s site doesn’t list a Z4 M specific shifter. Is the correct one to order the e46 model (and NOT the e8x / e9x model) even though we have a different transmission to the M3?
How does the RTD race lever compare in terms of height and resistance to the CAE?
      06-04-2023, 06:18 PM   #36
NLE
Anyone with an answer here?
      06-04-2023, 08:48 PM   #37
ANILE8
ANILE8's Avatar
No_Country
180
You want a E30, E36, E39, E46, E60, E63 shifter, the direct ordering link was provided in #1 post of this thread. For the Z4 platform you need to reverse-fit it as already discussed. The same goes for the CAE unless you want to start cutting up your interior trim.
Well unless this is a trick question the CAE Ultra Shifter is listed on the manufacturer's website as 315mm, the RTD as already mentioned in post #1 is 360mm for the Race version, so unless I'm mistaken the difference would be 45mm.
Resistance will be determined largely by the height of the shifter as both offer a race chassis solid mount shifter with a through bushing design. Generally, the longer the shifter, the lower the force needed.
