      03-28-2015, 10:26 PM   #221
Z4Oak
Drives: Silver 2004 BMW Z4 2.5
Tires rims
I'm thinking of getting NT 555 extreme ZR tires for my 2004 z4 2.5 ,,235 40 18 front 265 35 rear , with 18" niche wheels . Would 18x8 on the front , and 18x9.5 rear look good? I was debating between 18x8 or 18x8.5 on the front. Will either work?
      03-29-2015, 07:41 AM   #222
BGR
Drives: C7 GS 7MT; e90 M3 6MT
Here are my Breyton GTS-R wheels on the coupe.
225/40R18x7.5 et 45 with a 12mm spacer up front
255/35R18x8.5 et 48 with no spacer in the back
Over a seriously aggressive bump, the front rubbed for a split second on the fender. This makes no sense to me based on all the calcs I have done. Unless the 7.5" wheel making the shoulder of the tire is more square caused it, but I still think there should be plenty of room. Tired are Direzza ZII which are also a little more square than a PS2.
      03-29-2015, 01:43 PM   #223
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
07 z4 3.0si  [0.00]
So after months of contemplating which wheels to definitely buy this spring, I've opted to go with apex ps-7. After searching a few times, I've noticed that according to some posts from apex the correct fitment for a non m is 8.5" ET35 and 9.5" ET43 fitment. Which basically leads to both wheels being the same profile and at the minimum i wanted profile 2 in the rear. When I went on turner motorsports site, they have listed that ET33 9.5" fits. Wondering if anybody could shine some light on if this fitment would work. Also,car is lowered with bilstein struts n h&r springs and have rogue engineerings adjustable RCA if that would help at all. Any insight would be appreciated!
      04-07-2015, 05:31 PM   #224
jewagr007
Drives: 2004 Z4 3.0I
Anyone ever run 20's on their non-M Z4?
      04-08-2015, 02:52 PM   #225
Twixboy
Drives: '04 Z4 3.0i 6spd
Wasn't there a guy on here with 22's?
      04-08-2015, 07:59 PM   #226
horsepit
horsepit's Avatar
Drives: 2014 BMW 550i
Can I run 550i wheels
This may have been discussed but I can't find it. Can I run my 2014 BMW 550i wheels on the 2006 Z4? They are 19x8.5 ET33 and 19x9 ET44. Tires are 245/40 and 275/35. I guessing too big. I put M5 wheels on the 550 so I've got them sitting around and figure they would look a lot better than the little 17" on it now.
2014 F10 550i Space Gray| Avant Garde M355 20x9 ET35 + 20x10.5 ET38
| Michelin PSS 255/35 + 295/30 |
      04-09-2015, 12:58 AM   #227
jdoublehcubed
Mechanical Engineer
Drives: 2006 Z4MR, Imola Red
by "here" you mean west side baltimore, right?
      04-10-2015, 09:52 AM   #228
Twixboy
LOL no, but I found the 22's. It was actually another forum, but worth linking to see his 20's on the front and 22's in the rear. Not my style, but shows it can be done.
http://www.z4-forum.com/forum/viewto...rt=210#p327599
      06-03-2015, 07:23 AM   #229
Exist
Drives: 2007 Z4 3.0si Coupe
Idea piqued my interest. Anyone tried Style 5's? I've only been able to see 1 picture on a google search, but it was a roadster. Curious on how they would look on a 3.0 coupe.
-Spencer
      06-18-2015, 11:26 AM   #230
lunatik1
Drives: 2003 Z4
I found a good deal on a 18x8 +15 with a 225/40/18, will it fit on a 03 Z4 non sport-roadster?
      06-20-2015, 07:19 PM   #231
E86Z
Drives: 3.0si
Here's a little help for those wondering about fitment with the following specs:
Front 18x8.5" ET43 Tire: 235/40/18
Rear: 18x9.5" ET43 Tire: 255/35/18
The tires came with the wheels and are finished, I would go 225 in front and 265 rear.
Opinions on the color of the wheel center piece and on the wheel set in general are welcome.. I'm still not convinced I like them haha
      06-20-2015, 08:41 PM   #232
3002 tii
3002 tii's Avatar
2288
LMAO where's Omar??!!
Follow for latest mods
      08-15-2015, 02:52 AM   #233
Keithlam430
Drives: Z4 Coupe 3.0si
Does anyone know whether 235/35/19 and 265/30/29 will have any rubbing issues on standard 3.0si?(Planning to lower it a bit tho).
Wheels are 19 x 8.5J ET33 front, 9.5J ET40 rear. Any inputs will be appreciated!
      08-25-2015, 01:36 PM   #234
03z4
Drives: 2003 z4 2.5
Ok I'm ordering 18 x 8.5 et30 front and 18 x 9.5 et35 rear for my 03 z4. I plan on running 265 35 rear...what would match that in front?
      08-25-2015, 04:49 PM   #235
Steeler
Steeler's Avatar
2429
235/40 works for me
      09-05-2015, 02:22 PM   #236
NeilP
Drives: Z4 Coupe
Thought I'd contribute here my setups.
BMW Style 63 (with a 10mm spacer front and back)
Front: 19x9" ET48 Tyre: 225/35/19
Rear: 19x10" ET45 Tyre: 255/30/19
IMG_8067 by Neil Patel, on Flickr
257. Done by Neil Patel, on Flickr
Rial Daytona
Front: 19x8.5" ET14 Tyre: 215/35/19
Rear: 19x10" ET35 Tyre: 235/35/19
DT5_7937 by BMW Car Club GB & Ireland, on Flickr
IMG_1610 by Neil Patel, on Flickr
      09-08-2015, 04:09 PM   #237
03z4
Drives: 2003 z4 2.5
So I'm already starting to worry about the 265 35 18 to my 9.5 width rear wheels...im hoping they aren't balloon looking once mounted...I ordered kenda kaiser kr20
      09-09-2015, 03:09 PM   #238
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
9.5" is the perfect size for 265/35/18. No need to worry.
      09-11-2015, 10:16 AM   #239
03z4
Drives: 2003 z4 2.5
Well I went with kendas...these will be huge compared to the current stock wheel tire combo on my 03 2.5! The tires may not be high quality but they have a killer tread pattern and if I decide not to keep the car for long I won't be out too much tire money since I was able to get the entire setup (wheels and tires) brand new and shipped for under 1k.
      09-16-2015, 02:55 AM   #240
03z4
Drives: 2003 z4 2.5
Wheels arrived...getting closer
      01-08-2016, 08:42 AM   #241
Exist
Bump for those who may be looking for it.
Shouldn't this be stickied like the M thread?
-Spencer
      02-26-2016, 04:17 PM   #242
evotechnik
Drives: 2005 Z4 Roadster
Here's my contribution! 2006 3.0Si on M-Sport Suspension Stock Height
225/40R 18 x 8.5 et 35
255/35R 18 x 9.5 et 45
VMR 710 in Gunmetal Finish
I think that a 18x9.5 + 35 would fit much nicer than the 45 in the rear if you want to get more aggressive.
