      07-04-2022, 08:25 PM   #1
3002 tii
3002 tii's Avatar
2288
Front Fitment 9.5 et23 - How Much Camber
Assuming I want to run 255 up front, what’s the min camber? Anyone with actual experience?
Follow for latest mods
      07-05-2022, 07:40 AM   #2
F360C
Drives: E86 S54
I think the offset on the wheel might be too much... I run a 265 front with a 9.5" et30 front wheel and it has a lot of poke.
255 fits really nice with -2.6ish camber. 265 requires a min of -3
07 Z4 M Coupe AW/IR
3002 tii2287.50
      07-05-2022, 07:59 AM   #3
3002 tii
3002 tii's Avatar
2288
Thanks, that’s what I thought but having someone else validate is helpful.
      07-05-2022, 12:31 PM   #4
kyriian
kyriian's Avatar
885
Drives: 06 Black Sapphire Z4MR
2014 BMW X5  [0.00]
2011 Scion tC  [0.00]
The poke should be fine when static or just driving around, I am running 9.5 front, et28 with a 3mm spacer, I had used a 5mm before (effectively making et23) with -2.5 on 245/40 RS4 to clear my KW CS. You will find out just how little room there is though once you start hitting the track. I was rubbing on metal with the 5mm spacer with a fairly significant roll.
I have removed my helpers now which really helps so i moved back to 3mm and make clearance better.
Next time round I am thinking of going 255/35, wider but smaller diameter may change the dynamics
Revolution of our Times
I will return to the track, one day.
3002 tii2287.50
      07-05-2022, 04:11 PM   #5
Beedub
would love to see some pics if possible
      07-13-2022, 08:25 PM   #6
TAL2GK
TAL2GK's Avatar
145
Drives: 2006 Z4M Coupe, 2017 911
Apex has an amazing resource for thishttps://support.apexraceparts.com/hc...-Fitment-Guide:
2003 Z4 2.5i Roadster (SOLD)
2006 Z4M Coupe
2017 Porsche 911 C2S Cabriolet
